POV-Ray : Newsgroups : povray.animations : Simple animation-creation software? Server Time
9 Jun 2026 05:38:02 EDT (-0400)
  Simple animation-creation software? (Message 1 to 9 of 9)
Subject: Simple animation-creation software?
Date: 24 Sep 2009 20:23:52
Message: <4abc0d98$1@news.povray.org>
I'm looking for a command-line driven Windows software to throw a
sequence of image files together into a proper animation. Essentially
something to run via batch script after having run POV-Ray. Any
recommendations?
Subject: Re: Simple animation-creation software?
Date: 25 Sep 2009 00:22:18
Message: <4ABC44BE.9070304@joplin.com>
> recommendations?
Have you tried Cmpeg?
Date: 25 Sep 2009 00:52:35
Message: <4abc4c93$1@news.povray.org>
>> recommendations?
I just gave it a try, but alas! It will not run on my XP x64 machine.
Date: 25 Sep 2009 14:50:01
Message: <web.4abd10ba8e97becbcac4259f0@news.povray.org>
> >> recommendations?
I used to like Dave's Targa Animator.  I just tried running dta3.exe and
dtawin.exe on a Vista 64bit machine and they both ran.  I wish DTA were still
supported - I believe the latest version came out in 1999.  It doesn't support
mpeg but it can create .avi's which may be rather large and may best be used as
an intermediary format.  It's fairly versatile having a number of options and
supports .png up to 16 bit per channel including alpha.  Have you looked at
ffmpeg?
Charles
Date: 25 Sep 2009 15:10:14
Message: <4abd1596$1@news.povray.org>
> ffmpeg?
Looks like ffmpeg comes as source code only. With software natively
developed on Linux and Unix machines typically being awkward to compile
on Windows, I guess I rather pass on this, as long as nothing else pops up.
Date: 25 Sep 2009 15:54:09
Message: <4abd1fe1@news.povray.org>
Well, I found that they do have compiled binaries after all; looks like
exactly what I was searching for - thanks to Charles for pointing me in
the right direction!
Date: 25 Sep 2009 15:57:13
Message: <4abd2099$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4abc0d98$1@news.povray.org...
> I'm looking for a command-line driven Windows software to throw a sequence
> of image files together into a proper animation. Essentially something to
> run via batch script after having run POV-Ray. Any recommendations?
You might take a look at VideoMach (www.gromada.com). I used to use it all
the time for assembling my POV animations before I got sucked into the Adobe
Continuum. It's pretty easy to use, and it's got several command line
options. It's free to try out, and I think the mid-range version is
relatively inexpensive.
Date: 4 May 2010 16:35:01
Message: <web.4be084148e97becb926a7e230@news.povray.org>
I use virtual dub (http://www.virtualdub.org).  It is freeware and very easy to
use.
Date: 15 Jul 2010 01:50:01
Message: <web.4c3ea0338e97becb14f2c9f00@news.povray.org>
Another interesting option would be APNG Assembler:
http://sourceforge.net/projects/apngasm/files/
Dave's Targa Animator was great for creating FLIC files, but these days APNG is
more promising.
Command line examples:
apngasm output.png frame*.tga
apngasm output.png frame*.png 1 25
It creates apng from tga/png image sequence (frame delay is 1/25 sec in the
second example)
