POV-Ray : Newsgroups : povray.beta-test : Filling in T values in splines Server Time
1 Mar 2026 12:16:07 EST (-0500)
  Filling in T values in splines (Message 31 to 39 of 39)
Subject: Re: Filling in T values in splines - update
Date: 24 Feb 2002 22:02:13
Message: <3c79a935@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
> Actually, make both the initial and
> step values user-defined...
  Why? No-one will be using them anyways.
  The optional way of specifying the exact amount of points is more than
enough to optimize the creation of the spline. I don't think any other
optimization is needed. It would just be overkill.
Date: 25 Feb 2002 03:18:13
Message: <sfsj7ugi4dca42iahro07hs53dhhs378jm@4ax.com>
On Sun, 24 Feb 2002 03:13:34 +0100, "Rune" <run### [at] mobilixnetdk>
wrote:
> My question is - is the below syntax too ugly or would it be acceptable for
> a macro included in the POV-Ray distribution?
> #declare SplineArray =
> array[7*2] {
>   0.0*y, <0,1,2>,
>        x, <1,5,0>,
>        x, <4,1,0>,
I don't like those vectors at begining. What about something like :
spline{
  cubic_spline
  SplineFrom(0)
  SplineTo(.9,array[4]{<0,1,2>,<1,5,0>,<4,1,0>,<0,2,1>})
  SplineFrom(1)
  SplineTo(2,array[3]{<0,0,1>,<6,5,4>,<4,3,2>})
ABX
Date: 25 Feb 2002 11:09:31
Message: <chrishuff-01D664.11092325022002@netplex.aussie.org>
In article <3c79a935@news.povray.org>, Warp <war### [at] tagpovrayorg>
Tell me, what is the difference between specifying the initial size and
specifying the "exact amount of points"?
And do you have any reasons not to let the user change the default step
size? Adding this ability would just take making it a separate variable
instead of hard-coding it.
Date: 25 Feb 2002 11:40:04
Message: <3c7a68e4@news.povray.org>
> size?
  I have no reason for not to let the user do that, but in my opinion no-one
will be using it anyways, so it will probably be a waste of time. (Besides
contamining the already-crowded namespace.)
  It could be that increasing the array to 10 times the previous size is
a bit of overkill. Perhaps it could be better to just double the size.
Date: 25 Feb 2002 12:07:43
Message: <3c7a6f5f@news.povray.org>
Have you read the entire thread before replying?
Please read the branch in this thread called
"Re: Filling in T values in splines - update"
and then comment to that one.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 25 Feb 2002 12:59:50
Message: <3c7a7b96@news.povray.org>
> initial size and specifying the "exact amount of points"?
You're right, in effect it's the same thing. So I don't know why you
requested it when it was already there, and I had made it pretty clear that
it was indeed possible.
> the default step size? Adding this ability would just
> take making it a separate variable instead of hard-coding it.
It's simply pointless. Either memory is an issue for a spline, or else it
isn't.
If it's not an issue you don't have to care about the step sizes.
In the few cases where memory is an issue, you must have a rough idea of how
big your spline is and then you should just set the number of points
accordingly or a little higher so you're sure there are enough available
elements.
It's just easier to tell the macro how many points your spline has rather
than telling it which approach it should take at guessing how many points
there are. There's no point in going the long way round.
Rune
Date: 25 Feb 2002 14:09:32
Message: <3c7a8bec@news.povray.org>
> I've done that before, but never finished because of
> bugs in the spline feature. Here are the (partially
> complete) macros:
Thanks! This might be helpful to me if you provided information about which
macros are used for what, what data types each macro takes as input and what
they output, which macros are meant to be called by the user and which are
called by other macros, and at least one working example for each macro
designed to be called by the user.
(That's basically information I always expect to find when I need to look at
other people's macros. Without that, it takes me unreasonable effort to
figure them out.)
Rune
Date: 25 Feb 2002 15:56:36
Message: <chrishuff-B25574.15562825022002@netplex.aussie.org>
In article <3c7a8bec@news.povray.org>,
I should have commented the thing before...
The macros starting with SPLINE_* are internal macros, not meant to be
seen by the user.
SPLINE_TYPE(Type)
Takes an integer value 0, 1, or 2, and parses linear_spline,
quadratic_spline, or cubic_spline depending on the value. It is used
together with the LINEAR_SPLINE, QUADRATIC_SPLINE, and CUBIC_SPLINE
#defines to tell the include what type of spline it is dealing with. The
spline macros use this to generate splines of a specified type.
Spline_Length(Spline, Intervals)
Computes the length of a spline by dividing it into a number of
intervals and computing the length of each interval. Assumes the spline
starts at 0 and ends at 1.
Spline_Interval_Length(Spline, StartT, EndT, Intervals)
Does the same as Spline_Length(), but finds the length of a specific
segment of the spline, defined by beginning and ending T values.
Spline_Length() isn't that necessary, you could use
"Spline_Interval_Length(Spline, 0, 1, Intervals)".
Constant_Speed_Spline(Spline, Type, Intervals, Samples)
Makes a new spline that follows the path of a given spline, but has the
T values tweaked to give constant speed. It doesn't use the actual
control points of the original, but generates several points along the
original spline. The number of spline segments for the new spline is
given with Intervals, Samples controls the number of intervals used to
determine the length of each segment.
SPLINE_FindNextT(StIdx, Array)
Used by Spline_From_Array() to find the next array entry with a defined
T value.
Spline_From_Array(Type, ConstantSpeedSamples, Array)
Creates a spline from an array of points and possibly time values. I
used a 2D array to specify time values "next to" the points, instead of
specifying them in pairs in a 1D array.
If a 1D array is given, it is interpreted as an array of points, the T
values of the resulting spline are evenly spaced.
If a 2D array is given, the first "row" (Array[N][0]) is taken as the T
values and the second (Array[N][1]) as the points, but some of the
points may be specified without T values. (If the given T for a point is
< 1, 0, 0>, the previous and next specified T values are interpolated.)
If ConstantSpeedSamples > 0, any given T values are ignored, the macro
computes them itself to get constant speed. ConstantSpeedSamples
specifies the number of samples used per segment to get the length of
that segment. Specify 0 samples to turn constant speed off and use one
of the first two methods...you can use the built-in constants "false",
"no", or "off" as well as just plain "0".
These macros never got finished...as I mentioned, I couldn't test them
properly because of bugs in the spline feature, so I never finished or
documented them. I think the constant spline method works though...
Date: 26 Feb 2002 01:19:37
Message: <3c7b28f9@news.povray.org>
> couldn't test them properly because of bugs in the
> spline feature, so I never finished or documented them.
Thanks for commenting them.
I will use these macros for inspiration but create some new ones from
scratch that work differently both for the user and internally. Where
applicable I want the macros to work like they are properties of the spline
that can be set, for example I want the constant speed option to be
specified inside the spline definition, like with the other macros I've
shown the syntax for so far. I also want to have the constant speed macro
have access to the control points specified by the user, so that even with
few samples and intervals it will at least go though the control points
specified by the user. When using linear splines, this gets crucially - a
linear spline based on "random" points from a different linear spline will
be all wrong. Instead, when linear spline is used I only want to modify the
T values.
Rune
