POV-Ray : Newsgroups : povray.animations : Western Wheel calculations Server Time
29 Apr 2024 03:40:11 EDT (-0400)
  Western Wheel calculations (Message 1 to 10 of 10)
Subject: Western Wheel calculations
Date: 29 Jul 2015 21:40:00
Message: <web.55b9804e97eff9955e7df57c0@news.povray.org>
So, I would normally just puzzle this out myself, but it's 98 degrees here
(Fahrenheit, not rotationally  ;)  ) and my gray matter is cooked.
Anyway, concerning the "Western Wheel" problem:
http://www.f-lohmueller.de/pov_tut/animate/anim13e.htm
I have a gear that turns 7 times in 37 frames.
(it drives a gear that turns once per 7 revolutions, I'm doing a quick "36"
frames, and cyclic animation is on - so it's 37)
It has 5 spokes, and 55 gear teeth.
I'm assuming I take 360 degrees, then divide by 55 teeth, and multiply by 7
revolutions to get the total apparent movement of a tooth.  Then divide by 37
frames to find the "apparent movement" of a tooth between frames in degrees.
The "Western Wheel limit" is half of the span between teeth per frame, so that
would be (360/55)/2.
If the first calculation is correct, then if it's less than the limit, I
shouldn't get the undesired visual effect.  Correct?
Could someone check my logic / math?
Subject: Re: Western Wheel calculations
Date: 30 Jul 2015 01:26:05
Message: <55b9b56d$1@news.povray.org>
37 frames, but 36 movements, before repetition ? or 37 distinct moves
(between frame n and n+1) and frame 38 is identical to frame 1 ?
I always get confused by that fence problem.
You mean the visual effect of the wheel moving backward when rolling
forward ?
I'm not sure my eyes wouldn't rather spot the spokes than the teeth.
You can also help my poor brain by having a spottable unique feature on
wheel (such as a valve or a big mark/hole), easier to track
> Thanks  :)
Date: 30 Jul 2015 07:15:00
Message: <web.55ba06b5231eda285e7df57c0@news.povray.org>
cyclic = on keeps the end frame and the starting frame from being identical and
"jolting when it hits that double-frame in the playback loop
> forward ?
Correct.
It will spot both - especially when the spokes seem to be moving forward and the
gear teeth moving in the opposite direction!
There an extension on one spoke with a crank handle - can't miss it!  :D
I'll likely also have some type of texturing, such that those small features are
asymmetric, and the eye will follow it all better.
So many other things to do - so little time to POV lately.
Date: 30 Jul 2015 08:50:26
Message: <55ba1d92$1@news.povray.org>
> Thanks  :)
Your grey matter is cooked? So is mine and it is cool here.
I will have a look at your calculations a bit later.
I did something similar a few years ago and uploaded it to youtube a
couple of years ago.
https://www.youtube.com/watch?v=BOjKESXP814
and
https://www.youtube.com/watch?v=XTBurdd1Ad4
I think that I did not want to see the gears going backward so I did not
do your type of calculations.
What I did do was to split the animation into cyclic parts.
For instance if in your animation the gear turns 5 times in the time
frame. Then you only need to code a fifth of the revolutions and repeat
that continuously. That way you can have a faster frame rate. This will
mean that the angle moved each frame is smaller.
With your figures each frame will rotate the gear 68.108 degrees. I see
a problem with that. Of course this technique relies on the symmetry of
the object.
The other thing is, using Pov's cyclic animation. You don't render one
frame less as PovRay does the donkey work in calculating the clock
delta. I think that is how it works but it is a long time since I have
used it.
Regards
Date: 30 Jul 2015 08:54:33
Message: <55ba1e89$1@news.povray.org>
A longer one
https://www.youtube.com/watch?v=VfVRnAHu4JI
Regards
Date: 30 Jul 2015 10:50:01
Message: <web.55ba38bc231eda285e7df57c0@news.povray.org>
> that continuously.
Well, the problem is that it takes 7 revolutions of the drive wheel to make the
slowest gear complete a single revolution - so I think I have to use that gear
as the basis for my animation.
That gear drive a 1:1 gear, which is coupled by a shaft to a 9-tooth gear, which
drives a 45-tooth gear.  So the last gear travels 1/7 the number of revolutions
(9/45).
I haven't gotten that far along to the finished arrangement yet - I wanted to
zip out a quick sparse-framed animation to take a gander at how it's coming
along before I started coding a lot of things that might need to be changed.
> used it.
I didn't think about it too much.  I plugged in 36 for number of frames and set
cyclic animation to on.   POV-Ray spits out 37 frames.  So be it. I could do 35
or 34.... I think it's irrelevant - though for smoothness I'll probably render
180-360 frames, depending on how it looks.
Thanks!  :)
Date: 30 Jul 2015 12:16:09
Message: <55ba4dc9$1@news.povray.org>
>> that continuously.
I would think so too.
> (9/45).
Oh! Joy. Odd numbers and primes. :-) Maybe there are no shortcuts.
Of course.
