POV-Ray : Newsgroups : povray.animations : best to animate simple moving meshes Server Time
28 Apr 2024 13:45:24 EDT (-0400)
  best to animate simple moving meshes (Message 1 to 7 of 7)
Subject: best to animate simple moving meshes
Date: 16 May 2012 16:55:00
Message: <web.4fb413dcb833ef0692f3bd070@news.povray.org>
Hi Guys,
I am new to the povray community, and after reading the manual I am still not
sure what's the best way to achieve my goal:
I have a simulation written in c++ in which I simulate rigid bodies moving. In
each time step each body's position and orientation change.
I want to render my simulation using POV-Ray. What is the correct way? I can
output a pov file for each frame and then render each pov file and make an
animation.
However, as the meshes are rather large and do not change between frames (only
their orientation and position change), I hope there's a simpler way to just
write the mesh once and then reference it when producing the animation.
What is the best way to achieve my goal?
Subject: Re: best to animate simple moving meshes
Date: 16 May 2012 19:07:30
Message: <4fb43332$1@news.povray.org>
Am 16.05.2012 22:53, schrieb noam:
> Hi Guys,
> animation.
You can generate one include file (see "#include") for the shapes,
another one specifying their locations for each frame, and tie
everything together in a manually created .pov file.
Date: 17 May 2012 03:45:00
Message: <web.4fb4ac639fbc2e8e92f3bd070@news.povray.org>
> > Hi Guys,
> > animation.
Thanks! That solves almost everything, but how would I create an array for the
orientation matrices (I assume I would to create an array of matrices and then
index through it using 'clock')?
Date: 17 May 2012 10:02:07
Message: <4fb504df$1@news.povray.org>
If you just want to apply transformations to your object you can
create an array such as
#declare TRANSFORMS = array[42];
#declare TRANSFORMS[0] = transform {rotate 90*x translate 5*z};
#declare TRANSFORMS[1] = ...
and use it like this
object
   transform {TRANSFORMS[i]}
Of course you can also use a twodimensional array (or multiple
arrays) to holds the individual rotation and translation parameters
or matrix elements.
Date: 17 May 2012 10:13:03
Message: <4fb5076f$1@news.povray.org>
actually, since you have multiple objects you probably want
this to be something like
#declare TRANSFORMS = array[NUM_OBJ][NUM_TRANSFORMATIONS];
// Object 0
#declare TRANSFORMS[0][0] = transform {rotate 90*x translate 5*z};
#declare TRANSFORMS[0][1] = ...
// Object 1
#declare TRANSFORMS[1][0] = transform {rotate 40*x translate 5*z};
#declare TRANSFORMS[1][1] = ...
And in your shapes include file
#declare SHAPES = array[NUM_OBJ];
#declare SHAPES[0] = mesh {...}
#declare SHAPES[1] = mesh {...}
and use it as
#declare FRAME = <transformation index from "clock" or "frame_number">
#declare I = 0;
#while (I < NUM_OBJ)
   object
     SHAPES[I]
     transform {TRANSFORMS[I][FRAME]}
   #declare I = I + 1;
Date: 18 May 2012 09:53:09
Message: <4fb65445@news.povray.org>
> // Object 0
> // Object 1
  I think you can make it more concise:
{ { transform {rotate 90*x translate 5*z},
Date: 20 May 2012 12:00:01
Message: <web.4fb913fa9fbc2e8e34c116050@news.povray.org>
> > // Object 0
> > // Object 1
Thanks guys! I used something in the general notion of what you did.
