POV-Ray : Newsgroups : povray.beta-test : Gamma in POV-Ray 3.6 vs. 3.7 Server Time
3 Aug 2026 02:29:45 EDT (-0400)
  Gamma in POV-Ray 3.6 vs. 3.7 (Message 41 to 50 of 75)
Subject: Re: Gamma in POV-Ray 3.6 vs. 3.7
Date: 13 Sep 2009 04:56:14
Message: <4aacb3ae$1@news.povray.org>
MDenham wrote:
> From what I'm reading elsewhere, Y/Cr/Cb/K can be folded down to Y/Cr/Cb by just
> subtracting K from Y.  (Yes, this means you'd need to potentially support a
> negative luma component in the process of generating the colors at any given
> spot...  but shouldn't the internal calculation not have an issue with that
> anyway, given that negative channel values can crop up in OpenEXR files
> already?)
You are confusing things here. Negative luminance is just impossible
while having one or two negative RGB components (with at least one
positive) is perfectly valid and is indeed needed to describe colors out
of the gamut of the current RGB color system. In practice this means
e.g. colors that are not displayable on your CRT/LCD monitor but do
exist in the real world. Usually such colors are highly saturated
'neon'-colors.
The transformation from YCCK to RGB would require 2 steps.
First transform from Y/Cb/Cr to CMY in the same way as the YCbCr -> RGB
conversion is done (but actually you will get CMY values if
jpeg_color_space is JCS_YCCK ) either by using a set of pre-build lookup
tables like libjpeg does for speed reasons or by actually calculating
the transformation in place.
Leave the K untouched and you get CMYK.
But the transformation from CMYK (being a color separation) to RGB is
impossible without also knowing the used CMYK color space definition as
defined e.g. within an ICC profile. POV-Ray does currently not support
such color profiles.
And I know that there exists this simple 'formula' for converting CMYK
to RGB but believe me, this 'formula' should have never existed in the
first place. It once even found its way into the wikipedia article about
CMYK that was a mess at this time anyway and it was quite some fighting
involved to remove it. This happened a few years ago and meanwhile the
article is a quite good one. So if you are interested you may want to
look at the CMYK to RGB conversion section there for more details.
> Am I reading stuff from people who are grossly misinformed?
Might be ;)
-Ive
Date: 13 Sep 2009 05:35:15
Message: <4aacbcd3$1@news.povray.org>
clipka wrote:
> Ive, do you happen to know anything about IFF?
> (Maybe "not worth bothering about because it is definitely long obsolete
> by now"?)
Besides some sweet memories, an Amigo 500 was the fist machine I did use
POV-Ray with, I do also remember that I have a format specification
somewhere but as this might even be on some old 3.5" disk chances are
not very good that I will ever find it again.
But I do remember that the IFF/ILBM format was tailored to tightly fit
the Amiga hardware so I would be surprised if there was anything else
used as the actual system gamma of an Amiga. But I do not remember what
this might have been.
But while thinking about it, as the format was later even used on Atari
and Mac systems I might even be mistaken in this respect.
-Ive
Date: 13 Sep 2009 05:45:29
Message: <4aacbf39@news.povray.org>
clipka wrote:
> Ive, would it be a solution for such cases (but only those) to override
> the out_color_space with JCS_RGB, and have the library do the whole job
> (at the cost of precision)?
No. Libjpeg does not support a YCCK -> RGB transformation and it does
not support CMYK -> RGB transformation. So if the jpeg_color_space is
JCS_YCCK you can either get JCS_YCCK or JCS_CMYK from the library and
have to deal with color separations for yourself anyway.
-Ive
Date: 13 Sep 2009 06:17:16
Message: <4aacc6ac$1@news.povray.org>
No thanks - not for starters at least :-)
Date: 13 Sep 2009 06:35:01
Message: <web.4aaccaa6235fbd0cc15a32a60@news.povray.org>
> > already?)
Eh, negative luminance + positive Cr/Cb = <+,-,+> potentially (forgive the
massively bastardized variation on standard color syntax ;-D) - and negatives
on green are, from looking at normal "RGB vs. real coloring" gamut diagrams,
probably the most common colors that exist but aren't displayable.  Also, the
engine already handles "impossible" colors (components all negative,
hypersaturated colors that extend outside the gamut in the opposite direction,
&c.) so it's not like that's necessarily an issue other than the obvious "it'll
look weird and may not behave entirely correctly".
> 'neon'-colors.
Isn't the "formula" for CMYK->RGB essentially specific to an "ideal" ICC
profile?  If so...  *goes off to figure out a good syntax for true spectral
lighting and pigmenting, which is probably more in the realm of additions to
4.0 or later but would allow for "true" conversions both ways as well as other,
odder effects*
Date: 13 Sep 2009 06:42:58
Message: <4aacccb2$1@news.povray.org>
> odder effects*
Yeah, that would be something nice to have.
Including fluorescence, please :-)
Date: 13 Sep 2009 09:39:25
Message: <4aacf60d$1@news.povray.org>
Jpeg's YCbCr is a 1:1 adaption of the European standard tv signal
encoding (CCIR/ITU Rec. 601 IIRC) with the advantage that you can just
drop the CbCr part. This did make people happy who couldn't afford a
color tv. Sending a signal with negative Y would have made people quite
unhappy 'cause you just imploded their brand new tv set ;)
Seriously, jpeglib uses a strict range checking anyway (to avoid such
issues as the DCT compression might introduce some noise) and YCbCr is
just not *designed* to represent anything outside the gamut of a tv
monitor from this time. Thats not as bad as it sounds because, if I'm
not mistaken, this gamut was even defined wider than the currently
accepted sRGB gamut.
> profile?
An "ideal" CMYK ICC profile is somehow meaningless and does not exist.
Therefor such a 'formula' cannot exist and this was from the very
beginning my point ;)
What we have is a bunch of numerous international standards within the
printing business and an ICC profile is used to make clear to what
standard the CMYK separation does refer, tells something about the
intended ink set, raster...  and *a lot* more things.
> odder effects*
This is of course also something I would like to have, but as I'm not so
patient I'll wait with such things until computing power evolves much
more...
-Ive
Date: 13 Sep 2009 17:09:34
Message: <4aad5f8e@news.povray.org>
http://www.wotsit.org/list.asp?al=I
Date: 14 Sep 2009 11:43:07
Message: <4aae648b$1@news.povray.org>
Ive schrieb:
> To make life easier that's the libpng call for getting the
> sRGB chunk information. For the sole purpose of gamma correction you can
> safely ignore the value that is returned as sRGB_intent.
How about just checking for "png_inf->valid & PNG_INFO_sRGB"? Shouldn't
that do the same job?
Another thing: The sRGB spec speaks of aiming to achieve an overall
viewing gamma of 1.125; am I however correct in assuming that decoding
sRGB-encoded material according to the sRGB decoding function will
nonetheless reconstruct the /linear/ data?
Otherwise, if sRGB-encoded data was expected to already account for that
desired viewing gamma, for raytracing purposes it would theoretically
have to be compensated for, both when decoding and encoding.
Date: 14 Sep 2009 12:19:56
Message: <4aae6d2c$1@news.povray.org>
You are aware that you are breaking the poor mans idea of encapsulation
by directly accessing the fields from png_inf ;)
And it's by no means time critical, so why not just use the API call?
The sRGB viewing gamma of 1.125 is just another (poor mans) attempt of
taking the environment illumination of some typical pc user into
account. There are much more complicated attemps from the ICC and I
really think we do not need to care about this.
-Ive
