![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I believe something is seriously wrong with the include file shapes.inc, and
particularly with the HFCreate_ () macro.
Try this code, with an image twice as long as high (i.e. a planetary map):
#include "shapes.inc"
#declare F_HF1 =
function {
image_map {
png "my_image.png" gamma 1.0
map_type 1
interpolate 2
#declare F_HF2 = function (x,y,z){F_HF1(x,y,z).hf}
//HF_Sphere macro
HF_Sphere (
F_HF2, // Function,
0, // UseUVheight: 0 or 1
0, // UseUVtexture: 0 or 1
<1000, 1000>, // Resolution,
1, // Smooth, // 0 or 1
//"shapes_test.inc", // FileName or
"", //comment out one of these lines
<0,0,0>, // Center
2.0*10 , // Radius
0.08*10 // Depth
// end of HF_Sphere
object {
#include "shapes_test.inc"
pigment {rgb <1,1,0>}
1) for resolutions higher than approximately 1000, parse errors occur and
the render fails, whether a file is saved or not.
2) If you examine a save file, you will notice that the data sets are
written all on one line and without separating commas.
Typical parse error messages are:
For a saved file:
"shapes_test.inc" line 7: Parse Error: No matching } in 'face_indices', <
found instead
For a render without save file:
"C:\...\POV-Ray\v3.7\include\shapes.inc" line 967: Parse Error: bad
allocation
As said, in both cases the render failed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 17/05/2011 14:14, Thomas de Groot nous fit lire :
I got 8 lines in the saved file with a 2400x1200 image.
No comma between vector (but comma is traditionally optional in SDL)
I have an issue on the face_indices values: 1.996e+06 is not a good
value, as I have a bit more vectors and it complains about finding a "<"
instead of a "}".
The number should not be rounded.
You get lucky with 1000x1000 as it comes out as 1e+06
but you would be in trouble with 1001x1001, IMHO.
A few line feed would be welcome too.
(like one every 10 vector ?)
The update should be done in the #Write of HFCreate_, to replace
xRes*zRes with
xRes,"*",zRes
(and
(xRes-1)*(zRes-1)*2 with
(xRes-1),"*",(zRes-1),"*2"
) (if you get the spirit of it ?)
There already some double while-loop used to dump the vectors, so adding
a "\n" under #if(WriteFile) might already ease the output file.
(well, instead of 1 line of 1 million vectors... 1000 lines of 1000
vectors each... is that better ?)
> For a saved file:
> found instead
> allocation
I got a full render if I comment out the last "object" from the scene.
It's just plain black. (well, no light, no ambient.. ok)
The maximum resident size was 2 161 776 kilobytes. Might be an issue for
32 bits systems. (that's a bit more than 2 Giga, usual issue for 32 bits
program)
What is your system ?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Le_Forgeron" <jgr### [at] free fr> schreef in bericht
news:4dd2a7cf$1@news.povray.org...
> instead of a "}".
The better output format would be line feed for every data value, separated
by commas, i.e. the way Poseray writes mesh2 data. That way the file is
easily readable in all circumstances.
> xRes*zRes with
> xRes,"*",zRes
> (and
As shall play with this, thanks!
As said above, Poseray's lay-out is a better standard imo.
> program)
Yes, the size of the output might be a problem indeed. In general, I want to
keep my mesh2 files well under the 100Mb.
My system is an 32 bits WinXP-SP3, 3GHz, dual core machine.
Thanks for this already!!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> > program)
So the maximal address space for user data & code is 2 Giga (the 32th
bit is used on that system to reach the kernel space and other fancy zone).
No hope for that scene on that system. Sorry.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> xRes*zRes with
> xRes,"*",zRes
> (and
This is not really necessary in fact.
Better is to replace:
PArr[J][K],
with:
#if(WriteFile)
PArr[J][K],"\n",
#else
PArr[J][K],
And:
vnormalize(vcross(PArr[J][K+1]-PArr[J][K-1],
PArr[J+1][K]-PArr[J-1][K])),
with:
#if(WriteFile)
PArr[J+1][K]-PArr[J-1][K])),"\n",
#else
And:
<(J-1)/(xRes-1),(K-1)/(zRes-1)>,
with:
#if(WriteFile)
<(J-1)/(xRes-1),(K-1)/(zRes-1)>,"\n",
#else
And finally:
F1+A, F2+A,
with:
#if(WriteFile)
F1+A, F2+A,"\n",
#else
F1+A, F2+A,
This works fine.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Le_Forgeron" <lef### [at] free fr> schreef in bericht
news:4dd37e05@news.povray.org...
Indeed. It is to find the balance where everything still works fine....
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 05/18/2011 05:17 AM, Thomas de Groot wrote:
> "Le_Forgeron"<jgr### [at] free fr> schreef in bericht
>> xRes*zRes with
>> xRes,"*",zRes
>> (and
> PArr[J][K],
> with:
> #if(WriteFile)
> PArr[J][K],"\n",
> #else
> PArr[J][K],
> #end
> And:
> with:
> #if(WriteFile)
> #else
> #end
> And:
> with:
> #if(WriteFile)
> #else
> #end
> And finally:
> F1+A, F2+A,
> with:
> #if(WriteFile)
> F1+A, F2+A,"\n",
> #else
> F1+A, F2+A,
> #end
> This works fine.
> Thomas
I recently fixed warning messages that the Bevelled_Text macro (also in
shapes.inc) was spitting out (unnecessary bounding), so when you're
happy with the repairs you've made, attach the updated file in
p.t.scene-files and I'll make sure it gets into the distribution.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Jim Holsenback" <jho### [at] povray org> schreef in bericht
news:4dd39438$1@news.povray.org...
> shapes.inc) was spitting out (unnecessary bounding), so when you're happy
> with the repairs you've made, attach the updated file in p.t.scene-files
Excellent. I have now also added the *missing* commas. Not really necessary
of course, but it appeals to my sense of *correctness* so to speak :-)
Only for the face_indices block, have I not been able to write the last
vector without a comma.. Nonetheless, I shall put this version of shapes.inc
in p.t.scene-files. If somebody can solve this small problem, let us know.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Silly trick: the comma is not after the vector, but before it...
just my 0.02€ (Tax Not Included)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:4dd3d3c8$1@news.povray.org...
> just my 0.02? (Tax Not Included)
oh, right.... never thought of that trick... I shall have to try this out
first though...
Thanks for this :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
