POV-Ray : Newsgroups : povray.beta-test : PNG output much brighter than preview... Server Time
20 Mar 2026 07:55:09 EDT (-0400)
  PNG output much brighter than preview... (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: PNG output much brighter than preview...
Date: 14 Jan 2007 18:40:54
Message: <45aabf86$1@news.povray.org>
I should have remembered the assumed_gamma issue before posting this... but
on the other hand, why does this only cause a problem for the PNG output but
not the BMP or TGA? And why does the render window look OK while the file
doesn't?
Personally I've never understood the need for Gamma adjustment within
POVRay... I'd second any motion for ripping it out!
Rarius
news:45aab39c@news.povray.org...
>  Gamma, gamma, gamma... Each time I read something about gamma, it's
> a problem with it. It seems to me that gamma only causes problems and
> doesn't actually solve any. There are tons and tons of graphical
> software out there which do just *fine* without any gamma at all to
> worry about.
>  How about if we dropped everything related to gamma from povray?
> Who needs it anyways? It just fumbles things up and makes people
> struggle because they can't get what they want.
>  What is the most common thing people use assumed_gamma for in
> povray 3.6? Trying to get rid of it! That's what.
>  Ok, I apologize for the ranting.
>                                                          - Warp
Date: 15 Jan 2007 03:02:24
Message: <45ab3510$1@news.povray.org>
"Rarius" <rar### [at] rariuscouk> schreef in bericht
news:45aabf86$1@news.povray.org...
>but not the BMP or TGA? And why does the render window look OK while the
>file doesn't?
I agree with both of you :-)
I have/had the same problem with the png output, but only when looking at it
in WinEx. In any other paint program it looks alright. What seems to solve
that, is to open it in a paint program (PSP for instance) and just
save/overwrite it.
I have not experimented with bmp or tga, though.
Thoma
Date: 15 Jan 2007 04:40:00
Message: <web.45ab4b918a3ae007f1cb1e660@news.povray.org>
> doesn't?
> Rarius
> > worry about.
> >                                                          - Warp
trouble than it is worth
Date: 15 Jan 2007 05:05:36
Message: <45ab51f0@news.povray.org>
> worry about.
Why? It works, it is just that people need to read the release notes stating
how to use it in 3.7 to get 3.6 results and also complain to those programs
that do not support PNG properly. The reason you hear complains it because
(surprise), M$ has, I would guess intentionally, never supported PNG
properly. But as M$ dominates the market, those not understanding how M$
handles standards it dislikes fall for the trap and blame POV-Ray. Of
course, the question then arises why the same people insist on using PNG in
the first place - my motto in this regard is: Either know what you are
doing, or don't do it :-(
In short, there is no problem at all. POV-Ray functions properly, and the
feature is trivial to turn off by reading the documentation as well.
	Thorsten
Date: 15 Jan 2007 05:57:55
Message: <45ab5e32@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
> Why?
  I will respond to that question with another question: Can you tell me
any reason why people using povray would want gamma information to be
stored in the png file (especially considering that it's *not* stored
in any other image format supported by povray)?
  By far the most common situation is that people using povray expect
exact pixel color values which correspond to the color vectors they
have used in the scene. For example, if someone makes an object of
color <.5, .5, .5> and removes all lighting/shading effects (usually
by specifying "ambient 1"), they expect to get an image where the
pixel values (assuming 8-bit color channels) are 128, 128, 128, or
perhaps 127, 127, 127, but nothing else.
  When instead they get something like 135, 135, 135, they get confused
because they are not getting what they expect nor want. If they, for
whatever reason, relied on povray giving them exactly half-bright
pixels, getting 135*3 is useless to them.
  Another issue is that getting *different* pixel results when rendering
to png as compared to rendering to another image format is going to only
cause even more confusion. Shouldn't povray give consistent results
regardless of the image format used?
  Gamma information exists in OSes so that images will look approximately
the same as in other systems. However, this is an issue if image viewer
programs (and to some extent image editors). In other words, an image
viewer gets an image with "raw" pixels, and then it gamma-corrects them
to look good on the specific platform. In other words, this correction
is a duty of the viewer program (or the OS itself).
  Povray, however, *creates* the image file. It's not an image viewer.
Putting gamma correction in povray is putting it in the wrong end of
the pipeline. The gamma correction should be at the end of the pipeline
(the viewer program), not the beginning (the program that creates the
image, in this case povray). Using gamma correction in *both* ends will
only cause an incorrect result.
  In the past (at least with pov3.5) people have abused povray's gamma
correction for something completely different than what it was really
intended for: They have used it as a kind of post-process filter to
alter the brightness of the resulting image. This is obviously the
completely wrong usage, and if post-processing of individual pixels
(for example to brighten them) is desired, there should exist a tool
in povray specialized to do exactly that. Using gamma correction as
a hack for this is not the correct way.
  If this was done, the need for gamma correction actually completely
disappears. Why would anyone need gamma correction in povray anymore?
As I already wrote, gamma correction is a duty of the viewer program
(or the OS), not the program which creates the raw image.