>> used it.
Does it? I never noticed it spiting out n+1 frames but it has been a
long time since I used it.
> Thanks!  :)
It's my pleasure. :)
Don't forget to post your results. I for one am interested.
Regards
Date: 30 Jul 2015 14:10:01
Message: <web.55ba67dd231eda285e7df57c0@news.povray.org>
OK, so the problem and its solution is clearer in my heat-addled brain.
I figured at some point I had to take into account the movement of an element
(spoke or tooth) by a multiple of the distance between adjacent elements.
So I used mod() to give me the remainder, and compared this number of degrees to
half the distance between adjacent elements.
I send that all out to a debug stream and get the data below - but it's wrong.
I get the Western Wheel effect with the gear teeth even though my calcs and the
"1/2 distance" theory agree.
Also, is "clock_delta" busticated in 3.7?  It never registers any value other
than zero over all 37 frames.
I use:
#declare Degrees = clock * 360;
and
// ROTATION FOR ANIMATION
// Clockwise = Negative
 rotate <0, 0, -(Degrees*7)>
Animation Information:
Number of frames: 37.0
Clock  Delta: 0.0
Wheel2652: 55.0
Degrees between teeth: 6.55
Gear tooth movement between frames: 68.1 degrees
Multiple: 10.405
Western Wheel limit between frames: 3.27 degrees
0.405 x 6.55 = 2.65
 10 x 6.545 = 65.455 + Remainder: (2.65) = 68.1 degrees
2.65 is less than 3.27
OK - Normal Movement
Wheel2652A: 5.0 (spokes)
Degrees between teeth: 72.00
Multiple: 0.946
Western Wheel limit between frames: 36.00 degrees
0.946 x 72.00 = 68.11
  0 x 72.000 = 0.000 + Remainder: (68.11) = 68.1 degrees
greater than 36.00
*** Western Wheel problem ***
Date: 30 Jul 2015 15:37:24
Message: <55ba7cf4$1@news.povray.org>
Lucky you :)
Mine is addled by medications :(
Distance not angle, or is that a figure of speech?
Oh national bird of America. ;)
Do you realise that this is taking me back 50 years to high school?
Are you trying to eliminate the effect or show it?
Also what frame rate are you encoding the animation? I think you have to
take that into account too (also).
Have you tried a test with a single wheel?
I've never had the need to use clock_delta so I can't help there.
> I use:
Hmm! I use frame_number and keep the clock range between 0 & 1. I find
that it is easier to modify things that way. When I want something to
happen at a particular time. Although it probably doesn't mater here.
> and
Widdershins! Dangerous!  ;)
I had a quick look at Friedrich's site (not the code) and I think that
you might be trying to correct two illusions at the same time. I would
either just concentrate on the spokes and let the gears look after
themselves or greatly increase your frame rate. So that both the gear
teeth and spokes only incrementally move between frames. Not more than a
sixth of a revolution as the spokes do.
Notice Friedrich used a solid gear so did not have your problem. Also
Friedrich did not use a cotter pin, or similar on the axle. That way he
did not have to run the animation for a full revolution of the large gear.
> Clock  Delta: 0.0
> Wheel2652: 55.0
> Multiple: 10.405
> 0.405 x 6.55 = 2.65
> Multiple: 0.946
> greater than 36.00
Regards
Date: 30 Jul 2015 19:15:01
Message: <web.55baaf37231eda285e7df57c0@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> Lucky you :)
In some instances, you could be the luck one :D
I suppose it's a figure of speech or just lazy language - since arcs of the
circumference are subtended by angles.
It's a sort of many-layered inside joke.
Our National Bird will likely soon be the turkey, or the vulture, or the dodo.
Right, where we should have paid better attention.  ;)
Eliminate it on all moving parts.
I figured if I could pre-calculate / predict the appearance of the effect, I
could just vary the number of frames rendered between clock 0 ---> 1 and get
something that would mesh well (ha!) with all the gear sizes.
It's in there, since that's how I calculate the degree of rotation between
frames.
No - it doesn't take that much time to render the whole scene, so I just let 'er
rip.
> > I use:
It's easier to keep track of things that rotate by assigning a full 360-degree
rotation to a full clock cycle.
> > and
I know, right?   I'm not the one who chose a Left-Handed coordinate system for
POV-Ray  :O
I suppose I'm trying to correct 5 illusions at the same time, since I have 5
different size gears (assuming the spokes and teeth of the drive gear are
visually separate)
>I would
I don't think letting the teeth look after themselves fixes the problem - I have
a narrow window to sync the rotation with the proper positioning.
A fifth of a revolution would give me a full overlap of symmetry - it would look
like only the handle was moving.  I'd have to stick with a tenth of a revolution
or below to comply with the "1/2 distance" theory.
Right, but that's a simple demo - the drive gear has to revolve 5 times (not 7
SMH) for the slowest gear to make one full revolution - no way around that.
I jacked the frames up 90, and most of it looks good except for the 3 15-tooth
gears.  I will keep at it.
