POV-Ray : Newsgroups : povray.animations : detect totally black output Server Time
6 May 2024 16:34:20 EDT (-0400)
  detect totally black output (Message 1 to 4 of 4)
Subject: detect totally black output
Date: 20 Sep 2010 17:45:00
Message: <web.4c97d59d21eec7bebf952ed30@news.povray.org>
I'm rendering a series of test images as an animation and would like to omit the
pictures that did not result in any pixel data (they are actually totally black)
is there a way to detect this right after the rendering process in povray or do
I have to weed the pictures out after the animation is rendered?
Thanks,
Andi
Subject: Re: detect totally black output
Date: 21 Sep 2010 20:15:00
Message: <web.4c9949c2948af9acfdfcf7500@news.povray.org>
> Thanks,
> Andi
Hmm, I guess this question was a little too lame. I found my solution though.
After the animation is rendered I simply check for the picture with the least
bytes, and then get rid of all images that have the same byte amount. Seems to
be working great. ...
I guess there is no way to detect that within povray to speed up things.
Andi
Date: 27 Sep 2010 18:16:28
Message: <4ca117bc@news.povray.org>
Unless you render a scene in which no frame is totally black ;)
I don't think there is a faster way within povray. You could,
of course, when rendering frame n, load the image (n-1) as an
image_map and test all of its pixels using eval_pigment ;)
Date: 26 Oct 2010 17:40:01
Message: <web.4cc74a78948af9acbf952ed30@news.povray.org>
Hmmm ... eval_pigment ... interesting, will look into it. Thanks!
