POV-Ray : Newsgroups : povray.beta-test : Gamma tutorial for the 3.7 documentation? Server Time
19 Mar 2026 16:53:08 EDT (-0400)
  Gamma tutorial for the 3.7 documentation? (Message 21 to 30 of 35)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Gamma tutorial for the 3.7 documentation?
Date: 14 Oct 2009 20:47:37
Message: <4ad67129@news.povray.org>
Sven Geier schrieb:
>>  2) Why "Display_Gamma" and "File_Gamma" should always have the correct
>> values for the user's system (ie. usually 2.2, or in some Macs 1.8) and
>> why they shouldn't be abused for visual effects (because that's not their
>> purpose).
> I still don't understand this, to be honest. If PCs "usually" have a gamma
> of 2.2, why do I still have to tell the PC version of POVray these things? Why
> can the *default* behaviour on a PC not be the one that the majority of
> users will expect?
The default values /do/ match the standard of 2.2. The problem is that
there are some other things that don't work as a user may expect, unless
he knows a bit about the background.
> Why do I have to futz around with ini files (and make the same change every
> single time a new beta comes out because the old ini files get replaced with
> the new ones every time) just to get the behaviour that one would expect for
> a run-of-the-mill PC?
Well, what exactly /is/ the behaviour you'd expect? And why would it
require futzing around with ini files?
My guess would be that you're doing something wrong elsewhere.
>>  6) If the user needs to do it, how to create an image which has no gamma
>> correction at all, only non-corrected raw pixels. The example of rendering
>> an image to be used for creating a heightfield could be mentioned.
> Quite frankly I'd put this very high on the list. If I cannot get POVray to
> do what I want, I want it to do nothing. Just keep your hands off gamma and
> similar things. If I want gamma correction, I'll do it myself in a paint program
> after the fact.
Note that this would require you to virtually /always/ post-process the
image. I don't think that is what the majority of POV-Ray users would want.
Therefore, /by default/, POV-Ray /does/ perform gamma encoding (which
for various file formats is equivalent to gamma pre-correction). But you
can easily disable this by setting File_Gamma=1.0.
Note however that this does not make any difference at all for file
formats that provide meta-information about encoding gamma.
> That's a lot easier for me than reading up online for every minor revision how
> gamma is supposed to work this week and doing render after render to get to
> something that actually looks the way I wanted it (because this week the preview
> doesn't actually show what I get in my file).
You know that you're exaggerating here. The betas are not released
/that/ frequently - and gamma handling hasn't changed for a year or so.
Also keep in mind that we're talking about beta releases: They are
positively /not/ intended for people who just want to run POV-Ray "out
of the box" and bother about nothin'. It is instead a development
version, released to the public for everyone willing to be a guinea pig.
This shouldn't keep you from pointing out what irritates you about it,
and what you'd expect to be different - to the contrary, that's
absolutely desired - but please keep it fair, bearing in mind that it
should be /expected/ to still be in a state as to irritate you here and
there - and also to still be subject to change.
> You need to acknowledge that most users will read documentation NOT preemptively
> to understand the subtleties of the programming, but because they're trying to
> do something and it doesn't work. Number 1 on the list would be
> 1) My image looks (over- / under-) exposed. What should I do to make
> it (darker/brighter)?
Yes, the Questions & Tips section in POV-Ray's online help could be
improved I guess.
This one is not a particularly gamma-related problem though, as there
may be plenty of other reasons leading to similar effects; too high
ambient is probably the most common cause.
Date: 15 Oct 2009 12:03:39
Message: <4ad747da@news.povray.org>
Sven Geier <.sven.at.sgeier.dot.net.nospamplease> wrote:
> >  1) A simple and clear explanation behind the reasoning and motivation behind
> > the new gamma correction approach, why it makes sense and why it's better
> > than what POV-Ray 3.6 did.
