POV-Ray : Newsgroups : povray.beta-test : Render Priority Server Time
25 Apr 2026 23:52:20 EDT (-0400)
  Render Priority (Message 32 to 41 of 41)
Subject: Re: Render Priority
Date: 28 May 2010 03:20:00
Message: <4bff6ea0$1@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailcom> schreef in bericht
news:4bfda97c@news.povray.org...
> Getting 100% CPU usage is expected. But you shouldn't be getting any
> slowdown.
> Processes with low priority get all the CPU timeslices that aren't being
> used by a process with higher priority. As soon as an app in normal
> priority
> tries to use the CPU, POV-Ray will use less of it.
I understand that. My experience however is that, with the (low priority)
3.7 render active in the background, all other rapplications I start/use,
regularly /hang/ for some time (seconds to tens of seconds) before resuming
again. This is not the case with version 3.6, or at least hardly noticeable.
Date: 28 May 2010 06:37:13
Message: <4bff9cd9$1@news.povray.org>
Am 28.05.2010 09:19, schrieb Thomas de Groot:
>> priority
Same here.
I guess the Windows scheduler gives comparatively long time slices to
processes, and doesn't cut them short even if higher-priority processes
are ready. So while in /theory/ applications shouldn't bother about
scheduling, in /practice/ it would be good if POV-Ray yielded its time
slices now and again, at least on Windows systems.
Date: 28 May 2010 07:04:33
Message: <op.vdew1srk7bxctx@toad.bredbandsbolaget.se>
> are ready.
That is not what they say:
http://msdn.microsoft.com/en-us/library/ms685100.aspx
"If a higher-priority thread becomes available to run, the system ceases
to execute the lower-priority thread (without allowing it to finish using
its time slice), and assigns a full time slice to the higher-priority
thread."
A quick test on my own system shows that the GUI of other applications can
get slightly sluggish during a render, but not if I disable the preview
display. Perhaps POV-Ray spends a noticeable amount of time drawing the
preview (GDI functions are notoriously slow) and Windows does not want to
preempt that (either because some parts are non-reentrant or because
drawing to the screen temporarily boosts priority; I do not know).
FE
Date: 28 May 2010 11:31:26
Message: <4bffe1ce$1@news.povray.org>
Am 28.05.2010 13:04, schrieb Fredrik Eriksson:
>> processes are ready.
> using its time slice), and assigns a full time slice to the
> higher-priority thread."
Then there must be some other reason for the effects I do see. Maybe
some effects due to priority boosts?
Date: 28 May 2010 12:16:10
Message: <op.vdfbg5uy7bxctx@toad.bredbandsbolaget.se>
What effects do you see? As I said before, for me any issues seem to only
be noticeable with the preview display active, so it might be something to
do with that.
> Maybe some effects due to priority boosts?
The conditions for priority boosts are described here:
  http://msdn.microsoft.com/en-us/library/ms684828.aspx
The article also explains how to prevent priority boosts from happening.
FE
Date: 28 May 2010 13:45:16
Message: <4c00012c@news.povray.org>
Am 28.05.2010 18:16, schrieb Fredrik Eriksson:
> only be noticeable with the preview display active, so it might be
> something to do with that.
I virtually always have the preview display active, so yes - it might
indeed be related to that. Doesn't make it any better though.
Date: 30 May 2010 12:23:11
Message: <4c0290ef$1@news.povray.org>
did you try with 3.7 using only one thread? The difference
in behavior compared to 3.6 might simply be that 3.6 could not
really stress your dualcore CPU.
Also you might check if memory is running low if the
system starts feeling unresponsive.
Date: 30 May 2010 15:56:39
Message: <4c02c2f7$1@news.povray.org>
Am 28.05.2010 19:44, schrieb clipka:
Having kept an eye open, I noticed that responsivity is poor only at
certain intervals, and I also have the impression that these indeed
correlates with the finishing of SMP sub blocks.
So I think this calls for closer examination and - if possible -
elimination of this issue.
Date: 31 May 2010 04:27:29
Message: <4c0372f1$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4c02c2f7$1@news.povray.org...
Do you want me to issue a bug report?
Date: 31 May 2010 04:29:09
Message: <4c037355$1@news.povray.org>
I think that Christoph has - maybe - tracked down the problem. See his post
of yesterday, just above.
