POV-Ray : Newsgroups : povray.beta-test : Gamma tutorial for the 3.7 documentation? Server Time
28 Sep 2024 23:22:03 EDT (-0400)
  Gamma tutorial for the 3.7 documentation? (Message 1 to 10 of 35)
Subject: Gamma tutorial for the 3.7 documentation?
Date: 6 Sep 2009 08:02:40
Message: <4aa3a4e0@news.povray.org>
I'm pretty sure that I am not, and will not be, the only one who gets
confused about the new (I suppose better) approach at gamma correction in
POV-Ray 3.7, which differs from the way 3.6 did it, and which results in
images looking different, and different approaches having to be used.
This will create a lot of questions related to this subject, repeated
over and over, especially when the final 3.7 is published.
  Thus I think it would be a great idea if we created a concise, clear and
easy-to-understand section to be included in the official documentation so
that we can simply direct people to it rather than having to explain things
over and over again. I was hoping we could come up with something in this
thread.
  Preferably this tutorial would be somewhere in the documentation that makes
it prominent and visible, rather then buried under hundreds of similar
subsections.
  My ideas about what this section should have:
  1) A simple and clear explanation behind the reasoning and motivation behind
the new gamma correction approach, why it makes sense and why it's better
than what POV-Ray 3.6 did.
  Also: Why POV-Ray 3.7 will render scenes differently than 3.6, when using
default settings and "#version 3.6" is not used.
  2) Why "Display_Gamma" and "File_Gamma" should always have the correct
values for the user's system (ie. usually 2.2, or in some Macs 1.8) and
why they shouldn't be abused for visual effects (because that's not their
purpose).
  3) The difference between PNG and other output image file formats in this
regard.
  4) How to render an old 3.6 scene using POV-Ray 3.7 so that it will look
the same (basically, by adding "#version 3.6" to the scene file; I also hope
that the small problem of the gamma metadata being written to the PNG file
regardless of that #version directive being used gets fixed, for full
backwards "emulation").
  5) How to pre-gamma-correct input images (if and when this feature is
implemented in POV-Ray 3.7) and why this has to be done (and why it doesn't
need to be done for input PNG images which already have a proper gamma
metadata in them). Likewise, how to pre-gamma-correct color values from
other programs (such as color pickers).
  Might not be the proper place for this, but perhaps also:
  6) If the user needs to do it, how to create an image which has no gamma
correction at all, only non-corrected raw pixels. The example of rendering
an image to be used for creating a heightfield could be mentioned.
Subject: Re: Gamma tutorial for the 3.7 documentation?
Date: 6 Sep 2009 09:45:41
Message: <t5f7a5hui0jc4u335s3jj4tft44ktieci9@4ax.com>
>POV-Ray 3.7
You're not the only one and I think that it is a good idea.
Onwards and upwards. :)
Regards
Date: 6 Sep 2009 10:55:03
Message: <4aa3cd47$1@news.povray.org>
Absolutely correct! Imo, this should be placed in the section "Getting
started" of the "Introduction to POV-Ray"
Date: 6 Sep 2009 11:43:05
Message: <4aa3d889@news.povray.org>
news:4aa3a4e0@news.povray.org...
> things
Agreed! If you'll gather the information and get it all polished up, then
post your final on a talk page (on the Wiki) where it should be included,
I'll make sure it get's in the next gen documentation!
Jim
Date: 6 Sep 2009 17:23:48
Message: <4aa42864@news.povray.org>
  About that... I wonder if POV-Ray should offer some kind of function to
do that, for convenience. In the same way as eg. degrees() and radians()
exist for convenience, even though they don't really save a whole lot of
work compared to if they didn't exist.
Date: 6 Sep 2009 18:18:58
Message: <4aa43552$1@news.povray.org>
I think that definitely yes, POV-Ray should have such a feature. It is
perfectly possible to roll your own macro to do that, but if POV-Ray is
going the full way for proper gamma handling, it should - I'd even say
/must/ - provide some standard procedure to do it, if only to make a
clear statement along the lines of "yes, /this/ is the right way to deal
with it". And I'd go as far as to say that it should work without having
to include a particular file, so it should be a built-in language
contruct, not just a macro.
Date: 7 Sep 2009 04:35:45
Message: <4aa4c5e1$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4aa43552$1@news.povray.org...
> /must/ - provide some standard procedure to do it, if only to make a clear
> statement along the lines of "yes, /this/ is the right way to deal with
> it". And I'd go as far as to say that it should work without having to
> include a particular file, so it should be a built-in language contruct,
> not just a macro.
Sven Littkovski's neat little "POV-Ray Color Picker" (2006; version 2.0) is
a good example of such a picker. I use it quite a lot and I recommend it
warmly. Built into POV-Ray would be a nice addition.
Date: 7 Sep 2009 06:52:29
Message: <4aa4e5ed$1@news.povray.org>
>> not just a macro.
Well, I wasn't thinking about a built-in color picker, but a built-in
language syntax for gamma conversion.
Of course having its own built-in color picker would be a neat feature
(and I do second this idea), but for instance on Unix systems, where
POV-Ray does not come with an "IDE", a feature built into the SDL to
perform gamma conversion math would still be required.
Date: 7 Sep 2009 08:07:58
Message: <4aa4f79e@news.povray.org>
Are you aware that this tool (like most others) will not apply the
required inverse gamma correction and will result in the usual washed
out colors similar to jpeg image maps when used with 3.7 or
assumed_gamma 1.0 ?
And to mention it again: wrong gamma correction does not only give wrong
brightness intensities, it changes also the hue.
-Ive
Date: 7 Sep 2009 08:14:30
Message: <4aa4f926$1@news.povray.org>
"Ive" <"ive### [at] lilysoftorg"> schreef in bericht
news:4aa4f79e@news.povray.org...
>> is a good example of such a picker. I use it quite a lot and I recommend
>> it warmly. Built into POV-Ray would be a nice addition.
> required inverse gamma correction and will result in the usual washed out
> colors similar to jpeg image maps when used with 3.7 or assumed_gamma 1.0
Ah... yes...? I had not really/consciously thought of that... This means
that picking a color from a RGB/HSL color chart in any paint application
will show this problem?
