POV-Ray : Newsgroups : povray.beta-test : media & fog bug? Server Time
25 Jul 2026 21:41:55 EDT (-0400)
  media & fog bug? (Message 1 to 6 of 6)
Subject: media & fog bug?
Date: 9 Dec 2001 09:49:04
Message: <3c1379e0$1@news.povray.org>
Is this a bug with media containers and fog, surely the following scene
should render the same for all possible combinations of FogSw, MediaSw=1or
0, due to media being totally transparent, adding fog seems to be the
culprit
//Begin buggy scene
#declare FogSw=1; // 1=on, 0=off
#declare MediaSw=1; //1=on, 0=off
  location <0,2,-14>
  right <16/9,0,0>
  look_at <-1,2,0>
light_source {
  <0,200000000,0>
  color rgb <1,0.8,0.65>*1.8
  rotate <0,0,50>
  rotate <0,20,0>
sky_sphere {
    bozo
    color_map {
      [0 rgb <0.4,0.6,0.8>*0.87]
      [1 rgb <0.4,0.65,0.9>*1]
    scale 0.1
    turbulence 0.8
    octaves 4
    lambda 2
    omega 0.4
#if(FogSw)
fog {
  fog_type 2
  distance 200
  fog_offset 0
  fog_alt 80
  color rgb <0.8,0.8,0.75>*1
#if(MediaSw)
box {
  <-30000,700,-60000>
  <30000,900,60000>
  material {
      pigment {rgbt 1}
    interior {
      media {
        scattering {5, 0.00 extinction 1 eccentricity 0.005}
        method 3
        intervals 1
        aa_level 4
        jitter 0.1
        density {
          rgb 1
  hollow
plane {y,0 texture {pigment {rgb 1}
Subject: Re: media & fog bug?
Date: 9 Dec 2001 09:59:57
Message: <3c137c6d@news.povray.org>
oops Pov 3.5 b8, Intel compile, Win98, 1.33Ghz Athlon, 512MB ram
.................and a partridge in a pear tree :)
Kev
Date: 9 Dec 2001 18:50:30
Message: <3C13F95B.E4E09D82@pacbell.net>
Kevin Ellis wrote:
> Hi,
> culprit
I am pretty sure that this falls into the "not a bug" category. I know
this problem was present in v3.1g and have seen someone suggest a work
around for it. I just can't seem to find the article in question at the
moment.
Ken Tyler - POV-Ray Technical Assistance Group
Date: 9 Dec 2001 21:30:25
Message: <3c141e41@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3C13F95B.E4E09D82@pacbell.net...
MediaSw=1or
> > culprit
> moment.
If you're talking about using larger than 1 for transparency then it isn't
really possible to get a correct result, esp. not in every situation.  I
tried the script and with rgbt 1.6 for the box media container the plane is
approx. the same color as without media.  The fog becomes enhanced too
though.  If a filter value which matches that of the box is used in the fog
color then the original coloration appears.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Date: 10 Dec 2001 03:06:50
Message: <3c146d1a@news.povray.org>
> moment.
Sorry Ken, but I'll have to disagree with you on this one as in my opinion
it is definitely a bug. The work around that I have found is to use
radiosity with the media on switch, but this is incredibly slow when the
ground is an isosurface, but this is still not a complete solution.
The media container in the example should contain clouds so I should get
some shadow from just the clouds, at the moment the whole box casts a shadow
with the above radiosity solution I still get no shadows from the clouds. I
have been experimenting with media clouds since MegaPOV and have never
experienced this problem before. I realise that POV v3.5 is not MegaPOV it's
just that MegaPOV seemed to have the correct behaviour, or maybe I was just
plain lucky and never ran into the problem, could someone please check
MegaPOV for me as I no longer have it or v3.1 installed?
Kev
Date: 10 Dec 2001 03:58:29
Message: <3c147935@news.povray.org>
"Kevin Ellis" <kev### [at] tiscalicouk> wrote in message
news:3c146d1a@news.povray.org...
> > moment.
shadow
I
it's
just
Admittedly the box container object itself does seem to cast a shadow when
it should not be.  I'm just uncertain of the fact myself.
For media transmit can cast shadows too now, although at transmit 1 there
shouldn't be anything to cast a shadow from the box alone.  Before, in
earlier MegaPOV versions media couldn't cast shadows unless filter was used
instead (correct me if I'm wrong on that, anyone) but it didn't hamper
regular objects.
I can get shadows from clouds to show up simply by using:
box {
  <-30000,700,-60000>/10
  <30000,900,60000>/10
  material {
      pigment {rgbt 1}
    interior {
      media {
        scattering {5, .01 extinction 1 eccentricity 0.005}
        method 2 // speedier
        intervals 1
        aa_level 4
        jitter 0.1
        density {
                marble
                density_map {
                        [0 rgb 10] [.25 rgb 0]
                        } frequency 2 turbulence 1 scale 500
  hollow
instead of the box object you have there now, plus I put keyword parallel
into the light source.
Anyway, it does look as if there might be a problem since the shadow is not
seen when looking from above the lowest part of the box.  It manifests
itself when viewed from under the box.  At least I think it does.
