Thomas de Groot wrote:
> My experience, with POV-Ray 3.7 on a dual core XP machine, with priority
> set to "lower than normal", is that both cores take up the full 100% cpu
> during render, slowing down all other applications having the focus during
> that time. Again, I repeat myself, I seem to remember that Priority was
> disabled during beta development, but I have had no confirmation of that
> until now.
Getting 100% CPU usage is expected. But you shouldn't be getting any
slowdown.
Processes with low priority get all the CPU timeslices that aren't being
used by a process with higher priority. As soon as an app in normal priority
tries to use the CPU, POV-Ray will use less of it.
"Nicolas Alvarez" <nic### [at] gmail com> schreef in bericht
news:4bfda97c@news.povray.org...
> slowdown.
> priority
I understand that. My experience however is that, with the (low priority)
3.7 render active in the background, all other rapplications I start/use,
regularly /hang/ for some time (seconds to tens of seconds) before resuming
again. This is not the case with version 3.6, or at least hardly noticeable.
Am 28.05.2010 09:19, schrieb Thomas de Groot:
>> priority
Same here.
I guess the Windows scheduler gives comparatively long time slices to
processes, and doesn't cut them short even if higher-priority processes
are ready. So while in /theory/ applications shouldn't bother about
scheduling, in /practice/ it would be good if POV-Ray yielded its time
slices now and again, at least on Windows systems.
On Fri, 28 May 2010 12:36:58 +0200, clipka <ano### [at] anonymous org> wrote:
> are ready.
That is not what they say:
http://msdn.microsoft.com/en-us/library/ms685100.aspx
"If a higher-priority thread becomes available to run, the system ceases
to execute the lower-priority thread (without allowing it to finish using
its time slice), and assigns a full time slice to the higher-priority
thread."
A quick test on my own system shows that the GUI of other applications can
get slightly sluggish during a render, but not if I disable the preview
display. Perhaps POV-Ray spends a noticeable amount of time drawing the
preview (GDI functions are notoriously slow) and Windows does not want to
preempt that (either because some parts are non-reentrant or because
drawing to the screen temporarily boosts priority; I do not know).
FE
Am 28.05.2010 13:04, schrieb Fredrik Eriksson:
>> processes are ready.
> using its time slice), and assigns a full time slice to the
> higher-priority thread."
Then there must be some other reason for the effects I do see. Maybe
some effects due to priority boosts?
On Fri, 28 May 2010 17:31:09 +0200, clipka <ano### [at] anonymous org> wrote:
What effects do you see? As I said before, for me any issues seem to only
be noticeable with the preview display active, so it might be something to
do with that.
> Maybe some effects due to priority boosts?
The conditions for priority boosts are described here:
http://msdn.microsoft.com/en-us/library/ms684828.aspx
The article also explains how to prevent priority boosts from happening.
FE
Am 28.05.2010 18:16, schrieb Fredrik Eriksson:
> only be noticeable with the preview display active, so it might be
> something to do with that.
I virtually always have the preview display active, so yes - it might
indeed be related to that. Doesn't make it any better though.
did you try with 3.7 using only one thread? The difference
in behavior compared to 3.6 might simply be that 3.6 could not
really stress your dualcore CPU.
Also you might check if memory is running low if the
system starts feeling unresponsive.
Am 28.05.2010 19:44, schrieb clipka:
Having kept an eye open, I noticed that responsivity is poor only at
certain intervals, and I also have the impression that these indeed
correlates with the finishing of SMP sub blocks.
So I think this calls for closer examination and - if possible -
elimination of this issue.
"clipka" <ano### [at] anonymous org> schreef in bericht
news:4c02c2f7$1@news.povray.org...
Do you want me to issue a bug report?
