POV-Ray : Newsgroups : povray.beta-test : A note on #debug output in v3.7, beta 29 Server Time
26 Apr 2026 05:47:31 EDT (-0400)
  A note on #debug output in v3.7, beta 29 (Message 1 to 10 of 15)
Subject: A note on #debug output in v3.7, beta 29
Date: 12 Dec 2008 09:18:32
Message: <494272b8@news.povray.org>
This is not a major issue, but I figured I'd bring it to attention.
In v3.7, beta 29, a scene file containing only the following statement
will not write to the message window:
#debug "My Debug Text"
Adding "\n" to the end of the statement, or adding a #debug "\n"
statement to the end of the scene file will cause the line to be written
to the message window.
It seems that a final "\n" at the end of the scene file was implied in
version 3.6, but not in the current beta.
Subject: Re: A note on #debug output in v3.7, beta 29
Date: 13 Dec 2008 05:11:36
Message: <49438a58$1@news.povray.org>
"Kyle" <no### [at] spamok> schreef in bericht news:494272b8@news.povray.org...
I experience the same in 3.6. Without "\n" the line is only written when the
next #debug is met.
Date: 15 Dec 2008 08:44:07
Message: <49465f27$1@news.povray.org>
> next #debug is met.
That's odd.  Just to be clear, when I render a file containing only the
following line in version 3.6 ...
... the text is written to the message window, right after the "Peak
memory used" message.  The text is not written to the message window in
version 3.7, beta 29.
So, you're saying that you do not see the text in the message window in
version 3.6?  What is the exact version that you are using?  Perhaps
it's different from mine.  I'm testing on version 3.6.1a.icl8.win32.
Date: 16 Dec 2008 03:09:45
Message: <49476249$1@news.povray.org>
"Kyle" <no### [at] spamok> schreef in bericht news:49465f27$1@news.povray.org...
> version 3.6?  What is the exact version that you are using?  Perhaps it's
The latest version available: 3.6.1c for Windows.
Date: 16 Dec 2008 08:33:58
Message: <4947ae46$1@news.povray.org>
> Thomas
I just installed version 3.6.1c, and the result is the same as in
version 3.6.1a, the text shows up right after the "Peak memory used"
message.
Just to reiterate, this is not the case in version 3.7, beta 29.
Date: 16 Dec 2008 10:42:46
Message: <4947cc76@news.povray.org>
"Kyle" <no### [at] spamok> schreef in bericht news:4947ae46$1@news.povray.org...
> I just installed version 3.6.1c, and the result is the same as in version
> 3.6.1a, the text shows up right after the "Peak memory used" message.
Ah! ok! I just have been blind to the "Peak memory used" note from your
post. Obviously I have been thinking of something else  :-)
The point is that I use the #debug statement quite a lot in my scenes to
check the parsing procedure or the output of some parameters during testing.
As such, I need the message to be written right away, and I had not noticed
the writing of it at thre end of the render. Sorry for the confusion.
Date: 16 Dec 2008 17:07:49
Message: <494826b5@news.povray.org>
> testing. As such, I need the message to be written right away, and I had
> not noticed the writing of it at thre end of the render. Sorry for the
> confusion.
Just make sure you print a newline at the end.
Date: 16 Dec 2008 18:47:28
Message: <C78F717E7F134FCAB39FAD0DAE442E2B@HomePC>
It should be easy enough for POV to output a final newline at the end of
all messages just to clean up things like this.
...Ben Chambers
www.pacificwebguy.com
Date: 17 Dec 2008 03:40:13
Message: <4948baed@news.povray.org>
Except that you frequently do not want automatic newlines: They prevent
assembly of longer outputs using multiple debug statements.
	Thorsten
Date: 17 Dec 2008 04:03:44
Message: <4948c070$1@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailcom> schreef in bericht
news:494826b5@news.povray.org...
>> confusion.
Yes, that is exactly what I found out. I came across the problem when I
wanted to show a message about the start and then the end of a particular
parsing block, and both written on the same line. But both messages only
appeared together at the end of the block.
