POV-Ray : Newsgroups : povray.animations : grouping objects for transforms Server Time
28 Apr 2024 14:15:25 EDT (-0400)
  grouping objects for transforms (Message 1 to 10 of 20)
Subject: grouping objects for transforms
Date: 5 Feb 2017 09:20:01
Message: <web.5897336bee778495f9209890@news.povray.org>
For my animation, I want to place several objects in my scene individually,
group them somehow and perform transform operations on the entire group.
#declare groups the objects, but then I have to insert all objects as one unit.
Is there a way to create a group as you place the items in one at a time?
Something like:
#group {eastwall}
object { LongPlate
    rotate z*90
    rotate y*90
    rotate x*-90 }
object { LongPlate
    rotate z*90
    rotate y*90
    translate z*94.125
    rotate x*-90 }
object { ShortPlate
    rotate z*90
    rotate y*90
    translate <3.5, 0, 95.625>
    rotate x*-90 }
#for (i, 1.5, 241.5, 16)
    object {Stud
        rotate z*90
        translate <i, 0, 1.5>
        rotate x*-90 }
#endgroup
translate {eastwall} x*-90
then I would use a clock to place each item individually then transform the
entire group.
Subject: Re: grouping objects for transforms
Date: 5 Feb 2017 11:47:22
Message: <5897571a$1@news.povray.org>
Am 05.02.2017 um 15:15 schrieb Klewlis:
Nope.
Depending on what exactly you want to do, you might want to try
pre-defining the particular transform, and then applying it to multiple
objects:
    #declare MyTrans = transform {
      rotate x*-90
      scale <2,3,4>
    object { Foo
      transform { MyTrans }
    object { Bar
Note however that this probably doesn't give the intended result if one
of the objects is part of a CSG compound that itself is subject to some
transformation.
Date: 5 Feb 2017 12:12:11
Message: <58975ceb$1@news.povray.org>
> Something like:
> #group {eastwall}
> object { LongPlate
>      rotate z*90
>      rotate y*90
>      rotate x*-90 }
> object { LongPlate
>      rotate z*90
>      rotate y*90
>      translate z*94.125
>      rotate x*-90 }
> object { ShortPlate
>      rotate z*90
>      rotate y*90
>      rotate x*-90 }
>      object {Stud
>          rotate z*90
>          rotate x*-90 }
> #end
> #endgroup
> entire group.
Use union 2.2.3.2 CSG Union
union{		 // Start of union
 > object { LongPlate
 >      rotate z*90
 >      rotate y*90
 >      rotate x*-90 }
 > object { LongPlate
 >      rotate z*90
 >      rotate y*90
 >      translate z*94.125
 >      rotate x*-90 }
 > object { ShortPlate
 >      rotate z*90
 >      rotate y*90
 >      rotate x*-90 }
 >      object {Stud
 >          rotate z*90
 >          rotate x*-90 }
 > #end
}  // End of union
Regards
Date: 5 Feb 2017 13:30:00
Message: <web.58976e4d6098c6675f9209890@news.povray.org>
I want to build the wall laying down on the "concrete slab" then stand it and
move it into place as one unit.  I am currently building the wall standing up
which is not very realistic.
Date: 5 Feb 2017 13:35:01
Message: <web.58976f276098c6675f9209890@news.povray.org>
> }  // End of union
> Regards
>      Stephen
Thank you, I will give this a try
Ken
Date: 5 Feb 2017 13:39:27
Message: <5897715f$1@news.povray.org>
Am 05.02.2017 um 19:27 schrieb Klewlis:
Maybe it helps to recall that an animation's frames do not all have to
have the same hierarchical strucuture; for instance, you can use:
    #declare Part1 = box {...}
    #declare Part2 = box {...}
    #if (clock < 0.5)
        // move items individually
        object { Part1 rotate ... translate ... }
        object { Part2 rotate ... translate ... }
    #else
        // move items together
        union {
          object { Part1 }
          object { Part2 }
Date: 5 Feb 2017 13:39:38
Message: <5897716a$1@news.povray.org>
I would say that building a wall standing up is the way most people
build walls. ;-)
Regards
Date: 5 Feb 2017 13:43:00
Message: <58977234@news.povray.org>
>> }  // End of union
>> Regards
>>       Stephen
Although it is not recommended. You can use nested unions to have
various local transformation points.
Regards
Date: 5 Feb 2017 14:30:01
Message: <web.58977c586098c6675f9209890@news.povray.org>
> build walls. ;-)
> Regards
>      Stephen
actually, I framed houses for many years.  We always built the wall laying down
on the slab, then stood it up and nailed it in place.
Date: 5 Feb 2017 14:40:01
Message: <web.58977e9f6098c6675f9209890@news.povray.org>
clearly I don't understand how the clock works with animation yet.  When I
render I get the shed completely built on the first frame and 19 repeats of the
same scene.
