POV-Ray : Newsgroups : povray.beta-test : POV-Ray and Floating point stack overflow/underflow Server Time
13 Jun 2026 01:48:59 EDT (-0400)
  POV-Ray and Floating point stack overflow/underflow (Message 1 to 6 of 6)
Subject: POV-Ray and Floating point stack overflow/underflow
Date: 21 Mar 2002 17:11:28
Message: <3c9a5a90$1@news.povray.org>
This didn't start happening until POV-Ray 3.5 r13, I never encountered this
with r12. I have a scene with several very large intersecting isosurfaces
and sometimes when I try to render it at a high resolution with everything
in my scene turned on (like focul blur and radiosity) my computer will
either freeze or blue screen and then POV will pop up the window that the
floating point underflow/overflow occured.
What is the usual cause of this? Could it be something that I changed right
around the same time r13 came out? Or did something changed in r13 do this?
This happens with the install compile and the VC6 compile.
Thanks for any help/suggestions.
Subject: Re: POV-Ray and Floating point stack overflow/underflow
Date: 21 Mar 2002 19:07:38
Message: <09tk9uc0ja3vgbcnid6h4pp93n96fu6atf@4ax.com>
  Hi, Chris. We need a little more information, as specified at the
first message posted in this group, message i.d.
<3B94E1CF.7498B010@pacbell.net>. Also, please reduce the example scene
to the barest minimum that can still reproduce the problem. If we can't
duplicate it, we probably can't fix it. Thanks.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 21 Mar 2002 21:44:46
Message: <3c9a9a9e$1@news.povray.org>
Sorry, I'm an ignoramous.
Windows 98, Athlon 1900+, 512meg DDR.
Here's the stripped down source code (a bit long):
"Alan Kong" <ako### [at] povrayWWWSPAMCOMorg> wrote in message
news:09tk9uc0ja3vgbcnid6h4pp93n96fu6atf@4ax.com...
right
this?
> Alan
Date: 21 Mar 2002 21:49:44
Message: <3c9a9bc8$1@news.povray.org>
(sigh)
#include "woods.inc"
#include "functions.inc"
global_settings {
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.04
      count 35
      nearest_count 5
      error_bound 1.8
      recursion_limit 3
      low_error_factor 0.5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 1
      adc_bailout 0.01/2
camera{ location<30,1,0> look_at<-1,1,0> }
light_source{ <2000,2000,1000> White }
background{Grey}
// mountains
isosurface{
 function{-f_ridged_mf(x,0,z, .5, 3, 5, 1, .4, 3)+y }  max_gradient 9
contained_by{box{<1,5,1>*2,-1*2}} rotate<0,0,-25>
 pigment{Brown}  translate<0,-1,0> scale <1000,400,1000>
 translate<-1000,0,0>
light_group{
plane {<0,1,0>,400 pigment{bozo turbulence 1 color_map{[0 rgbt 1][1 rgb .5]}
scale 350 rotate<0,0,10>} hollow scale<5,1,1> /*rotate<0,0,10>*/ no_shadow}
global_lights off
fog
  fog_type 1 distance 3000 Grey
#declare S1=seed(12318);
light_group {
// ground plane
plane {<0,1,0>,-1 pigment{White} normal{bozo .3 turbulence 1}}
#declare f_mbumps = function{pigment{bumps color_map{[0 Black][1 White]}
translate<-10,0,0> scale<1,1,5> rotate<0,-48,0>
// the ground
//isosurface{ function{ (f_bumps(x/10,0,z/30)+y)*ln(-(x-20)+1)/5}
contained_by{ box{<-100,-2,-100>,<0,20,100>}} pigment{White}
translate<0,.4,0> scale<1,10,1> normal{bumps .3 scale .1}}
isosurface{
function{f_mbumps(x,0,z).gray-.5+y + f_bumps(x*300,0,z*300)*.0003
 +(((x-20)^2+(z-3)^2)<=15)*(1-((x-20)^2+(z-3)^2)/15)^2                   //
cabin
 +(((x-26.9)^2+(z+1.1)^2)<=.125)*(1-((x-26.9)^2+(z+1.1)^2)/.125)^3/5     //
post
 // this part carves out the river
 #declare i=0;
 #declare S1=seed(32);
 #declare r=rand(S1);
 #while(i<30)
+(((x-30+2*i)^2+(z+5-r*.3-i^2/20)^2)<=5)*(1-((x-30+2*i)^2+(z+5-r*.3-i^2/20)^
2)/5)^3*2
 #declare i=i+1;
} max_gradient 2.5 contained_by{box{<-100,-2,-30>,<40,1,30>}}
global_lights on
The tough thing with this is that it is very hard to get the exact duplicate
of the problem I'm having because of the nature. POV-Ray may come up with
the window I described, or I may get a blue screen or other programs may
start to crash or the computer might freeze or I may get nothing at all,
especially if I just rebooted. It's like you have to build up enough crud
before it starts to happen, which is just what a stack overflow would do,
right?
It seems to happen most often around the time of the intersection of the
mountain and the snow. Between 50%-53%. I'm rendering at 1024x768 with AA
0.3. I don't know if you get the same results by just rendering the middle
of the screen.
Sorry, this is kind of a complex problem. : |
"Chris Becker" <cmb### [at] ritedu> wrote in message
news:3c9a9a9e$1@news.povray.org...
> right
> this?
> > Alan
Date: 22 Mar 2002 18:27:09
Message: <3c9bbc13.6687114@news.povray.org>
On Thu, 21 Mar 2002 21:46:58 -0500, "Chris Becker" <cmb### [at] ritedu>
Can't confirm this in my first test render in 1024*768 A0.3 on a
PIII/1GHz, 512 MB, Win/ME, POV-Ray r13 install compile. At almost 2
hours I won't be running multiple tests.
/Erkki
Date: 22 Mar 2002 23:06:52
Message: <3c9bff5c$1@news.povray.org>
Exactly, it happens after successive renders and since the scene I've been
using that produces it is hard to render, it is hard to confirm. Right now
I'm trying to duplicate it on a seperate PII 450, Win98 256.
Sigh. I really hope there's a simpler way to confirm this or someone else
happens upon it. I'm in the middle of a scene and it's impossible to
continue since I can't render the whole thing without it freezing. The
completed scene has a large amount of texturing as well, like lots of
pigment maps, etc. Could this "aid" in getting a floating point
overflow/underflow? What exactly causes this error?
news:3c9bbc13.6687114@news.povray.org...
> /Erkki