Date: 15 Jan 2007 06:58:11
Message: <45ab6c53$1@news.povray.org>
Yes, exactly! And if you refer back to the original post you will see
exactly that problem taking place - POV-Ray is a viewer of images! It shows
you the preview, and the original poster complained that his viewer program
does not handle gamma correctly. POV-Ray as viewer does. Now it writes the
image correctly, with the information needed to recreate exactly its
preview. But the outside viewer program ignores what POV-Ray included in the
image.
Yes, because one could manipulate "gamma" from within the scene. This was
the actual flaw. Gamma is something you set *once* for your system and then
forget about. Assuming all programs you use support it, everything will be
fine. That is why in 3.7 gamma changing from within the scene is deprecated,
and will be no longer possible in whatever release comes after it. Setting
in once in povray.ini/.rc will do.
	Thorsten
Date: 15 Jan 2007 09:25:01
Message: <web.45ab8e418a3ae007c150d4c10@news.povray.org>
> doesn't?
Because PNG stores a gamma setting and certain viewers use it.  I usually
render in PNG and convert to JPG.  When I open the PNG in the basic Windows
Picture and Fax Viewer or Picasa, it is bright (ie uses the internal gamma
setting), but in Microsoft Photo Editor, it isn't (doesn't use the
setting).  I would suspect that the POV preview displays without the gamma.
 And remember, there are 2 gamma settings, Display_gamma in the ini and
assumed_gamma in the scene file.
Personally, I can never get it to work right (or at least the way I want it
to work)
-tgq
Date: 15 Jan 2007 09:39:00
Message: <45ab9204@news.povray.org>
> image.
  Then why do all other image formats look the same with the viewer
programs as how povray shows them? Why is PNG the only format that
makes a difference? Why can't povray create the PNG in the same way
as it creates the other, non-problematic image formats (IOW. without
gamma info stored in it)?
  Why does the PNG need the gamma info? The other formats don't, and
they work just ok. PNG is the only one which presents problems when
the gamma info *is* included. How about not including it at all?
Date: 15 Jan 2007 11:40:57
Message: <45abae99$1@news.povray.org>
For TIFF it is a missing feature (in POV-Ray) that gamma settings are not
written to file. The other formats are just so old they don't support it.
	Thorsten
Date: 15 Jan 2007 13:09:24
Message: <45abc354@news.povray.org>
After reading a fair bit about gamma on the web during the years I think
I have a good grasp of it and can answer some questions.
First answering Warp:
If you create an image in windows (gamma 2.2) and save it as JPEG and
PNG and send whose to your friend who owns a mac (gamma 1.8) the JPEG
will look wrong while the PNG will look exactly as you intended (thanks
to the stored gamma info). This assumes that both systems use programs
that use gamma information as they should and that both system are
configured correctly.
More general discussion about gamma:
Gamma is a way to compensate for the non-linearity of the monitor (due
to the properties of the phosphor and electron gun). To get black you
output the value 0.0 (0) and to get white you output 1.0 (255), so far
so good. But to get something which look like 50% gray you don't output
0.5 (128), you output 0.73 (187) which is 0.5^(1/2.2), that is the gamma
correction. The non-linear transfer function of the monitor is
  brightness = value ^ 2.2
and that takes the value 0.73 back to 50% gray as expected.
The above paragraph assumes gamma 2.2.
To make the whole thing more complicated, calculations on color values
(such as ray-tracing, filtering, image transformation with
anti-aliasing) should be done in linear color space (gamma 1.0) or
errors such as hue shifts will occur. That is why povray uses gamma 1.0
in all calculation and does the correction when it saves the image to a
file (or rather, I hope that's what 3.7 does, I does right?).
To see why calculations should be done in gamma 1.0 consider the task of
averaging two pixels, one black and one white, in a gamma 2.2 color space:
  (0.0 + 1.0) / 2 = 0.5
If you just send this to the monitor you get a pixel that looks 22% gray
(0.5^2.2) and not 50% gray as you would expect. If the pixels are
colored it gets even worse, say one medium red (50% red) and one yellow
(100% red and green):
  50% red in gamma 2.2 is 0.73
  red:   (0.73 + 1.0) / 2 = 0.86
  green: (0.0 + 1.0) / 2 = 0.5
  blue:  (0.0 + 0.0) / 2 = 0.0
If you send that to the monitor it will look like 73% red, 22% green, 0%
blue. The expected values are 75% red, 50% green, 0% blue. The gamma 2.2
calculation yields a too dark color with a hue that is too much red.
In short:
For correctly configured systems, do calculation in gamma 1.0 and save
with any gamma in a file format that store the gamma (such as PNG). This
will always look as intended as long as the viewing program uses the
gamma information (this is how it should be in a perfect world).
For systems that may have programs that don't do gamma right, do
calculation in gamma 1.0 and save with the gamma of your target audience
in a format that *don't* store gamma. This will look right only if the
user viewing the image has a system with the gamma you used else it will
look wrong.
I hope this was understandable and that it answered a few question
people have about gamma.
Daniel Nilsson
