POV-Ray : Newsgroups : povray.beta-test : Beta 28 now available Server Time
26 Apr 2026 11:32:41 EDT (-0400)
  Beta 28 now available (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Beta 28 now available
Date: 3 Aug 2008 17:41:50
Message: <4896261e$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:48959c3f@news.povray.org...
> Apologies to those who attempted to install on Vista and weren't able to.
> The problem was due to the fact that despite setting the INSTALLPATH
> property to the appropriate location (under AppData), Windows Installer
> was
> still attempting to install the files into program files. This should now
> be rectified. There will still most likely be weirdness installing for all
> users under Vista - probably UAC will not trigger, blocking the install.
> This isn't really an issue since All Users isn't fully supported yet.
Good to know there was a reason other than something I was doing with Vista.
Glad you figured it out Chris.
As the others have said, UAC off was what finally made sense, which must
have been the difference between a no-go and successful install. I chose to
try this in the middle of the night (again) when I wasn't thinking clearly
to begin with.
Curious thing then that the posting by SafePit here was okay even though UAC
was on... something about Vista Basic? This was another lesson for me in
using Vista, to look at UAC first not last.
/*bob hughes*/
Subject: Re: Beta 28 not installing on my Vista user or admin
Date: 3 Aug 2008 22:20:30
Message: <4896676e@news.povray.org>
"Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com> wrote:
> Typically, Vista will notify you when an installer needs administrative
> privileges, and prompt the user, but not always. It may have something to
> do with the name of the installer; at least that is how it worked in XP.
Executables can have a "manifest" saying they need admin privileges. The
same kind of manifest used on Windows XP for an app to say it wants to be
XP-styled (by loading the newer common controls library).
Date: 4 Aug 2008 03:19:13
Message: <4896ad71@news.povray.org>
Good news, Chris!
It is time for a file conversion tool (import/export), I think. And the
radiosity should be change from alpha to regular. Well, let's see. But
POV-Ray is a masterpeice of good work!
My best wishes for the team, and lots of thanks,
Sven
Date: 4 Aug 2008 05:09:22
Message: <4896c742$1@news.povray.org>
4896261e$1@news.povray.org...
> UAC was on... something about Vista Basic? This was another lesson for me
> in using Vista, to look at UAC first not last.
It worked OK here too (Vista Home Premium) with UAC on. The only issue, as
previously reported, is that AppData is hidden by default, so users must
unhide it to be able to browse through the ini and demo scenes files.
G.
Date: 4 Aug 2008 06:39:28
Message: <4896dc60@news.povray.org>
I wasn't aware of that (hadn't noticed when testing). The installer does
however place a link to the scene files in the start menu group and IIRC on
the desktop.
It's also rather ironic if hidden is in fact the default; according to the
InstallShield documentation, one of the requirements for Vista logo
cerfification is that files installed for non-admin users go under AppData.
-- Chris
Date: 4 Aug 2008 07:20:22
Message: <4896e5f6$1@news.povray.org>
le message de news: 4896dc60@news.povray.org...
> on
> the desktop.
OK I'll have a look.
> AppData.
Apparently the question of where to install + store writeable files in Vista
does not have an easy answer.
http://lists.runrev.com/pipermail/use-revolution/2007-February/094217.html
Also it looks like InstallShield doesn't have a variable for
CSIDL_COMMON_DOCUMENTS so workarounds are needed.
http://community.installshield.com/showthread.php?t=159616 (see last
message)
http://community.installshield.com/showthread.php?t=181423
G.
Date: 4 Aug 2008 08:13:26
Message: <op.ufc2wnmv7bxctx@e6600>
On Mon, 04 Aug 2008 12:39:26 +0200, Chris Cason
> the
> AppData.
"Application Data" is where you store configuration files and such. Files
that users work on directly go under "My Documents" or "Shared Documents".
FE
Date: 4 Aug 2008 08:50:30
Message: <4896fb16$1@news.povray.org>
"Gilles Tran" <gil### [at] agroparistechfr> wrote in message
news:4896e5f6$1@news.povray.org...
> dans le message de news: 4896dc60@news.povray.org...
>> on
>> the desktop.
I was overlooking the scene file shortcut at first because I don't show
icons in order to better see the background image wallpaper (a pov
rendering). My most-used programs are on Quick Launch, or last used list of
the Start Menu.
I know now the shortcut will provide access to those files outside of POV,
despite them not showing in Computer or user file lists.
>> the
>> AppData.
> Vista does not have an easy answer.
> message)
Helping me by reading more... found a web page describing path changes from
older Windows to Vista:
http://www.svrops.com/svrops/articles/jpoints.htm
When I read what I could find about AppData\Roaming things began making less
sense. ;)
Just saw what Fredrik Eriksson said and the Users\Public location comes to
mind, but that's after the short reading I was doing before. I'm sure
something will work out, I have faith.
/*bob hughes*/
Date: 4 Aug 2008 17:38:10
Message: <489776c2@news.povray.org>
> AppData.
Files local to a specific user account. That doesn't necessarily mean "files
the user will want to see or tinker with".
Date: 7 Aug 2008 07:51:31
Message: <489ae1c3@news.povray.org>
> message)
Thanks for that; it's an interesting read. Glad to know I'm not the only
one scratching their head.
I did think of installing the scene files etc into 'My Documents' (and its
equivalent on Vista*). But - perhaps I am too pedantic - I have always
disliked 'My Documents' and don't even tend to use it on my own machine. I
simply find the name Microsoft gave it as quite condescending. I realise
this is not a good technical reason to avoid using it in an installer and I
might very well end up doing this; I guess it's just habit that I avoid it:)
If I do move the files I will probably move them all from AppData. While
there are some files in AppData that don't need to be in My Documents (e.g.
the Insert Menu, which already has a means of being opened from the program
directly), I really don't want to have three separate locations for POV
files (e.g. in the case of an all-users install).
-- Chris
* At least Microsoft got rid of the 'My ...' prefix in Vista.