> That's good information to have but it should definitely not be number 1) on the
> list. I would put this into some appendix somewhere ("If you were
> wondering ... see section ...").
  Except that its purpose it to explain why the feature has changed in
POV-Ray 3.7 compared to 3.6.
> >purpose).
> users will expect?
  Because not everyone's system has a gamma correction of 2.2?
  How is that related to this thread?
> >  5) How to pre-gamma-correct input images [...]
> Kinda specialized.
  You won't find it "kinda specialized" if you try to use image maps with
POV-Ray 3.7.
> after the fact.
  You are thinking of gamma correction in the wrong end of the process.
Gamma correction is not an image post-processing filter like brightness,
contrast or gaussian blurring. (Yes, some people abuse post-processing
gamma correction to adjust brightness and contrast, but that's not what
gamma correction is for.)
  Gamma correction is about how your *input* values are mapped to the
output values. In other words, when in the *input* you say "I want 50%
gray", gamma correction tells the program what it should write to the
output image in order to get 50% gray.
  Gamma correction is also about telling in the image data that "this
should be interpreted as 50% gray" so that if you view the image in a
different system with a different display hardware with different gamma,
that color will look like 50% gray there as well, and not eg. 40% or 60%
gray.
  Skipping gamma correction altogether has its own uses, but those are
seldom related to regular images. (One example is when using an image file
as a storage format for heightfield data.)
  If you specify "50% gray" in your scene file, and the end result is not
50% gray on your screen, is that how you wanted it to work? Because that's
how POV-Ray 3.6 works.
  Basically in POV-Ray 3.6 if you want a 50% gray color, you just can't
use "rgb 0.5". You have to manually find some value which will look like
what you want.  POV-Ray 3.7 wants to change that: It wants that "rgb 0.5"
means "50% gray".
> I can think of a hundred possible scenarios where an image gets rendered on a
> different computer than where it is viewed and what not, but I'd be willing
> to bet dollars to donuts that the vast majority of POVray users render and view
> on the same machine and have no real need for for anything beyond "I want this
> to look as it does in the preview".
  As I said, it's not only a question of whether the image will look the same
in another computer, but also about more consistent interpretation of colors
in the scene file. "rgb 0.5" should mean "50% gray", not something else,
because that's the most logical interpretation.
  In order to achieve that goal, gamma correction is needed.
  Currently in POV-Ray 3.6 the only way to get exactly what you want is to
try manually rgb values until you end up with something that looks like what
you want.
> Notably absent from your list is what I would put on the list as number one.
  Gamma correction is precisely the wrong tool for that problem. Gamma
correction is *not* a post-processing filter to adjust brightness and
contrast. It has been extensively abused for that purpose, but it's not
what it exists for, and never has been.
  Gamma correction is used to map linear rgb values to colors which will
look on your screen equivalently linear (because your screen does *not*
show pixel values with a linear brightness). Gamma correction is not a
brightness/contrast knob for your rendered image.
Date: 15 Oct 2009 13:58:25
Message: <Xns9CA5CB2EB33B3seed7@news.povray.org>
Gentlemen,
being a trained photographer the whole gamma issu is becomming a bit of
a non issue to me, but alas
Gamma is a necessary evil. It has to be explained, so, yes a tutorial
is needed. The differences in output between 3.6 & 3.7 are of minor
importance to me. In the time since the 3.6 release I gues over 80% of
the users have switched from CRT to LCD that has no gamma at all. So an
old image will never look the same on a new monitor. The spread of
quality between LCD's I find quite big, so big a "gamma" adjustment
would be needed.
Digital imaging has progressed over time, digital camera's are commen
now. People will expect the "same" output of a renderer as from their
camera. So, I would suggest a simple setting for the user to choose
colour space, not just gamma. Most digital devise use sRGB now, so for
many platforms that would be the default. A special colour space could
be "linear" for a gamma = 1 output (it's been some time ago, but
doesn't the hf_gray setting automagically create gamma = 1 images).
