POV-Ray : Newsgroups : povray.beta-test : Radiosity: maximum_reuse Server Time
16 Jul 2026 09:34:44 EDT (-0400)
  Radiosity: maximum_reuse (Message 1 to 8 of 8)
Subject: Radiosity: maximum_reuse
Date: 6 May 2010 04:19:43
Message: <4be27b9f$1@news.povray.org>
This info is unclear to me: what is the default value of the new radiosity
parameter maximum_reuse, and how to best use it in combination with
minimum_reuse? Maybe a little addition to the Radiosity Voodoo can be
expected...?   ;-)
Subject: Re: Radiosity: maximum_reuse
Date: 6 May 2010 05:15:08
Message: <4be2889c$1@news.povray.org>
Am 06.05.2010 10:19, schrieb Thomas de Groot:
> expected...?   ;-)
maximum_reuse defaults to 0.2 - which was also the hard-coded value in
POV-Ray 3.6.
In a nutshell, the parameter governs the maximum effective radius of
radiosity samples in just the very same way as minimum_reuse governs the
minimum effective radius; a value of 0.2, for instance, means that a
sample at X units distance from the camera will be re-used within a
radius of at most 0.2*X units.
Obviously this parameter should be > minimum_reuse at all times. While
reducing the value will almost certainly increase rendering times, it
might be useful e.g. in cases where you have wide open spaces with a few
comparatively small objects, which the radiosity pretrace might tend to
miss otherwise.
Date: 6 May 2010 09:51:18
Message: <4be2c956$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4be2889c$1@news.povray.org...
> POV-Ray 3.6.
> sample at X units distance from the camera will be re-used within a radius
> miss otherwise.
Perfectly clear, Christoph. Thank you very much.
Date: 6 May 2010 13:10:29
Message: <4be2f805$1@news.povray.org>
>> radiosity
>> expected...? ;-)
> POV-Ray 3.6.
> miss otherwise.
What will appen if you set it to low: smaller than minimum_reuse?
An error, a warning and proceede, a warning and use the default value
instead,...
Date: 6 May 2010 15:42:21
Message: <4be31b9d$1@news.povray.org>
Am 06.05.2010 19:10, schrieb Alain:
> instead,...
Presently, "maximum_reuse" will quietly win over "minimum_reuse" without
any warning.
Date: 8 May 2010 16:12:57
Message: <4be5c5c9$1@news.povray.org>
>> instead,...
> any warning.
I think that's an acceptable beaviour. The only change I see would be
the isuing of a warning in that case.
Date: 9 May 2010 01:55:01
Message: <web.4be64d2227756df6f035a3e20@news.povray.org>
> >> instead,...
> > any warning.
> Alain
Actually, if it's setting both the maximum and minimum reuse to the same value,
it's basically saying "only reuse if it's within (arbitrary small float value)
of maximum_reuse".
In effect, it mostly disables reusing of samples, with exceptions that aren't
necessarily reproducible on systems of different architecture (like, say, if
someone were inclined to make a build of POV-Ray for the XBox 360, since pretty
much everyone else is using an Intel or AMD processor).
I'd be inclined to, in situations like this, give a warning and then swap the
values on the assumption that someone just wasn't paying attention, rather than
a "mostly disabled" setting that's going to, at some point in the future, drive
someone nuts.
Date: 9 May 2010 02:24:28
Message: <4be6551c@news.povray.org>
Am 09.05.2010 07:50, schrieb MDenham:
>>> any warning.
>> Alain
> of maximum_reuse".
No, that's not what it does.
As the person who overhauled the radiosity code for v3.7, and
implemented the code to expose this parameter to the user, I guess I
know a bit about the matter ;-)
You are right that there is indeed a mechanism in place to suppress
samples that would be "too small" (i.e. too close to other objects) to
be useful, and also that this mechanism's threshold is currently tied to
the maximum_reuse parameter; however, that's not the main purpose of the
parameter, nor is there any corresponding minimum_reuse-related
mechanism discarding samples that would be "too large" (such samples are
just "trimmed down" in size, /after/ having been subjected to the "too
small"-test).
