POV-Ray : Newsgroups : povray.beta-test : problems linking to boost libraries (linux) Server Time
17 Mar 2026 07:43:10 EDT (-0400)
  problems linking to boost libraries (linux) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: problems linking to boost libraries (linux)
Date: 8 Mar 2009 15:40:43
Message: <slrn.gr87pr.6hv.steev@hot.pl>
Klik-klik-klik... To CShake pisze :
> Now it is throwing errors on zlib,
> "checking whether to use the ZLIB library... yes
> checking for library containing zlibVersion... -lz
> checking zlib.h usability... yes
> checking zlib.h presence... yes
> checking for zlib.h... yes
> checking for libz version >= 1.2.1... unknown
Is zlib-devel installed?
  ________
 \__ \__ \_______________________________________________________________
Date: 9 Mar 2009 16:33:13
Message: <49b57d09$1@news.povray.org>
> configure: error: cannot find a suitable ZLIB library"
	In fact this might not be a problem with zlib, but something else
in the compiler command-line might prevent liking the test binary that checks
for the libz version.
	In other words, you must check the config.log file to see the actual
error; search for "libz version" (without quotes) to jump slightly above
the error message.
	- NC
Date: 9 Mar 2009 18:42:05
Message: <49b59b3d@news.povray.org>
On Mon, 02 Mar 2009 11:19:39 -0500, CShake wrote:
> I know I have zlib 1.2.3 installed, and I tried
> '--with-zlib=/usr/include/' (where zlib.h is) and --with-zlib=/var/lib/'
> (where libz.so is), neither of which work.
While it looks like you do, can you confirm that you have the zlib devel
package installed as well?
Jim
Date: 10 Mar 2009 16:10:31
Message: <49b6c937@news.povray.org>
> checks
> the error message.
>     - NC
You are correct, after digging in config.log I see that it is once again
a boost problem:
configure:8561: checking for libz version >= 1.2.1
configure:8593: g++ -o conftest  -pthread -I/usr/lib/../include
-pthread -I/usr/local/include/boost-1_38 -L/usr/lib  -L/usr/local/lib
conftest.cpp -lz -lrt -lm -lboost_thread-gcc43-mt  -pthread  >&5
configure:8596: $? = 0
configure:8602: ./conftest
./conftest: error while loading shared libraries:
libboost_thread-gcc43-mt-1_38.so.1.38.0: cannot open shared object file:
No such file or directory
This error confuses me as well, because
/usr/local/lib/libboost_thread-gcc43-mt-1_38.so.1.38.0 exists, with
permissions -rwxr-xr-x u:root g:root, so it shouldn't have trouble
reading the .so
cshake
Date: 10 Mar 2009 16:22:26
Message: <49b6cc02@news.povray.org>
>> checks
>> the error message.
>>     - NC
> a boost problem:
> configure:8593: g++ -o conftest  -pthread -I/usr/lib/../include -pthread
> reading the .so
> cshake
Well, just downloaded the b31 source and tried again, this time with it
dying at 'checking if boost thread library is usable', but with the same
reasons.
config.log shows the same errors. I'm confused why the switch
'-I/usr/local/include/boost-1_38' exists, since my calling line is
'$ ./configure COMPILED_BY=cshake <cshake+pov### [at] gmailcom>
--with-boost=/usr/local --with-boost-thread=boost_thread-gcc43-mt',
nowhere do I say that boost is within the 'boost-1_38' subdir, because
it isn't. Do I need to create that subdirectory with symbolic links in
it, or edit the configure script to not add the extra path?
Date: 10 Mar 2009 18:08:03
Message: <49b6e4c3$1@news.povray.org>
	So linking is successful since the boost thread lib is indeed found
under /usr/local/lib.
	Now this is the sign that something is wrong at runtime, i.e. as if
/usr/local/lib is not set in the default search path for the runtime linker.
You may check with ldconfig whether this is the case.  For testing before
having to modify your system setup, you may try using LD_LIBRARY_PATH
(e.g. export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH) before running
configure and (hopefully) the povray binary.
	- NC
Date: 10 Mar 2009 18:14:37
Message: <49b6e64d$1@news.povray.org>
	This path was guessed by configure as a possible search path for
the boost libs after failing looking in "standard" directories.  It won't
harm to search a non-existing path for include files, however that means
maybe the boost install is somewhat screwed.  What is the actual location
of the boost 1.38 headers on your system?
	- NC
Date: 10 Mar 2009 21:07:14
Message: <49b70ec2$1@news.povray.org>
>     - NC
All the .a and .so libraries are in /usr/local/lib/, and all the .hpp
headers are in /usr/local/include/boost-1_38/boost/ (and subdirectories)
Boost was installed from source without any extra configure switches,
just $ ./configure and $ sudo make install.
Date: 10 Mar 2009 21:18:51
Message: <49b7117b@news.povray.org>
OK, guess this is just due to the pov-team only officially supporting
boost 1.37 and not 1.38. I removed all the 1.38 files that were built
from source, and installed 1.37 from pacman (the ArchLinux repository
system), and it worked fine only having to change the name of the thread
library to boost_thread-mt.
Guess this whole thread can be ignored now, or maybe just as a caution
to not use 1.38.
cshake
>>> because it isn't. Do I need to create that subdirectory with symbolic
>>> links in it, or edit the configure script to not add the extra path?
>>     - NC
Date: 11 Mar 2009 07:34:20
Message: <49b7a1bc$1@news.povray.org>
> to not use 1.38.
	No, (under linux at least) 1.38 works as well as any boost version since 1.35.
	Ok, indeed this is what happens by default when installing boost from sources.
Just create a symlink then, e.g.
sudo ln -s /usr/local/include/boost-1_38/boost /usr/local/include/boost
	- NC