For the common problem of gamma abuse in the past, for that "tone
control" or contrast control would be nice.
ingo
Date: 15 Oct 2009 14:15:00
Message: <4ad766a1@news.povray.org>
  Actually that's exactly what gamma correction data in the images is
trying to fix: To actually make the image look the same when you switch to
a different monitor technology (assuming you configure your system gamma
settings properly). That's the whole idea of gamma information.
  (Of course how well this will succeed in practice depends on a ton of
things. It requires for the OS to have a proper gamma correction setting
in its display device driver, among other things.)
  Actually a full post-processing scripting language would be nice, and
many times discussed, but ton of work to design properly.
Date: 15 Oct 2009 15:40:57
Message: <4ad77ac9@news.povray.org>
> would be needed.
While it is true that technically an LCD /panel/ has no gamma worth
mentioning, LCD /displays/ usually do include some gamma curve using a
look-up table - for the sole purpose of being compatible with CRTs in
this respect.
High-end LCDs for multimedia production may be yet a different story,
but the average PC user is likely to have either a low-end LCD, or a
high-end LCD for gaming purposes.
I think going for full-fledged colour management would be pretty
far-fetched ATM - even if output would be limited to two hard-coded
color profiles (e.g. sRGB, as well as a linear color space using the
sRGB primaries and white point) - as it would appear to carry an
implicit promise that...
- the colors with which POV-Ray is operating internally would be
precisely defined with respect to wavelength-dependent effects (which is
not the case at present)
- POV-Ray would do full-fledged colour management for input files as
well (which it doesn't, and due to complexity and lack of manpower is
unlikely to do in the near future)
What does seem feasible at present would be to provide an option to use
the /gamma function/ defined in the sRGB standard (and even make it the
default) instead of a classic constant-gamma power law encoding.
Date: 17 Oct 2009 19:17:53
Message: <4ada50a1@news.povray.org>
> every single time a new beta comes out because the old ini files get
> replaced with the new ones every time) just to get the behaviour that one
> would expect for a run-of-the-mill PC?
Because it's a beta, maybe?
If you don't want to futz around with that kind of things, use a final
release version.
Date: 3 Nov 2009 21:40:01
Message: <web.4af0e8efe70cefa24726e92b0@news.povray.org>
Okay, I see I've stumbled onto this discussion a couple months late, but only
because of the linear 1.0 gamma issues I *thought* I was having recently. So I
started searching the groups for gamma topics and here it is.
Anyway, I've been reading for hours online about the gamma issue and I now
realize the problems I've been seeing are related to my new 26 in. LCD monitor
and video card, not POV-Ray 3.7 per-se (and since I only recently actually
started using the beta consistently, it was just bad synchronicity). I finally
located the gamma correction utility in my NVidea control panel and got that
sorted (doh!).
Now my only real issue is with gamma pre-correction on my image map files (so
v3.7's linear 1.0 rendering and post file_gamma correction don't wash out my
image maps). I'd like to be able to simply tell POV-Ray to gamma pre-correct my
input images as needed by using some simple math, say 1.0 divided by display
gamma, something like:
image_map { jpeg "myfile" pre_gamma 1/2.2 }
Then when using any PNGs with embedded gamma I could skip that (or just use
pre_gamma 1)
Is that anything like what's planned/coming in the future?
(And thanks for bearing with me on this gamma issue everyone - I needed to
educate myself a bit on this topic - never really considered it much until very
recently)
-Rob
Date: 3 Nov 2009 22:45:18
Message: <4af0f8ce$1@news.povray.org>
> pre_gamma 1)
Yes, definitely. As a matter of fact, a corresponding patch has been
implemented already, and I expect it to feature in the next beta.
