POV-Ray : Newsgroups : povray.beta-test : Iridescense Bug Server Time
25 Apr 2026 23:53:07 EDT (-0400)
  Iridescense Bug (Message 1 to 9 of 9)
Subject: Iridescense Bug
Date: 8 Aug 2009 14:50:25
Message: <4a7dc8f1$1@news.povray.org>
If one has a closer look at Iridescence, the results are devastating.
Take the scene below, for instance:
- We have two spheres, one with "irid" and one without.
- The non-iridescent sphere is set to be 100% white, the brightest you
can realistically have. The iridescent one is set to pitch black except
for the iridescence contribution.
- We have two very dim light sources, one of which is a spotlight with
smooth falloff.
What's wrong?
- The iridescent sphere is brighter than the white one!
- The iridescence effect breaks the smooth spotlight.
If you toy around more with lighting, you'll notice that the iridescence
effect perfectly ignores how bright the light of any particular source
is - as long as it isn't zero.
What else?
- Try setting the "thickness" value to something extremely low;
theoretically, this should kill off any interference at visible
wavelengths; yet the iridescence effect adds some plain grey.
- If you toy around with camera perspective, you may notice that it has
no influence on the iridescence effect; theoretically, it should be
influenced by both the light source *and* observer position.
To make a long story short: Iridescence is badly broken (and has always
been, by the way). I suggest to give it a major overhaul - even at the
cost of breaking compatibility with 3.6.
   location  <0.0, 0.5, -4.0>
   direction 1.5*z
   look_at   <0,0,0>
light_source { <0,30,-30> color rgb 0.2
   spotlight point_at 0.0 radius 0.5 falloff 1.0
light_source { <-30,30,-30> color rgb 0.1 }
default {
   finish { ambient 0 diffuse 1 specular 0 }
plane { y, -1
   pigment { checker color rgb 1 color rgb 0.5 rotate y*30 }
sphere { -x, 1
   pigment { color rgb 1 }
sphere { x, 1
   pigment { color rgb 0 }
   finish { irid { 0.5 thickness 1 turbulence 0.5 } }
Subject: Re: Iridescense Bug
Date: 9 Aug 2009 11:35:13
Message: <4a7eecb1$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4a7dc8f1$1@news.povray.org...
That last should not be a problem imo. Good spotting by the way.
Date: 9 Aug 2009 11:52:49
Message: <4a7ef0d1$1@news.povray.org>
I actually stumbled across it while examining the code, to get a better
understanding of the various functions involved in illumination.
Date: 9 Aug 2009 11:57:12
Message: <4a7ef1d8@news.povray.org>
  Especially since iridescence seems to be one of the features seldom used
by anybody, for some reason.
Date: 10 Aug 2009 00:20:00
Message: <web.4a7f9ef56edb0afeff536cf30@news.povray.org>
Probably because it's a royal pain in the neck to tune properly, and rarely
looks "right". :-)
Really, between iridescence, dispersion, and photons, an alternate color system
- basically, "give us the spectrum" rather than "give us the effective color" -
seems like it's almost a necessity.  (Probably wouldn't hurt the whole
subsurface system either.)
That's just asking for potentially ugly code, though, and is more the realm of
4.0 than 3.7 anyway...
Date: 11 Aug 2009 13:16:11
Message: <4a81a75b$1@news.povray.org>
Some reasons:
  - hard to set up
  - seldom gives correct results
  - very small parameter changes can result in extreeme and unexpected
changes
  - large parameter changes may not change the end result at all
  - it often goes from not to almost not visible effect to overwhelming
In one of my dablings, adding "turbulence 0.01" resulted in a totaly
white surface.
Date: 21 Aug 2009 20:27:48
Message: <4a8f3b84$1@news.povray.org>
Sample showing the problem when you use irid with turbulence.
With no turbulence, the two halves of the top part are identical.
They react to the positions of the two light_source.
With any amount of turbulence, the left part becomes extremely different.
It NO LONGER react to the direction of the incoming light. The perturbed
pattern continue from area lighted by the two lights to areas
illuminated by only one with only a difference in brightness. You cam
move the lights any way you want, the perturbed irid pattern won't change.
Very small turbulence values result in a totaly washed out effect with
no iridescence at all. Try "turbulence 0.01" or less.
union{
	union{
		box{<0,100,0><100,0,1>}
		sphere{<3,3,0>2}
		finish{irid{ 0.5 thickness 0.1}}}
	union{
		box{<0,100,0><-100,0,1>}
		sphere{<-3,3,0>2}
		finish{irid{ 0.5 thickness 0.1 	turbulence clock}}}
	union{
		box{<-100,0,0><100,-100,1>}
		sphere{<0,-3,0>2}
	pigment{rgb 0.25}
camera{location -15*z look_at 0 direction z up y right x}
light_source{<0,60,-50> rgb 0.4
//rotate 360*z*clock
light_source{<60,0,-50> rgb 0.4 spotlight point_at 0 radius 0 falloff 5
Date: 22 Aug 2009 00:05:47
Message: <4a8f6e9b$1@news.povray.org>
I didn't even see /that/ problem yet, but yes, that part is bogus, too:
The code is written in such a way that when turbulence is used...
(a) the effective turbulence "strength" is always 1.0
(b) the value specified with the "turbulence" keyword instead multiplies
the thickness parameter
I guess that (a) causes the (apparent) angle-independence of the effect,
as the film thickness varies too much to see any influence of the light
direction, while (b) causes small turbulence values to kill the whole
iridescence effect (with the wrong side effect of greying out the whole
color).
Man, that code is probably the crappiest part in all of POV-Ray.
Date: 22 Aug 2009 18:16:09
Message: <4a906e29$1@news.povray.org>
> color).
I can agree with you. That peice of code is rotten to the core.
I think that this is a cese where you must recode the whole thing
without regard to backware compatibility with older scenes.
Older scenes that do use the feature will probably benefit from the change.
