POV-Ray : Newsgroups : povray.beta-test : triangle texture interpolation Server Time
30 Jan 2026 15:28:01 EST (-0500)
  triangle texture interpolation (Message 1 to 10 of 11)
Subject: triangle texture interpolation
Date: 15 Sep 2001 15:40:09
Message: <3BA3A9E3.9DF1D9E2@free.fr>
Povray 3.5 beta2, Windows 98 SE, Pentium MMX, 256 Mo.
According to doc 6.7.8, there could be a comma between the texture identifiers.
But the parser refuse it.
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <-30, 30, -30>
  color rgb <1, 1, 1>  // light's color
#declare T1=texture { pigment {color rgb <1,1,0>} }
#declare T2=texture { pigment {color rgb <1,0,0>} }
#declare T3=texture { pigment {color rgb <0,1,1>} }
mesh {
triangle { <-1,0,0>,<0,1,0>,<0,0,0> texture_list { T1 T2 T3 }  }
triangle { <0,0,0>,<0,1,0>,<1,1,0> texture_list { T3  T2 , T1 }  }
triangle { <0,0,0>,<1,1,0>,<1,0,0> texture_list { T3 , T1 , T2 }  }
Subject: Re: triangle texture interpolation
Date: 16 Sep 2001 17:37:47
Message: <Xns911EF0604B6B6seed7@povray.org>
> identifiers. But the parser refuse it.
Could somebody on the Team tell me, should I change the docs for this
or will POV-Ray be changed?
Ingo
Date: 16 Sep 2001 21:00:30
Message: <3ba54b2e@news.povray.org>
"ingo" <ing### [at] homenl> wrote...
Please change the docs.
-Nathan
Date: 18 Sep 2001 14:49:47
Message: <Xns9120D3E43CF64seed7@povray.org>
>> > texture identifiers. But the parser refuse it.
>> this or will POV-Ray be changed?
Does the same apply to the texture_list in mesh2 ?
Ingo
Date: 18 Sep 2001 19:41:53
Message: <3ba7dbc1$1@news.povray.org>
I don't think so.  Do you think we should require commas in "mesh" for
consistency?
-Nathan
Date: 19 Sep 2001 04:18:42
Message: <Xns912168E5AB370seed7@povray.org>
> consistency?
Yes, as in most places you can use commas if you wish.
Ingo
Date: 19 Sep 2001 18:44:23
Message: <3ba91fc7@news.povray.org>
Nathan Kopp <nat### [at] koppcom> wrote:
: I don't think so.  Do you think we should require commas in "mesh" for
: consistency?
  As long as it doesn't make it harder to create items in a loop/macro/etc.
  The greatest thing of commas being optional in most lists is exactly that:
You don't have to worry about extra commas at the end of the list when creating
the lists automatically.
  Another possibility is that a #-command could work effectively as the same
kind of separator as a comma.
Date: 19 Sep 2001 19:57:17
Message: <3ba930dd$1@news.povray.org>
> > consistency?
Good point.  Done.
-Nathan
Date: 2 Dec 2001 14:49:24
Message: <3C0A8288.DDA0905B@free.fr>
Initial problem solved (no more comma in the doc, OK).
But it seems that one of the texture (the first texture) disappears, or at least
is not put on the first point. Instead, the second texture is on the first point
and the third texture is used on the second and third points.
Povray 3.5.beta.8.icl.win32, Win98, Pentium MMX, 256 Mo
Demo scene (T1 is red, T2 green and T3 blue)
  direction 1.5*z
light_source {
  <-30, 30, -30>
#declare T1=texture { pigment {color rgb <1,0,0>} }
#declare T2=texture { pigment {color rgb <0,1,0>} }
#declare T3=texture { pigment {color rgb <0,0,1>} }
mesh {
triangle { <0,0,0>,<0,1,0>,<1,1,0> texture_list { T3  T1  T2 }  }
triangle { <0,0,0>,<1,1,0>,<1,0,0> texture_list { T2  T3  T1 }  }
Date: 2 Dec 2001 15:09:04
Message: <Xns916BD72C8BE49seed7@povray.org>
> disappears, or at least is not put on the first point. Instead, the
> second texture is on the first point and the third texture is used
Confirmed.
> triangle { <-1,0,0>,<0,1,0>,<0,0,0> texture_list{ T1 T2 T3 }  }
If you put commas in the texture list, the result changes and not for
the better.
Ingo