The syntax will differ in some details of course; for instance, the
keyword is likely to be "file_gamma" and the parameter value will
actually be the inverse of your proposal; it will also be conceptually
an override, not an additional adjustment, which will make a difference
for PNG files; e.g. if a PNG file is encoded pre-corrected for a display
gamma of 2.2, and "file_gamma 2.2" is specified, POV-Ray will still
apply a total gamma adjustment of x^2.2, not x^(2.2*2.2).
> recently)
I guess you're not the only one. I didn't wrap my head around it in a
single day either.
Date: 4 Nov 2009 15:45:00
Message: <web.4af1e75ee70cefa25b4449250@news.povray.org>
> [a number of interesting things]
I have to say: If the value of a message is measured by the amount of thinking
it inspires, then this was one of the most valuable messages I've seen on the
Internet in a while. After quite a bit of pondering, this is the most coherent
answer I can come up with.
Let me start here:
>gray.
I think these two paragraphs sum up a bit of a conflict: is gamma about the
input or the output? If you say that it specifies how I want a pixel to appear
on the screen, then it sure looks like it is a post-processing step after the
color of the pixel has already been computed in the linear rgb space. An
afterthought, if you will, to take care of the different output devices this
pixel might be displayed on. Which is in conflict with the claim that it is
about input conversion.
At this point, it might actually be nice to have a clear "mission statement"
that actually tells us what purpose all the futzing with gamma in POV is
actually supposed to have. Input? Output? Both? Some high-level declaration
against which we can measure any one change that is occuring: "does *this*
change really serve *that* purpose?"
But the real beef, the part that really made me think, was this innocent little
question:
I had never really thought much about it, but I actually think *about POV-Ray*
in two different (sometimes incompatible) ways.
On the one side, I think of it in terms of physics. Photons interacting with
surfaces, watts per square meter per steradian emitted in certain given spectral
bands and then absorbed somewhere else. Diffraction, illumination, scattering.
All the wonderful bits of math involved. Conservation of energy. That kind of
thing.
From this perspective, your question up there doesn't make much sense: a
specification of "rgb 0.5" in my scene file is about the reality of a given
object, namely that it emits half as many watts per area into some solid angle
(given by things like specularity) as it received. This specification is
completely unrelated to any kind of output device - an object specified as "50%
grey" can appear on any one monitor as any one color, depending on the
illumination of that surface by light sources and other surfaces and by the
angle to and distance from the camera.
Heck, even if there is no camera at all. The object is still specified as "50%
grey" and that is still a property of the object and this "50% grey"-ness
influences how it reflects light onto other things even if the camera points in
the opposite direction. Whether this object is ever taken into account in the
creation of any one image depends on its geometric relationship with its
environment and the direction in which any one camera might be pointed. And if
it is in view in any one image, then it can appear on my screen as anything from
pitch black to pure white and anything in between, depending on the actual
illumination conditions.
The other perspective I have on POV-Ray is about art. A tool to make pretty
images. Here I care about composition, lighting, shapes, structure, texture etc.
The physical background goes away entirely.
I might look at a scene and say: "That thing there looks too dark compared to
what I am trying to achieve. I'd like to make it a little lighter". In this
context, I could not care less what *number* there is attached to any one
specification - like the "rgb ..." value in some pigment. If I want it lighter,
I might increase it. Until it looks right. Or do something completely different
like increase "ambient" or such.
What I am concerned about there is the actual pixels on my screen, the image
that is being created - and all the vectors and color specs and whatnot become
mere utilities to that end. I want a grey that "looks a little lighter than that
and a shade colder" and from an artistic perspective I know I can make it a
little colder by making it a little bluer which I can achieve by raising the
blue component in my "ambient" statement and voila: I have changed the
appearance of an object even though its pigment is still specified as "rgb 0.5".
Or maybe "rgb 0.1" or "rgb 5.7". Or whatever I may have tinkered with to make
something *look* right.
