POV-Ray : Newsgroups : povray.beta-test : Why is Povray 3.7 for Windows installed in such a stupid place? Server Time
28 Jul 2024 14:30:19 EDT (-0400)
  Why is Povray 3.7 for Windows installed in such a stupid place? (Message 1 to 10 of 26)
Subject: Why is Povray 3.7 for Windows installed in such a stupid place?
Date: 4 Jan 2009 11:49:17
Message: <4960e88d$1@news.povray.org>
Why is POVRay for Windows 3.7 now being installed into C:\Documents and
Settings\Username\Application Data\POV-Ray\v3.7\ ?
As I regularly build very large datasets with POV, I have always
installed my POVRay into a secondary harddrive (D:). Now it appears with
the current Beta installers I get no control over where it is installed.
I now have two competing POV directory structures!
Is this a temporary situation for the Betas or is it the future scheme
for 3.7... if so why?
Rarius
Download 'iso-8859-1' (2 KB)
Subject: Re: Why is Povray 3.7 for Windows installed in such a stupid place?
Date: 4 Jan 2009 12:35:00
Message: <web.4960f22ddc46c7bf180057960@news.povray.org>
Can't you just move it elsewhere after installed?  This is why I like zip
packages best rather than installers...
Date: 4 Jan 2009 13:05:41
Message: <4960fa75$1@news.povray.org>
Actually, that isn't quite the point. The problem is, this behavior is
annoying as hell. It obfuscates, for the average person, and I would
argue, at least initially, for me too, where the hell the files are.
And, if you are a dumb fuck like me, you assumed that XP worked like 98,
and your "documents" and "programs" would all end up where you told the
OS to put them, so didn't bother with a huge partition for the OS. I for
one simply don't have the space on C: for an endless number of idiot
applications stuffing things in those locations (and at the moment, its
just not practical for me to try to fix it, not the least because I have
drives running from C to I on the machine, and trying to mess with
partitions, even if I could find an old copy of partition magic that
could help me fix it, could, do to one of those partitions needing to
go, seriously screw up a lot of installations.
Windows behavior in this is just bone headed imho, and I can't
comprehend, given this behavior, how they ever managed to get it to run,
at all, on one of those Asus Eee PCs. Its not like those have hundreds
of gigs of space sitting around for every application in the known
universe to dump its junk into the same partition as the OS. lol
Yeah, with respect, I much prefer to have control over where things put
themselves, instead of being "told" by Windows, yet again, "You can have
anything you want, just so long as its what we decided you want!"
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 4 Jan 2009 13:19:15
Message: <4960fda3$1@news.povray.org>
Is the *code* going there?  That's extremely wrong.
If the local data is going there, like .ini files, that's where it belongs.
If the user data is going there, it should be going under "My documents" in
XP, or wherever you tell it to install.
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 4 Jan 2009 14:22:47
Message: <49610c87$1@news.povray.org>
Darren New wrote:
>> and Settings\Username\Application Data\POV-Ray\v3.7\ ?
Not wrong. Just different (see below).
> belongs.
> in XP, or wherever you tell it to install.
Choose 'install for all users'. Then it will allow you to choose an install
location.
NB this new behaviour is more or less forced on me by Vista, since when
installing for the current user only (the default unless you want to get
UAC prompts), it is required to install the entire thing into a place the
user has permission to write to. Basically the binaries and the user files
are now split and end up in two locations; I use one of the pre-defined
variables set by Windows Installer for the path of the binaries. It so
happens that the above is what it resolves to on XP.
[Yes it's a pain in the ass but unless I spend the time supporting both
pre-Vista and post-Vista install schemes (= less time to work on other
stuff) there's not a lot I can do about it.]
-- Chris
Date: 4 Jan 2009 14:23:45
Message: <49610cc1@news.povray.org>
Reading the release notes usually answers such questions.
-- Chris
Date: 4 Jan 2009 18:07:25
Message: <4961412c@news.povray.org>
If you could, there would be no need for an installer! There's surely lots
of registry settings.
Date: 4 Jan 2009 18:08:24
Message: <49614168@news.povray.org>
That's Vista's equivalent to the way you can install programs anywhere in
$HOME if you don't have root.
Date: 4 Jan 2009 19:16:14
Message: <4961514e$1@news.povray.org>
Well, OK. If it installs there for just "one user", I suppose there's not a
whole lot of good places. I didn't realize that's what you meant.
Installing things outside of "Program Files" in the general case breaks a
whole bunch of stuff, such as System Restore, all kinds of general backup
scripts, and etc. It would be as "extremely wrong" as storing the per-user
ini-config files in the /bin directory on Unix. :-)
Installing the whole executable under "Application Data" could, I suppose,
cause trouble with people who have (for example) corporate networks where
that stuff gets backed up on a regular basis or roamed or etc.
Personally, I would have put the single-person install under the "my
documents" area rather than someplace "hidden", but it's certainly not
something that Windows makes an obvious place for, yes.
Date: 4 Jan 2009 19:38:47
Message: <49615697$1@news.povray.org>
> location.
Maybe only the text is misleading, because installing just for
one user usually means that shortcuts and ini files and the such
go to the users app data and not "All Users" app data. Installing
the binaries into the user's app data is rather exceptional and
could be marked more clearly, such as
o Standard installation (requires administrator privileges)
o Private installation  (places program under user files)
Even so, I think the default should be "Standard" and require
explicit action on the part of the user to change. When ignoring
the warning about administrator privileges, UAC popups should
not come as a big surprise.
Depending on the effort it would require using your tool,
the following two modifications might be helpful:
1. If Windows version is XP or lower, skip the query and
    proceed with standard installation.
2. When doing the query, set the default selection based
    on the availability of administrator privileges.
What tool are you using to build the installer? You mentioned
Windows Installer, but I thought that is just an installer platform
nobody writes for manually. Urk ;) You may wish to have a look at
http://www.advancedinstaller.com for targetting MSI, or NSIS to
avoid MSI altogether.
BTW, note that applications can have a manifest for Vista
which specifies that starting them requires administrator
privileges (common for installers).
