POV-Ray : Newsgroups : povray.beta-test : Philosophical objection to fog distance=0 Server Time
2 Nov 2024 15:22:53 EDT (-0400)
  Philosophical objection to fog distance=0 (Message 1 to 10 of 20)
Subject: Philosophical objection to fog distance=0
Date: 6 Nov 2001 08:43:29
Message: <3BE7E897.FEC8EF6@aol.com>
The following scene file gives a black screen.  IMHO it should give a
green screen. This bug/feature caused me considerable headaches 'till I
figured it out.  Consider for example the difference when the distance
is 1e-6.
  fog {
    distance 0
//    distance 1e-6
    color rgb<0.3, 0.5, 0.2>
Subject: Re: Philosophical objection to fog distance=0
Date: 6 Nov 2001 08:52:18
Message: <iiqfut8231iiqn5odnhj1bd2mtba42pjra@4ax.com>
On Tue, 06 Nov 2001 08:41:43 -0500, "Greg M. Johnson"
> green screen.
The behaviour is probably undefined becouse of fog formula from 6.9.3 chapter.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 6 Nov 2001 09:26:42
Message: <3BE7F340.CC6AC882@pacbell.net>
> is 1e-6.
Philosophical objection?
It does not behave any differently than it did in POV-Ray v3.1g. This
means it is not a bug and this message does not belong in this group.
If you want to discuss feature behavior you might try one of the
other groups on this news server such as povray.general.
Let's keep focused on bug reports, please.
Ken Tyler - POV-Ray Technical Assistance Group
Date: 6 Nov 2001 10:08:52
Message: <p0vfutka6fjr50c0rrn9egpqk63c80ibj9@4ax.com>
Could it be treated as bug report if I say there is no simple small example for
mesh2 in scene files ? Only within advanced balcony.
ABX
Subject: 3.1g & 3.5 bug report
Date: 6 Nov 2001 10:41:28
Message: <3BE8043C.FB0E9E02@aol.com>
> > green screen.
This bug-carry-over-from 3.1g could be fixed by changing:
PIXEL_COLOR = exp(-d/D) * OBJECT_COLOR + (1-exp(-d/D)) * FOG_COLOR
to
PIXEL_COLOR = exp(-d/(D+GGG)) * OBJECT_COLOR + (1-exp(-d/(D+GGG))) * FOG_COLOR
Where GGG= an infitesimal, just bigger than the smallest number pov can handle
Subject: Re: 3.1g & 3.5 bug report
Date: 6 Nov 2001 10:59:56
Message: <kv1gut8247bkoa6o7t01pcb8pg2gbt0n27@4ax.com>
On Tue, 06 Nov 2001 10:39:40 -0500, "Greg M. Johnson"
> to
Balancing between floating point accuracy and division by zero is rather not
very best thing. "The smallest number pov can handle" depends on platform.
Morover why this addition should be done for all values (even large integers)?
It is rather bug in parser which allows even "distance -1".
ABX
Date: 6 Nov 2001 11:24:45
Message: <3BE80ECD.2628F521@gmx.de>
Hmm, certainly not a bug, but relevant for this group anyway.  I think the
main reason is that mesh2 is particularly useful for large meshes which
would be too large for the scene file collection.  I had quite a lot of
trouble getting the cloth mesh in balcony down to the current 300k and
this is still quite a lot.
Date: 6 Nov 2001 11:56:26
Message: <b05gut83dfmig601dqivm42bg43qm2s620@4ax.com>
On Tue, 06 Nov 2001 17:24:45 +0100, Christoph Hormann <chr### [at] gmxde>
But there could be comparision of mesh with two faces - one with mesh{} and the
same with mesh2{}. Bezier patch is supposed to be generated with external
programs but there is sample for it within scenes/objects.
You can remove some space by replacing "0." with "." but I think you have
considered this. I don't know how many signs are there but perhaps you can also
change negative to positive and positive to negative in vertices and normals and
use scale -1.
I think it could be also good idea to make universal macros to generate
face_indices and uv-vectors for grids like yours within standard include files.
ABX
Date: 6 Nov 2001 12:02:12
Message: <3be81794@news.povray.org>
> POV-Ray v3.1g. This means it is not a bug and this
While I agree that this message of Greg's is perhaps more of a feature
request than a bug report (since a distance of 0 may be undefined for good
reasons), I would like to point out that even if something works the same
way in POV-Ray 3.1 it can still be a bug. POV-Ray 3.1 is not entirely
bug-free.
There have been lots of bugs reported here that also were present in POV-Ray
3.1, and AFAIK no Team member has ever complained about that, but on the
contrary they have tried to fix them.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 6 Nov 2001 12:14:20
Message: <3BE81A6B.547F0694@gmx.de>
Although the scene file collection is to some extend 'fixed' this might by
a good idea, i will see what i can do.
> use scale -1.
Yes, removing the 0's would reduce size although compression (for the
installation package) will work quite well on them.
I think Ingo has already made such macros, i don't know if they are
already well tested though.