From this perspective your question doesn't make much sense either - if I want
50% grey then there's a million buttons to turn and very rarely will there
happen to be a number "0.5" in there somewhere. Maybe the object is specified as
"0.7" and with a negative ambient illumination or something weird like that -
because it served some artistic purpose elsewhere.
All this said, here's my take on your question:
If I specify "50% gray" in a scene file and there happens to be a pixel on my
screen that happens to come out 50% gray, then this would be mere coincidence.
It's not that I "want" it to come out differently, but it sure isn't like I
"wanted" it to come out this way either. From a physics perspective the "50%
grey" in the input is the reality and the resulting image (if any) is just
incidental to that reality and carries the properties of my camera and my light
sources in it - and from an arts perspective the image is all there is to it and
whether any of the numbers that entered into making the image happens to be
"0.5" or "128" or or "#808080" or "374629.4432" makes no difference to the end
result.
All that said - my preferred way of looking at POV-Ray is from an arts
perspective. I'm a physicist and if I have a situation where I really care about
the reality of the light propagation I'll run Zemax or Code-V; POV-Ray doesn't
cut it there. It's a toy, in the end.
And from an arts perspective, the recent betas of 3.7 have produced results that
looked like foot. But looked a lot better if I take them individually into a
paint program after the fact - and reduce gamma by about ~50%.
Am I the only one who looks at things this way? Who is the target audience here,
really? And what do they want and think? I am honestly curious.
Date: 4 Nov 2009 17:39:20
Message: <4af20298@news.povray.org>
> >gray.
  It's related to mapping input values to output values. Input values are
abstract, for example "50% gray", while output values are concrete pixel
values which will show up on your screen. What the gamma value does is to
tell the hardware how to convert the input values so that they will show
up on screen correctly. This is needed because different hardwares have
different mappings between input and output.
  Most programs don't care about this mapping and skip gamma correction
altogether. In these programs if you specify, for example "50% gray", what
you will get is a pixel with color components which are exactly in the
middle of the color component range (eg. on a 24 bits-per-pixel display
it will result in a pixel with values 127,127,127). That will not produce
a 50% gray with most monitors. However, people are so used to this that
they don't even notice that the mapping is incorrect.
  POV-Ray 3.6 is, basically, such a program. POV-Ray 3.7 wants to change
that and abstract the meaning of color definitions so that "rgb 0.5" really
means "50% gray" and not "whatever your monitor will show when you use a
pixel value of 127,127,127". A proper gamma setting is the tool for that.
  "Post-processing" is a change done to the pixel after it has been rendered
and before it's written to the image file (or previewed on screen). Gamma
correction goes beyond that (at least for image file formats which support
gamma information): It also writes to the file information which an image
viewing program can use to correct the pixels properly before showing them
on a different hardware with a different gamma than the computer where the
image was created. This means that in different computers, with different
gamma correction settings, what ends up being sent to the display hardware
may be different pixel values, with the goal that what you see on screen
will end up looking the same (rather than darker or lighter than in the
original computer).
> An
  It is about input conversion in the sense that the original data (eg. in
this case an SDL scene file) had for example "50% gray", and the gamma value
is used during the entire process of rendering and displaying in order to
make sure that it will look like "50% gray" on the screen as well. Without
this gamma correction it won't look like that.
  Of course lighting will affect how the color ends up on the final image.
However, gamma correction makes sure that the end result will be proper,
according to the math. For example if a 50% gray color is dimmed by lighting
by half, then you want a 25% gray to show up on screen, not something else.
And gamma correction is the tool for that. Without gamma correction you won't
get 25% gray.
  Wouldn't you want for the image to look the same in someone else's computer
as it does in yours?
  Improper (or lack of) gamma correction will not only change the brightness
of the colors, but also their hue (because if different color components have
different values, they will be affected non-linearly by the display hardware;
this means that a pixel value of eg. 192,128,64 will have a slightly different
hue with different display hardwares).
  So gamma correction *does* make a difference even from an artistic point
of view.
