POV-Ray : Newsgroups : povray.beta-test : <1, 0, 0> + 1*t Server Time
6 Mar 2026 03:24:43 EST (-0500)
  <1, 0, 0> + 1*t (Message 1 to 10 of 10)
Subject: <1, 0, 0> + 1*t
Date: 21 Jan 2002 01:20:13
Message: <3c4bb31d$1@news.povray.org>
I don't know if it is a bug or intended, but it caused me some loss of time
: the <1, 0, 0> + 0.5*t  yields <1, 0, 0, 0> and not <1, 0, 0, 0.5> as
expected (by me!). (This happens whatever the number at the place of 0.5)
Additions <1, 0, 0> + t, <1, 0, 0> + t*1, or 1*t + <1, 0, 0> yield <1, 0, 0,
1>!
#macro V4Show(S, V)
#debug concat(S, ": ", str(V.x,6,2), ", ", str(V.y,6,2), ", ",str(V.z,6,2),
", ",str(V.t,6,2), "\n")
#declare vvv = <1, 0, 0> +1*t;
V4Show("vvv ",vvv)
Subject: Re: <1, 0, 0> + 1*t
Date: 21 Jan 2002 01:48:09
Message: <ZgqRnDAol7S8EwIR@econym.demon.co.uk>
>1>!
>#macro V4Show(S, V)
>#end
>V4Show("vvv ",vvv)
The documentation states that "t" is defined as
 #declare t = <0, 0, 0, 1>;
But that's a long way from the place where we learned that the order of
the vector components is "rgbft". The fourth vector is "filter", not
"transmit".
V.t extracts the fifth component, not the fourth.
I reckon things would make more sense if "t" where defined (and
documented) to be <0,0,0,0,1> and "f" were defined to be <0,0,0,1,0>,
but the current code works exactly as documented, so it's not really a
bug.
Mike Williams
Gentleman of Leisure
Date: 21 Jan 2002 09:40:45
Message: <3c4c286d$1@news.povray.org>
I think you misunderstand the problem. "t" is defined as <0, 0, 0, 1>, and
the ".t" operator extracts the fourth component of the vector. It has
nothing to do with filter or transmit.
To make it more clear, this script:
  #debug concat(str((<1, 0, 0> + t*1).t, 0, -1), "\n")
  #debug concat(str((<1, 0, 0> + 1*t).t, 0, -1), "\n")
outputs:
  1.000000
  0.000000
even though the two results should be identical.
Anders
light_source{6#local D#macro B(E)#macro A(D)#declare#declare C=mod(E
D);E=(E-C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)
}cylinder{0(C=<1 2>).2translate<D+C*A(2)A(4)#else}intersection{torus
{1 .2}box{-2y}rotate<1 0C>*90translate<D+1A(2)*2+1#end-2 13>pigment{
rgb x}finish{specular 1}#end#end#end=-8;1B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Date: 21 Jan 2002 09:45:57
Message: <chrishuff-F7BDE6.09465221012002@netplex.aussie.org>
In article <3c4c286d$1@news.povray.org>,
Exactly, it is "t" as in "time", not "transmit". You can access filter
and transmit with ".filter" and ".transmit".
Date: 21 Jan 2002 09:53:23
Message: <chrishuff-939110.09541921012002@netplex.aussie.org>
> outputs:
>   1.000000
>   0.000000
The problem seems to be that "1" gets expanded to "< 1, 1, 1, 0, 0>",
this works as expected:
#declare FourD1 = < 1, 1, 1, 1>;
#debug concat(str((<1, 0, 0> + t*FourD1).filter, 0, -1), "\n")
#debug concat(str((<1, 0, 0> + FourD1*t).filter, 0, -1), "\n")
So at least there's a workaround...
Date: 21 Jan 2002 14:57:45
Message: <$sPY0GA7CHT8Ewli@econym.demon.co.uk>
>outputs:
>  1.000000
>  0.000000
Oh, right. It's a precedence bug.
