POV-Ray : Newsgroups : povray.beta-test : rare conic prism bug Server Time
25 Jul 2025 11:04:48 EDT (-0400)
  rare conic prism bug (Message 1 to 10 of 10)
Subject: rare conic prism bug
Date: 25 Jan 2002 04:11:12
Message: <3C51212E.9090707@irrwerk.de>
// system :  Win98 / Athlon 800 / 512 MHz RAM  / beta10
// A rare prism bug: Following code produced strange behavior of
illumination/texture of conic prisms.
// If one declares a rotation value smaller than -89.999999994270432
// and bigger -90.0000000057296  the conic sides of the prism are not
illuminated by the light_source,
// with ambient 1 they are visible. this happens to all spline types (at
least the examples I tested).
// (if  necassary, I can post 2 sample render pictures)
// 8) SciBorg
// good luck !
#version 3.5
#declare test=texture { pigment { color rgb 1  } finish { ambient 0
diffuse 1}   }
light_source {  0*x  color rgb 1.0 translate <10, 10, 50> }
camera {  orthographic  location <0,0,4> look_at  <0,0,0>  right 2.1*x
up 2.1*y  }
prism {
  conic_sweep  // linear_sweep or conic_sweep for tapering to a point
  linear_spline // linear_spline | quadratic_spline | cubic_spline |
bezier_spline
  1,  0.5,   4, <-1, -1>,< 1, -1>,<1, 1>,<-1,  1>
  //rotate  -90.0000000057296*x     // visible
  //rotate  -90.0000000057295*x     // invisible
  rotate  -90*x                   // invisible
  //rotate  -89.999999994270433*x   // invisible
  //rotate  -89.999999994270432*x   // visible
  texture { test }
Subject: Re: rare conic prism bug
Date: 25 Jan 2002 04:53:47
Message: <vma25u4v3bqt3lde7dh75eosjrb5nb1cm1@4ax.com>
Confirmed with both compile versions.
POV 3.5 b 10 on WinNT Sp 6 PII 233 with 128 MB
ABX
Date: 2 Feb 2002 03:32:10
Message: <3BAKPVASO6W8EweW@econym.demon.co.uk>
>ABX
Thorsten says "Not properly confirmed.  Just being able to reproduce the
exact behavior is not enough.  At least a tiny bit of experimentation
should be done to be able to say it is a bug and not a precision
problem."
Mike Williams
Gentleman of Leisure
Date: 2 Feb 2002 04:53:14
Message: <Xns91A931B7D9912csbhccse@204.213.191.226>
Mike Williams <mik### [at] nospamplease> wrote in
news:3BA### [at] econymdemoncouk:
> problem."
I'm wondering just what kind of precision he has in mind if blatant
lighting errors as a result of using rotate x*90 (that's with zero decimal
places) can be dismissed as a precision problem.  This kind of reasoning is
getting close to defining -1^(1/2)=3 as correct.
Working with the example scene, it's plainly obvious that the lighting
calculations break down on the beveled portions of the prism when the prism
is transformed to face the camera.  This problem depends on the
orthographic camera and on the prism being transformed to face the camera
head-on by using either rotate x*90 or a matrix.
The prism is lit correctly if it is rotated by 90.01 or 89.99 degrees (if
using rotate), if  a shear component is introduced into the second row of
the matrix (if using a matrix transform), or if the perspective camera is
used.
Simplified scene, with matrix transform:
light_source {<10, 10, 50> rgb 1}
camera {orthographic location z*4 look_at 0 right x*3 up y*3}
prism
    conic_sweep
    linear_spline
    1, .5, 5, <-1, -1>, < 1, -1>, <1, 1>, <-1,  1>, <-1,-1>
    matrix
        1,0,0,
        0,0,-1,
        0,1,0,
        0,0,0
//    rotate  x*-90
    pigment {rgb 2}
background {rgb 0.25}
Date: 8 Feb 2002 10:50:08
Message: <3C63F3AB.7010406@irrwerk.de>
>>problem."
[Question] Which kind of experimentation should be done to proof, that
it is not just a silly annoying precision problem ?
I would expect such things not in a simple rectangular rotation. I would
like to help but how ?
:-) SciBorg
Date: 8 Feb 2002 11:08:34
Message: <7gt76ugumobnrk0rnogdt6doj9aglhvsic@4ax.com>
Unfortunatelly I've experimented with your report and I must say it is
possible it's not a bug. Rotation is internally represented as matrix. Or
rather two matrixes: normal and inverted transformation. This inverted
transformation is applied to ray during intersection test.
Orthogonal camera type sends parallel rays. Note: bug disappeare when camera
is changed to perspective. I have also found strange behaviour for torus in
orthogonal view.
ABX
Date: 10 Feb 2002 10:50:40
Message: <3C6697C8.60A16193@free.fr>
> orthogonal view.
> ABX
Why does it remind me of a problem with the superellipsoid in 3.1g, which
was also obvious with orthographic and well hidden with perspective and AA ?$
It ends up with a bogus code when a rotation of 270*y was applied...
 it has since been corrected.
Did you report the torus & orthogonal ? (Where ?)
Non Sine Numine
http://grimbert.cjb.net/
Etiquette is for those with no breeding;
fashion for those with no taste.
Date: 11 Feb 2002 04:57:17
Message: <da0f6uoairsjav7t7ajud6jf6q138qbde0@4ax.com>
On Sun, 10 Feb 2002 16:54:48 +0100, L'Harmonieux Forgeron <jgr### [at] freefr>
I don't know
IIRC the problem was that superellipsoid returned only one intersection (or
something similiar).
Sure.
> (Where ?)
I remember I reported it earlier on some group but perhaps within thread about
something other. But when beta-testing started I posted regular report here:
http://news.povray.org/i344rt8ftt1ctvq3smm5f8salnaeoclpl3%404ax.com
http://news.povray.org/rh44rtoeu5ifj145bv3iu3uirf6jb7ckrj%404ax.com
ABX
Date: 12 Feb 2002 04:00:50
Message: <3C68D9D0.A30FE12B@atosorigin.com>
Testing the provided scene with 3.1g, I got the mention that the spline is not closed.
No problem with any rotation value.
Date: 12 Feb 2002 04:40:09
Message: <d1oh6u821648rvs7frgmt4cl7u41s6cmmo@4ax.com>
closed.
the same as with 3.5 b11 probably
strange
I have replaced
rotate  -90*x
with pair of rotations
rotate 90*z
rotate -y*90
and parts are still invisible
then I replaced rotations with matrix
matrix <1,0,0,0,0,-1,0,-1,0,0,0,0>
and discussed parts are still invisible
ABX
