POV-Ray : Newsgroups : povray.beta-test : Newbie question on beta10 camera behavior-Not a bug report- Server Time
6 Mar 2026 03:24:43 EST (-0500)
  Newbie question on beta10 camera behavior-Not a bug report- (Message 1 to 10 of 10)
Subject: Newbie question on beta10 camera behavior-Not a bug report-
Date: 28 Jan 2002 23:51:38
Message: <3c562a5a@news.povray.org>
Dear Povers,
 Couple of days ago, I re-rendered older scene file on the new Pov3.5 beta
10. It seemed to me the size of the objects in the raytraced image are
rather smaller than the previous render done in older betas.
Would this possibly be related to the position of the camera statements,
which have been (I guess) changed in the beta10 of Pov3.5?
Thanks so much,
Jong
Subject: Re: Newbie question on beta10 camera behavior-Not a bug report-
Date: 29 Jan 2002 00:26:02
Message: <Xns91A546A3FE88csbhccse@204.213.191.226>
"Jong" <jjk### [at] mmewhaackr> wrote in news:3c562a5a@news.povray.org:
> beta 10. It seemed to me the size of the objects in the raytraced image
> are rather smaller than the previous render done in older betas. Would
Probably.  Beta 10 ignores the angle statement unless it is the last
component in the camera block (this change wasn't documented) and requires
the up and right vectors to be given when using the orthographic camera.
The former change is not backward compatible with previous versions of Pov
and the latter means that orthographic and perspective cameras no longer
give the same field of view even when all other camera keywords are
identical.
Date: 29 Jan 2002 03:50:02
Message: <Xns91A526F497EB8mrartchesapeakenet@204.213.191.226>
Coridon Henshaw scribis news:Xns### [at] 204213191226:
> and requires the up and right vectors to be given when using the
> orthographic camera
I just ran a test to see about this part...
I get no errors/warnings by using an orthographic camera without
setting up and right vectors. And yes, I am using 3.5 b10
camera{orthographic location <0,0,-20>}sphere{0,2 pigment{color rgb 10}}
Gis poste, Arto.
Date: 29 Jan 2002 04:52:42
Message: <3c5670ea@news.povray.org>
In article <Xns### [at] 204213191226> , che### [at] sympaticoca
Neither is correct.  Both work at any place in the camera statement.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 29 Jan 2002 12:17:59
Message: <Xns91A57D1AF6C1Dcsbhccse@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3c5670ea@news.povray.org:
Try it yourself.
AngleFirst.pov:
sphere {0,2000 pigment {rgb 1} finish {ambient 1}} camera {location
<0,0,15000> right x*(image_width/image_height) angle 25 look_at <0,0,0>}
AngleLast.pov:
<0,0,15000> right x*(image_width/image_height) look_at <0,0,0> angle 25}
The angle statement in the first example is ignored.
Orthographic vs. perspective camera:
Perspective.pov
<0,0,15000> right x*(image_width/image_height) look_at <0,0,0>}
Orthographic.pov
sphere {0,2000 pigment {rgb 1} finish {ambient 1}} camera {orthographic
location <0,0,15000> look_at <0,0,0>}
Note that the latter camera generates a completely white image rather than
a non-perspective version of the image generated by the perspective camera.
The up and right vectors must be specified (as I said) in order to get a
usable field of view.
Date: 29 Jan 2002 18:04:02
Message: <i9ae5u0kkkncqodnmkse9dn6utgds3iaej@4ax.com>
On 29 Jan 2002 12:17:59 -0500, che### [at] sympaticoca (Coridon Henshaw)
>Try it yourself.
I suggest you trust Thorsten on this one. After all, he made the
changes to the camera code in question :)
That documentation does not _yet_ reflect them is another story but I
can't really blame the docs folk as I haven't written even a byte of
it (though I probably should have; oh well...) and there wasn't enough
time between the committing of aforementioned changes and the b10
release, so...
Peter Popov ICQ : 15002700
Date: 29 Jan 2002 19:18:23
Message: <Xns91A5C465C9400csbhccse@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:i9ae5u0kkkncqodnmkse9dn6utgds3iaej@4ax.com:
>>Try it yourself.
If a coder says his code does one thing but his executable does another
(which it does; run the examples and you'll see it, too), I think you can
understand that I'll take the executable at face value and suggest that the
coder doublecheck his code.
Date: 30 Jan 2002 02:57:38
Message: <3c57a772$1@news.povray.org>
Wrong.
If you, say, you have "look_at" and "angle" as the
last two statements in your "camera", then even
altering just their order screws up everything (yes,
Thorsten, believe it or not -- the "angle" gets ignored).
BTW, could you please give any reason for altering
the "camera" statement so heavily? E.g. I tried Moray
3.3a (evaluation copy; specially patched for POV 3.5)
and its preview pane did not look correctly until I put
"#version 3.1;" into MorayPov.inc.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c5670ea@news.povray.org...
requires
>     Thorsten
> Thorsten Froehlich
Date: 30 Jan 2002 03:04:09
Message: <3c57a8f9$1@news.povray.org>
Does the comment /* can't happen */ ring the bell for you?
Date: 30 Jan 2002 05:14:42
Message: <3c57c792$1@news.povray.org>
> Try it yourself.
"Work" does simply imply "not ignored", I never said they "work exactly the
same as in POV-Ray 3.1".  This is important as the whole issue of fixing the
camera statement order of keywords problem in 3.5 will break some scenes that
depend on the previously existing chaos.
I suggest you just wait until the changes are complete (and there is one
deterministic order) in the next beta.  Then we can determine if any possible
uses of the camera keywords and their order are no longer covered and thus
solutions for those occasions need to be developed.
    Thorsten
e-mail: tho### [at] trfde
