POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. New inbuilt f_agate(). Server Time
16 Jun 2024 23:21:48 EDT (-0400)
  Function / pattern issues. New inbuilt f_agate(). (Message 1 to 7 of 7)
Subject: Function / pattern issues. New inbuilt f_agate().
Date: 7 May 2020 21:45:42
Message: <5eb4b9c6$1@news.povray.org>
<---------------------- References. Seven previous posts
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ea57285%241%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ead9027%40news.povray.org%3E/
Replacing the f_agate simple pattern{} wrap in functions.inc with a new
inbuilt f_agate which brings out the x,y,z directions and power exponent
as parameters in addition to parameters for the turbulence call's
octaves, omega and lambda.
Parameters: x, y, z
7 extra parameter required:
1. 0,1 or 2 for x, y or z agate alignment. Pattern's agate always uses z
(2).
2. Turbulence multiplier. Called agate_turb in the pattern version. (1.0).
3. Power exponent for pow(). Hard coded to 0.77 in the pattern version.
(0.77)
4. Number of octaves for the turbulence call. Pattern version defaults
to (6).
5. Omega value for the turbulence call. Pattern version defaults to 0.5.
6. Lambda value for the turbulence call. Pattern version defaults to 2.0.
7. The noise generator to use. Valid values 1-3. Pattern agate uses
pattern or global setting.
Notes. To match the default pattern agate:
f_agate(x,y,z,2,1.0,0.77,6,0.5,2.0,2)  <-- Matches pattern agate when
everything defaulted.  With the pattern agate octaves, omega and lambda
can be set with those bare keywords immediately after agate changing
agate's inbuilt turbulence.
For the bottom of the attached image creating an isosurface using both
the non-preferred directions looks like:
#declare Iso99 = isosurface {
     function { y+f_agate(x*2,y*2,z*2,0,0.08,0.20,6,0.5,2.0,2)*0.135
                 +f_agate(x*2,y*2,z*2,2,0.08,0.20,6,0.5,2.0,2)*0.135
On the top of the image subtracted both f_agate()s at multiplier of 0.035.
In a surprise, I expected f_agate() to be a little slower than the
inbuilt used as a pattern in a pigment, for example. It's running about
16% faster for reasons not currently understood. This the first pattern
where - other than f_dents which is cheap - the inbuilt function
implementation can match the pattern one exactly. (My f_granite23
inbuilt doesn't match granite.) A mystery for another day.
Bill P.
Download 'story_f_agate.jpg' (285 KB)
Preview of image 'story_f_agate.jpg'
Subject: Re: Function / pattern issues. New inbuilt f_agate().
Date: 7 May 2020 22:23:21
Message: <5eb4c299$1@news.povray.org>
> and
> Parameters: x, y, z
> (2).
> (0.77)
> to (6).
> Bill P.
Those looks like a slightly turbulent quilted pattern. Especially the
top example.
Date: 8 May 2020 06:16:58
Message: <5eb5319a$1@news.povray.org>
> top example.
I agree. :-) You can take the f_agate turbulence to 0.0 and get clean
lines (or grids) making it look similar to other patterns(1). Suppose on
some level the underlying driving variables - dimensions - are always
there.
An f_quilted() inbuilt on my list. It's got better control of the shape
of both extremes in value. With it I'm thinking of adding options which
run in x, y and z only. Maybe adding turbulence as an internal option
makes sense too...
Bill P.
(1) And the agate oriented dimension 'greys out.'
Date: 3 Jun 2020 14:30:09
Message: <5ed7ec31$1@news.povray.org>
A significant part of the performance degrade in the normal agate
pattern looks to be due the use of a dynamic_cast(1) while it checks
which turbulence warp exists / is the internal agate one. So, other
special turbulence patterns likely have this slow down too - though I've
not tested them.
In povr I'm now on the path of creating a set of it_ prefix turbulence
keywords and have this going for fog. Plan to move all the special
turbulence to these over time and move the special turbulence storage
out of the warp list into whatever. The it_ stands for (i)nternal
(t)urbulence. What I'm working with currently is:
it_depth      - Scaling by value along ray or other single vector.
it_frequency  - Multiplying the turbulence returned value(s). In action
                  it's a synonym for it_magnitude, butthe result is used
for a pattern map, or similar. Meaning the value(s) will see some form
of fmod() resulting in a frequency of repetitions through the map - or
whatever.
it_lambda     - Violence of each step(2.0).
it_magnitude  - Synonym for it_frequency in action, but better
description when thinking about vector turbulence and we are changing
              the magnitude of the returned DTurbulence vectors.
it_octaves    - Integer. Number of iterations 1 to 10?.
it_omega      - Dampening factor (0.5)
it_scale      - Multiplies input coordinates before turbulence
generated.  Internally x|y|z/<float(s)>. The fog turbulence 3d vector is
really acting as a 3d inverse scale.it_translate  - Moves from input
location before turbulence generated.  Internally x|y|z - floats(s)
Today we have ambiguity with just turbulence <vector>. In straight
turbulence it means it_magnitude. In fog - POV-Ray proper - it means
it_scale(2). In other places it means wave modification frequency
multiplication because of what the magnitude multiplication sees post
value(s) multiplication. Trying to make each sort explicit over time.
Bill P.
(1) - We've hit similar issues before with dynamic_cast. It's really,
really slow.
(2) - Frequency scaling is missing from our pattern 'magnitude'
turbulence today which is why you see people do things like:
scale 5/1  // scaling the whole mess up.
warp { turbulence... }
scale 1/5 // scaling the whole mess back down.
Date: 4 Jun 2020 17:10:05
Message: <web.5ed9625b5333712c8e3283b10@news.povray.org>
> not tested them.
You mean this train wreck of a C++ function that is abusing dynamic cast for a
type check?
bool AgatePattern::Precompute()
    return (!warps.empty() && dynamic_cast<ClassicTurbulence*>(*warps.begin()));
Oh hell, if the remaining code was turned into such a pile of junk :-( :-( :-(
Date: 5 Jun 2020 06:43:03
Message: <5eda21b7$1@news.povray.org>
>> not tested them.
> type check?
Similar. For agate most of the impact looks to me to be from:
static inline const ClassicTurbulence *GetTurb(const WarpList warps)
     POV_PATTERN_ASSERT(!warps.empty());
     POV_PATTERN_ASSERT(dynamic_cast<const
     return static_cast<const ClassicTurbulence*>(*warps.begin());
as it gets called - or probably 'run' as it's inlined - each time the
agate pattern is evaluated at a point.
After a couple times finding dynamic_cast to be big performance hits,
Christoph took a pass removing them from the ray tracing paths, leaving
the majority of uses in the parsing code. But, some still exist in other
than the parser. In the csg code there is still a cluster of them as I
recall.
Bill P.
Date: 5 Jun 2020 09:10:02
Message: <5eda442a$1@news.povray.org>
Couple coffees and now wondering if some of what I see is just that I
have that pattern assert on...
In any case, my plan is to slowly remove the special turbulence
handling. If I remember, I'll look at agate vs f_agate performance again
when I get back to pattern cleanup work again. Focused elsewhere at the
moment.
Bill P.
