POV-Ray : Newsgroups : povray.beta-test : Gamma of interpolated colors in color maps Server Time
24 Jun 2026 19:53:40 EDT (-0400)
  Gamma of interpolated colors in color maps (Message 31 to 36 of 36)
Subject: Re: Gamma of interpolated colors in color maps
Date: 26 Dec 2010 01:10:06
Message: <web.4d16db7bc7728638ae5c9ba20@news.povray.org>
"Edouard" <pov### [at] edouardinfo> wrote:
> Warp <war### [at] tagpovrayorg> wrote:
> >   Likewise with gradients: The default should be *perceived* linearity,
> > the absolute linearity being the special case which has to be specified
> > in a special way.
> I sort of agree, but I think perhaps a more general solution would be even more
> useful; allow the user to specify the colourspace in which the interpolation is
> working. So you can specify a linear coourspace, or a sRGB colourspace, or a
> specific gamma, or (actually quite usefully) HSV or L*ab or some other non-RGB
> one.
> >                                                           - Warp
> Cheers,
> Edouard.
Christ, now we're (almost) getting into the territory of how I want to implement
true "specify your spectrum" lighting/pigments...  :-D
(Granted, that _would_ pretty well obviate this whole argument because if you're
stating the spectrum, obviously you're stating it in [fake-unitized] radiant
flux at various wavelengths, but it's also enough work to try and implement that
I doubt it'd be finished before we were staring down the barrels of POV-Ray
5.0...)
Date: 4 Jan 2011 08:19:52
Message: <4d231e78@news.povray.org>
>> OOC did you decide already which algorithm to use for this? Will it give
>> more linear looking gradients between different colours too?
> I expect so.
> When interpolating between two colors, POV-Ray currently computes
> something along the lines of:
> q = 1-p;
> result = p * color1 + q * color2;
> For a "perceptually linear" gradient, the formula would be changed to:
> q = 1-p;
> temp1 = pow(color1, 1/gamma);
> temp2 = pow(color2, 1/gamma);
> tempR = p * color1 + q * color2;
> result = pow(tempR, gamma);
> where gamma would be a value around 2.5.
OOC why 2.5?  CIELAB uses a value of 3 to computer the "lightness".
Whilst that will be great for greys, it might not work so well for
colours.  For example if you take a gradient between dark green and dark
blue, or between purple and orange, I actually think the 3.7 "physically
linear" method gives a more perceptually linear result currently.
Date: 4 Jan 2011 09:42:24
Message: <4d2331d0$1@news.povray.org>
>> I expect so.
>> q = 1-p;
>> q = 1-p;
Just asking a question now:
Why should the interpolation be done in rgb colour space ?
(whatever the gamma used, it would still be a line in a rgb(gamma) space).
Well, may be the word "always" is missing from the question.
(I have been playing a bit with interpolated colors in blobs: rgb, xyv,
xyl, hsv & hsl... not always the same results, but I'm lacking a good
showcase so far).
Interpolating between "red 1" and "green 1", should it always go via a
"yellow 0.5" ? Tuning the gamma in previous formula allow to shift that
a bit, but wouldn't a different color space be simpler and better
instead ? (as an option of the map)
How do you expect to interpolate between "green 1" & "magenta 1"
(opposite rgb value, but both fully saturated : should interpolated be
not saturated ?) ?
Date: 4 Jan 2011 10:25:45
Message: <4d233bf9$1@news.povray.org>
The problem is if you tune the gamma for that, you'll end up needing a
different gamma value for every pair of colours to give the perceptually
linear result you want.
There are colour spaces designed specifically so that equal distances
equate to equal difference perceptions, one of these could be used
instead of rgb (just for the interpolations, if some keyword like
"perceptual" is specified) and it would give correct results for any
possible input colours.
 > How do you expect to interpolate between "green 1"&  "magenta 1"
 > not saturated ?) ?
Green and magenta is a good example of a gradient that looks much better
in 3.7 compared to 3.6 IMO.
Date: 4 Jan 2011 10:55:49
Message: <4d234305$1@news.povray.org>
Am 04.01.2011 16:25, schrieb scott:
I guess you're making a good point there, for why the way I'm aiming for
is the right way to go: Making linear color space the default and fixing
the places where it leads to noticeably unpleasant results. Because
after all, I'm convinced that those places have always been problematic,
but haven't been recognized as such because it wasn't that obvious as
with a linear color space.
So yes, you've convinced me that we need to leave RGB space there. Maybe
color map interpolation is a good place to start introducing color space
handling into the POV-Ray code.
Date: 6 Jan 2011 22:48:19
Message: <4d268d03$1@news.povray.org>
Am 04.01.2011 14:19, schrieb scott:
>> q = 1-p;
Maybe this is just CIE's way of avoiding potential trouble if someone
tries to feed negative values into the formula for converting from CIE
XYZ to L*a*b*.
Note that for instance Hunter Lab uses a gamma of 2.0.
