On 22 Jan 2002 12:14:13 -0500, Warp <war### [at] tag povray org> wrote:
> It's not actually a heightfield bug. It's a more general phenomenon. If the
> angle between the normal vector returned by the object (any object) and the
> incoming ray is <90 degrees, then the normal vector is inverted.
> The normal vector of this smooth triangle points always upwards, never
> downwards, and thus it should never get colored red. But the inversion
> phenomenon of the normal causes the artifact.
I can be completly offtopic but could be normal determined by order of vertices
in triangle?
ABX
On Thu, 24 Jan 2002 08:48:33 +0100, Włodzimierz ABX Skiba
>in triangle?
Then the renderer would have to trust that the order is correct, and
that is the task of either the export utility or the scene that
generates it. In any case the user shouldn't be doing the renderer's
job.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
> > in triangle?
not exactly
I proposed this becouse I always generate meshes from triangles builded in one
direction (ok, almost always). I helps me a lot in generating smooth normals.
Old behaviour could be supported just with #version 3.1; afaik there is no
export utylity for 3.5 so I suppose all utilities adds #version to exported
scripts.
> In any case the user shouldn't be doing the renderer's job.
But renderer can't decide as I understand.
ABX
Włodzimierz ABX Skiba <abx### [at] babilon org> wrote:
: I can be completly offtopic but could be normal determined by order of vertices
: in triangle?
I didn't understand this.
The problem is not determining the normal. The problem is just that if
the angle between the incoming ray and the normal vector returned by the
object have an angle <90 degrees, the normal is inverted.
This works just fine in most cases (and it has to be done this way). The
only problem happens with smooth triangles and smooth heightfields in certain
cases.
As for lighting, this problem goes away by making the object
double-illuminated (because then it doesn't matter which way the normal
is pointing). However, as for the slope pattern, the solution is not so simple
(double_illuminate is used only for lighting and can't be used for slope
pattern calculation).
By the way: In a heightfield the problem with the slope y pattern goes
away if you "mirror" the color_map around 0.5 (of course it doesn't work if
the slope is anything else than y), besides making the heightfield
double-illuminated.
With smooth meshes which use the slope pattern there's no currently fix,
AFAIK.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
I see, sorry then.
ABX
Subject: Re: More info (Was: Heightfield bug (most probably an inverted normals problem))
Date: 24 Jan 2002 09:48:07
Message: <3C501EB7.263F96C0@atosorigin.com>
> in triangle?
From memory:
In 3.1 code, the short answer is NO, at least for mesh,
because the mesh code is free to reorder the vertices of any single triangle.(*)
So even if you carefully generate all your triangles with a +side and -side,
once in the mesh structure it might be impossible to get back to the original
order. It's often simpler to use a smooth_triangle which allow to explicitely
specify a normal for each vertex (but take more memory, of course).
(*) and it does it, according to its own private criteria.
Non Sine Numine
http://grimbert.cjb.net/
On Thu, 24 Jan 2002 13:38:00 +0100, Włodzimierz ABX Skiba
>not exactly
Yes, but that's you. You're not the average Joe User.
Yet :)
In article <9uuv4uoaebc3dldemv9snhjmopultmctlj@4ax.com>,
> job.
No. There is no way for the renderer to reliably determine the correct
normal, and such a mechanism would break many meshes that use the
winding to determine it. It normally isn't a problem anyway, since POV
renders both sides of the triangle.
And it isn't related to the height field problem, which has more to do
with the interpolation of smooth triangle normals.
Christopher James Huff <chr### [at] mac com>
In article <3C501EB7.263F96C0@atosorigin.com>,
> triangle.(*)
Not true. The mesh stores the vertex *vectors* separately, the triangles
then refer to that list. The triangles still know what order the
vertices are in.
Proof? Use interior_texture on a mesh. The height-field macros make good
examples...
Date: 6 Feb 2002 07:18:40
Message: <3c611f20@news.povray.org>
> macros make good examples...
And after I fixed the height-field macros you even get the interior texture
on the *inside*, contrary to how it was before... ;)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Jan 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