What we'd expect to happen is for the multiplication to happen first,
but it doesn't, the addition happens first; and for that to happen the 1
may need to be expanded to a 5d vector.
If we add brackets to the t*1 and 1*t we get the "right" answer 1.000000
in both cases
  #debug concat(str((<1, 0, 0> + (t*1)).t, 0, -1), "\n") // 1.000000
  #debug concat(str((<1, 0, 0> + (1*t)).t, 0, -1), "\n") // 1.000000
If we force the addition to happen first, then we get the wrong answer
  #debug concat(str(((<1, 0, 0> + t)*1).t, 0, -1), "\n") // 1.000000
  #debug concat(str(((<1, 0, 0> + 1)*t).t, 0, -1), "\n") // 0.000000
What's happening is that in the second case the "1" gets expanded to
<1,1,1,1,1>. This gets added to <1,0,0,0,0> to give <2,1,1,1,1>.
<2,1,1,1,1> * <0,0,0,1,0> gives <0,0,0,0,1>.
  #declare Test = <2,1,1,1,1>*<0,0,0,1,0>;
  V5Show("Test ",Test) // Test:   0.00,   0.00,   0.00,   0.00,   1.00
Mike Williams
Date: 21 Jan 2002 15:23:01
Message: <chrishuff-E3EDE9.15235821012002@netplex.aussie.org>
In article <$sPY### [at] econymdemoncouk>,
<2,1,1,1,1>*<0,0,0,1,0> should equal <0,0,0,1,0>, not <0,0,0,0,1>.
Again, I don't think this is a precedence bug, but a bug with converting
float values to vectors.
(<1, 0, 0> + t*1).t
expands to:
(<1, 0, 0> + (< 0, 0, 0, 1, 0>*< 1, 1, 1, 1, 1>)).t
which equals < 1, 0, 0, 1, 0>
as it should, but
(<1, 0, 0> + 1*t).t
expands to:
(<1, 0, 0> + < 1, 1, 1, 0, 0>*< 0, 0, 0, 1, 0>).t
which equals < 1, 0, 0, 0, 0>.
However, if you use:
(<1, 0, 0, 0> + 1*t).t
All is well.
I'm guessing the code decides it's using a 3D vector when it parses the
first vector, so it only expands the 1 to a 3D vector. When it then
multiplies by a 4D vector, the fourth component is 0. Probably the only
solution is to do 5D math all the time, I don't think it's possible to
scan the expression to see the largest number of dimensions involved in
the current parser.
Date: 22 Jan 2002 03:41:18
Message: <3c4d25ae$1@news.povray.org>
I'm not that well versed in compilation, but I would expect that an
expression is parsed left to right, but analysed as a tree. If that would be
the case the sub-expression 1*t would be analysed first, on its own, and
typed as a 4D vector; then x + 1*t would be analysed and typed as a 4D
vector also. There is no need to parse or analyse the whole expression, just
to analyse it from leafs up in the tree.
I find the present state annoying not so much because 1*t and t*1 are
distinct (in math, there is no reason why the two would not be distinct
operations), but because the normal way to write math expressions is 1*t,
i.e., a real times a vector, not the other way round!
Michel Mouly
chr### [at] netplexaussieorg...
> (<1, 0, 0> + t*1).t
> expands to:
> as it should, but
> (<1, 0, 0> + 1*t).t
> expands to:
> All is well.
> the current parser.
Date: 22 Jan 2002 06:14:38
Message: <3c4d499e@news.povray.org>
In article <3c4d25ae$1@news.povray.org> , "mm" <mmo### [at] wanadoofr> wrote:
Not really.  It is parsed recursively.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Jan 2002 13:45:48
Message: <rvLt0DAqXUT8Ew35@econym.demon.co.uk>
>distinct
1*t and t*1 do evaluate to the same thing, <0,0,0,1>.
It's A+1*t and A+t*1 that evaluate differently (where A is a 2d or 3d
vector).
Perhaps more worrying is that  A+1*z  is different from  A+z*1  (where A
is a 2d vector) even though 1*z = z*1 = <0,0,1>.
Mike Williams
