POV-Ray : Newsgroups : povray.beta-test : [includes] VPow does not work Server Time
11 Oct 2025 21:34:48 EDT (-0400)
  [includes] VPow does not work (Message 1 to 10 of 11)
Subject: [includes] VPow does not work
Date: 13 Jun 2002 16:36:53
Message: <3d090265@news.povray.org>
VPow in math.inc does not work, because pow only works with floats.
POV 3.5 RC6
Simon
Subject: Re: [includes] VPow does not work
Date: 15 Jun 2002 08:15:54
Message: <3d0b2ffa@news.povray.org>
I presume it should work correct if it is changed to be like this below?
// Raises the components of a vector to a given power
#macro VPow(V, P) <pow(V.x, P), pow(V.y, P), pow(V.z, P)> #end
#macro VPow5D(V, P) <pow(V.x, P), pow(V.y, P), pow(V.z, P),
pow(V.filter, P), pow(V.transmit, P)> #end
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated May 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 15 Jun 2002 12:16:02
Message: <3d0b6842@news.povray.org>
  I wonder if there would be some ingenious way of detecting the type of
vector given as parameter and then creating the same type of vector as
result. This way one macro would suffice.
Date: 15 Jun 2002 15:17:48
Message: <3d0b92dc@news.povray.org>
> detecting the type of vector given as parameter and
> then creating the same type of vector as result.
Yes, if it is possible to detect, I'd be interested. Especially since
there are several other macros in math.inc which also come in several
versions due to the various types of vectors.
But I don't know of such a method.
Rune
Date: 15 Jun 2002 16:14:31
Message: <3d0ba027@news.povray.org>
  I found a method. It may not be the fastest possible, but at least it works.
#macro Is5DVector(V)
  (strcmp(vstr(5, (V=V), "", 0, 0), "11111") = 0)
#declare V1 = <1,2,3>;
#declare V2 = <4,5,6,7,8>;
#if(Is5DVector(V1)) #debug "yes, " #else #debug "no, " #end
#if(Is5DVector(V2)) #debug "yes" #else #debug "no" #end
#debug "\n"
Date: 15 Jun 2002 16:19:47
Message: <3d0ba163@news.povray.org>
> it works.
That's great! Could you make it detect 2d (UV) vectors too? Of cpurse it
should then not return yes or no, but rather 2, 3 or 5.
Rune
Date: 15 Jun 2002 16:35:17
Message: <3d0ba505@news.povray.org>
  Well, you could count the amount of 1's in the string. I think that should
be the correct answer (I haven't tried what happens when you do a (V=V) with
V being a 2D vector, but I think it should return <1,1>).
  Of course that's even slower because you'll have to call substr() at least
two times. Don't know if that matters in practice (after all, the string is
very short).
  Perhaps something like:
#macro VectorSize(V)
  #local tmp = vstr(5, (V=V), "", 0, 0);
  (2 + (asc(substr(tmp,3,1))=49) + 2*(asc(substr(tmp,5,1))=49))
#declare V1 = <1,2>;
#declare V2 = <3,4,5>;
#declare V3 = <6,7,8,9,10>;
#debug concat("Size of V1: ", str(VectorSize(V1),0,0),
            "\nSize of V2: ", str(VectorSize(V2),0,0),
            "\nSize of V3: ", str(VectorSize(V3),0,0), "\n")
Date: 15 Jun 2002 16:40:17
Message: <3d0ba631@news.povray.org>
Actually it can be made to work for floats as well:
  (1 + (asc(substr(tmp,2,1))=49)+ (asc(substr(tmp,3,1))=49) +
#declare V0 = 0;
#debug concat("Size of V0: ", str(VectorSize(V0),0,0),
            "\nSize of V1: ", str(VectorSize(V1),0,0),
Date: 15 Jun 2002 16:49:42
Message: <3d0ba866$1@news.povray.org>
Why don't you add four-dimensional vectors, just to make it complete?
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Date: 15 Jun 2002 17:02:49
Message: <3d0bab78@news.povray.org>
  Yes, why not?
  (1 + (asc(substr(tmp,2,1))=49) +
       (asc(substr(tmp,4,1))=49) +
#declare V1 = 0;
#declare V2 = <1,2>;
#declare V3 = <3,4,5>;
#declare V4 = <3,4,5,6>;
#declare V5 = <6,7,8,9,10>;
            "\nSize of V4: ", str(VectorSize(V4),0,0),
            "\nSize of V5: ", str(VectorSize(V5),0,0), "\n")
