POV-Ray : Newsgroups : povray.animations : Earth by clearmap.tga Server Time
27 Jul 2026 12:13:22 EDT (-0400)
  Earth by clearmap.tga (Message 1 to 10 of 12)
Subject: Earth by clearmap.tga
Date: 3 Nov 2011 16:58:16
Message: <4eb30068$1@news.povray.org>
Just show the explanation of the PEGE symbol.
For this animation, I rendered Earth
by clearmap.tga as described in POV 1994.
This was fine at the resolution of this days,
but now, I would like a file like
clearmap.tga with a much higher resoltuion.
What source?
Subject: Re: Earth by clearmap.tga
Date: 3 Nov 2011 18:04:48
Message: <4eb31000$1@news.povray.org>
Le 03/11/2011 21:58, Roland Mösl nous fit lire :
> What source?
> Roland Mösl
For daylight with snow,
http://www.nnvl.noaa.gov/ddsimages/SnowIceCover_Daily.png
For nightlight, "earthlights dmsp" in wikipedia
(16,384 × 8,192 pixels at full resolution)
http://en.wikipedia.org/wiki/File:Earthlights_dmsp.jpg
For daylight,
http://commons.wikimedia.org/wiki/File:Land_shallow_topo_2048.jpg
(2048x1024 at full resolution)
Date: 4 Nov 2011 02:04:48
Message: <4eb38080$1@news.povray.org>
>> What source?
>> Roland Mösl
This picture would be optimal for spring or autumn
With all the snow, I would have to change the direction
of the earth axis to the winter postion.
> For daylight,
This in PNG and the resolution of the snow picture!
Roland Mösl
Date: 4 Nov 2011 13:55:46
Message: <4eb42722$1@news.povray.org>
Le 04/11/2011 07:04, Roland Mösl nous fit lire :
You need to learn patience... and sample it everyday of the coming year!
(or over five years ?)
>> For daylight,
Ratio 2:1 is usual for spherical projection.
Firefox report it as jpeg, and save it as such.
At least there is no clouds on it.
Date: 4 Nov 2011 19:32:38
Message: <4eb47616$1@news.povray.org>
It appears to be available as 21600 x 10800 TIFF (173.5MB)
http://visibleearth.nasa.gov/view_rec.php?id=2433
Date: 4 Nov 2011 19:50:59
Message: <4eb47a63$1@news.povray.org>
Actually, if you feel slightly insane, click on
"Details and more Imagery" to find a 43200 x 21600
version (split up in east and west image) ;)
Date: 5 Nov 2011 02:28:22
Message: <4eb4d786@news.povray.org>
  You may have trouble using that directly with POV-Ray because according
to my calculations it would consume about 3.4 gigabytes of RAM. (In a
64-bit system with significantly more RAM than that it might work ok.)
  That will most definitely be unusable as-is in most system, as it consumes
something like 14 gigabytes of RAM (hence you can only use it in a 64-bit
system if you have more RAM than that.)
Date: 5 Nov 2011 03:30:29
Message: <4eb4e615$1@news.povray.org>
Thanks! Just downloaded the 8192 x 4096 version
Roland Mösl
Date: 5 Nov 2011 19:04:01
Message: <4eb5c0e1$1@news.povray.org>
If it's 3 channel 8 bit I'd have expected something closer to 700 MB.
Date: 6 Nov 2011 01:55:02
Message: <4eb62136$1@news.povray.org>
Am 06.11.2011 00:03, schrieb Christian Froeschlin:
Indeed. For input images, POV-Ray has various internal storage formats
at its disposal to keep the memory footprint low, allowing it to choose
either 1, 3 or 4 channel(s) for greyscale, RGB or RGBA respectively, and
either 8 bit integer, 16 bit integer or 32 bit float precision per
channel. In addition there's also a 1 bit per pixel representation
available for black & white bitmaps.
