![](/i/fill.gif) |
Just FYI, this scene:
#version 3.6;
background { colour rgb 0.5 }
camera
location <0.0, 2.0, -5.0>
look_at <0.0, 0.0, 0.0>
plane
y, -1
pigment { checker color rgb 1 color rgb 0 scale <1000, 1, 1> }
finish { ambient 0.75 }
will render differently in 3.7 vs 3.6, however I don't consider this to be a
bug (at least not in 3.7). You may come across this issue with other patterns
in real scenes if they are scaled severely (like the above).
-- Chris
![](/i/fill.gif) |
![](/i/fill.gif) |
"Slime" <fak### [at] email address> wrote in message
news:43f976fd$1@news.povray.org...
> I assume this is related to the fact that the checker/cells patterns were
> internally translated by -.001 or something like that to avoid ugliness
> issues on unit-aligned planar surfaces. Out of curiosity, how was this
> changed without bring the problem back?
I wasn't sure what this was about until reading your reply, almost wrote
here earlier to ask why Chris thought this was a potential problem but
thought I would wait and see if I figured it out, so am glad I did-- well,
you did for me.
Now I've tried this using plane, box and disc with either checker or
gradient x to see how each is affected. You might want to take a look at the
script below.
The disc is still affected by the gradient pattern being at 0, although I
think you and others already knew that. I have a vague memory of this being
discussed even during the 3.7 betas, just not absolutely sure it was.
Hmmmmm... was it that some object surfaces are now being moved in lieu of
patterns and some not? Must be something I didn't retain in my personal POV
knowledge base (in-brain, that is). ;)
The box is a curiosity to me because it isn't the x direction being affected
by the scaling, it's the -z side seen changing instead. Maybe this is of
some importance anyhow.
/* BEGIN */
#version 3.6;
// use checker pattern, or use gradient x
#declare Check = yes;
// scale pattern along x by 1000, or not
#declare Scale = yes;
camera
location <2.0, 2.0, -5.0>
plane // semitransparent so disc can be seen below
y,0
#if (Check=yes)
checker color rgb 1 transmit 2/3 color rgb 0 transmit 2/3
#else
gradient x color_map {[0 color rgb 1 transmit 2/3][1 color rgb 0
transmit 2/3]}
#if (Scale=yes)
scale <1000, 1, 1>
box
<-1,0,-1>,<0,2,1> // left side aligns with plane's pattern when scaled
#if (Check=yes)
#else
gradient x color_map {[0 color rgb 1][1 color rgb 0]}
#if (Scale=yes)
scale <1000, 1, 1>
disc
<0,-1,0>,<1,0,0>,1
#if (Check=yes)
#else // gradient causes surface alignment artifacts
#if (Scale=yes)
scale <1000, 1, 1>
/* END */
![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, in-brain "databases". Of course, these lack several features of a
true database: concurrent multi-user access, automated crash recovery,
data integrity assurance, and limited capacity.
![](/i/fill.gif) |
