Warp wrote:
> * Text object problem
> (Text objects get tilted when highly scaled in one direction.
I think the "highly scaled in one direction" does not cause the problem,
but merely makes it more visible.
> This is most probably a floating point precision problem in the
> implementation of the text object code.)
Agreed.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{location<6,1.25,-6>look_at a orthographic}
andrel linnenbank <a.c### [at] amc uva nl> wrote:
:> Fixed bugs:
:> * Sphere sweep bug (job000200)
:> (discontinuous normals on inverse of sphere_sweep)
:> Reported in:
:> bug in sphere_sweep for removing parts of an object
:> http://news.povray.org/3C1A5D47.EA38F6E5@amc.uva.nl
: I am afraid this one ended up in the wrong list.
: My bugtest.pov still gives wrong results :(
This one is marked as fixed in the project jobs list and I personally
didn't really see the mentioned symptoms of the bug when I tried it.
I can double-check.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> * WinPOV problem (job000219)
> (Render window pops up when application minimised, after which the
> application doesn't open when clicked on the task bar. Might be a
Windows
> problem instead of a WinPOV problem.)
> Reported in:
> Render Window Bug
> http://news.povray.org/3bde157e@news.povray.org
> This report might be the same problem:
> Povray main window disappears during rendering
> http://news.povray.org/3c1350f4@news.povray.org
One possible solution to the first (and possibly only) bug mentioned in this
is that the render window load state has a mode of normal rather than hidden
or minimized. I am pretty sure this isn't Windows. Could someone without
an NT based OS reconfirm this by opening POVray, clicking Options->Other
Settings->Re-render Insert Menu Bitmaps, positioning the mouse over the
minimize button, then pressing Enter for "OK" and clicking the minimize
button in close sequence. Thank You.
N Shomber
Are you taking over the logging of know bugs?
I'd be very happy for you to do so. I never wanted to the job in the
first place.
If you're not taking over the known bugs list, then please don't post
things that look like known bugs lists. It's a real pain to correlate
the info in this thread with the info in my list.
Mike Williams
Gentleman of Leisure
In article <jOP$8KAad1b8EwkB@econym.demon.co.uk> , Mike Williams
Indeed, the POV-Team has been asking TAG members to take over this job because
they can provide direct feedback to the POV-Team in other (private) groups on
this server. Warp volunteered to do the major work, but I am sure other TAG
members will support him.
> first place.
Thank you very much for your help!
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
Warp <war### [at] tag povray org> wrote:
: This one is marked as fixed in the project jobs list and I personally
: didn't really see the mentioned symptoms of the bug when I tried it.
: I can double-check.
Let's wait for beta12 to see if the bug is still there. I'll then update
the list accordingly.
As per request I waited for beta 12, the bugs still there.
