POV-Ray : Newsgroups : povray.beta-test : Beta 37 changes to file gamma? Server Time
15 May 2026 22:12:34 EDT (-0400)
  Beta 37 changes to file gamma? (Message 1 to 10 of 30)
Subject: Beta 37 changes to file gamma?
Date: 27 Apr 2010 17:39:20
Message: <4bd75988@news.povray.org>
Just trying out beta 37 of povray and all output files are over bright
compared with earlier versions.
I always add the following lines to the end of my povray.ini file.
; .png Image Type by default
Output_File_Type=N
; Picture brightness
Display_Gamma=1
File_Gamma=1
The display seems ok but the output file is lighter, even with the default
file type (BMP).
Anyone else having trouble or is it my setup thats gone wrong somewhere?
Cheers.
Subject: Re: Beta 37 changes to file gamma?
Date: 27 Apr 2010 17:56:57
Message: <4bd75da9$1@news.povray.org>
Am 27.04.2010 23:39, schrieb Quietman:
At present I can't rule out that I might have broken something with
change #4932.
I'll try to recreate your scenario to see what's happening. Are using
assumed_gamma? If so, what value it is set to?
BTW, regardless of whether this is a bug or not, be advised that
File_Gamma=1 is not a good idea if you intend to share generated image
files; and are you sure that your display subsystem does indeed have an
overall gamma of 1.0 as indicated by Display_Gamma?
Date: 28 Apr 2010 10:59:10
Message: <4bd84d3e$1@news.povray.org>
Am 27.04.2010 23:56, schrieb clipka:
> change #4932.
Darn - I did indeed break it quite thoroughly.
Date: 28 Apr 2010 12:01:01
Message: <4bd85bbd$1@news.povray.org>
> Output_File_Type=N
> Display_Gamma=1
> File_Gamma=1
As a workaround, try setting File_Gamma to something like 0.98 or 1.02.
(Any value smaller than 0.99 or greater than 1.01 should do.)
Date: 29 Apr 2010 04:21:13
Message: <4bd94179$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4bd84d3e$1@news.povray.org...
>> change #4932.
OK. So this means that, if we do not want to work around this now, we should
better wait for the next beta (and stick with beta 36)?
Date: 29 Apr 2010 04:34:42
Message: <4bd944a2$1@news.povray.org>
Am 29.04.2010 10:21, schrieb Thomas de Groot:
> "clipka"<ano### [at] anonymousorg>  schreef in bericht
>>> change #4932.
I didn't break it as thoroughly as it seemed at first: The error only
kicks in when File_Gamma is set to 1.0 (or, more precisely, 0.99 to
1.01), which is normally not recommended anyway, so I fancy that the
average user will not be affected. Phew. <wipes sweat off forehead>
So please do upgrade to beta 37 and give it a go, as there are many
changes in there waiting for thorough testing.
Date: 29 Apr 2010 04:56:19
Message: <4bd949b3@news.povray.org>
news:4bd944a2$1@news.povray.org...
> kicks in when File_Gamma is set to 1.0 (or, more precisely, 0.99 to 1.01),
> which is normally not recommended anyway, so I fancy that the average user
OK. Anyway, the choice was taken out of hands as beta 36 crashes when going
automatically to the update site. I produced a mini-dump file, should I send
it somewhere? Have others the same experience?
Date: 29 Apr 2010 11:42:12
Message: <4bd9a8d4$1@news.povray.org>
>clipka" <ano### [at] anonymousorg> wrote in message
>news:4bd85bbd$1@news.povray.org...
>> Output_File_Type=N
>> Display_Gamma=1
>> File_Gamma=1
Setting them both to 1.02 fixed it.
Gamma settings have always been a source of trouble for my own renders with
povray. I can remember using version 3.5 and having to change gamma to
something lower. I stopped using assumed_gamma 1 in every file and changed
to the povray.ini settings when they were introduced.
I find using the defaults (2.2?) produces very bright washed out files. The
best fix I have found so far is to set both gamma settings to 1. It makes
the renders look natural in tone and colour for me.
I only do this for a hobby on a Samsung R700 laptop so sharing files with
anyone else isn't likely to happen. I assume it has a regular LCD screen (as
far as gamma goes).
Thanks for the help :)
Date: 29 Apr 2010 12:24:49
Message: <4bd9b2d1@news.povray.org>
  If you had been using true gamma 2.2 for all your povray images for your
entire life, you would find a gamma of 1.0 unbearably dark.
  The reason is that if you were accustomed to the proper gamma, you would
be using the adecuate colors for that gamma (eg. 0.5 for a *truly* mid-gray
color, etc).
  As for image map images which don't have gamma info in them, they have to
be pre-gamma corrected manually when using the correct gamma for your system.
POV-Ray 3.7 implements now a keyword to do that.
  Question: If someone "lies" to POV-Ray by claiming that his system uses
a gamma of 1.0 when in reality it uses a gamma of 2.2, and renders an image
with that setting, will that image look the same in a different system with
a different gamma (eg. one with a gamma of 1.8), or will it look different?
If so, how different (brighter, darker...)?
Date: 29 Apr 2010 15:30:22
Message: <4bd9de4e@news.povray.org>
Am 29.04.2010 17:42, schrieb Quietman:
I take a bold guess that this is probably because you're used to the way
older POV-Ray versions did it, and have developed an instinct how to
achieve the desired results for the old versions. Unfortunately that
instinct don't work with the /more realistic/ model used in 3.7.
You may also have been fooled by earlier betas which couldn't handle
input images properly (they did indeed get those input images too bright
and washed-out).
Well, I guess I'm trying to evangelize you here, but in the end it's
your choice of course.
