POV-Ray : Newsgroups : povray.animations : bind the camera to a location of transformed objects Server Time
14 Jun 2024 04:41:13 EDT (-0400)
  bind the camera to a location of transformed objects (Message 1 to 3 of 3)
Subject: bind the camera to a location of transformed objects
Date: 19 Jan 2007 02:45:01
Message: <web.45b0762fe269e131bd8c5ded0@news.povray.org>
I am looking for a solution to get back the transformed location of an
object. I want to use that location as camera {location
MovedAnRotatedObjectLocation}.
I hoped to include the camera directly into the object hirarcy like
object{object{object1, object2,camera} translate<...> rotate <...>}
but that does not work.
Can anyone give me a hint to save transformed vectors in a deep hiracy and
work with them on the top-level (WCS) ie. camera relations?
Thanks.
Subject: Re: bind the camera to a location of transformed objects
Date: 19 Jan 2007 04:25:53
Message: <45b08ea1@news.povray.org>
"DevMan" <pet### [at] klemm-softwarede> wrote in message
news:web.45b0762fe269e131bd8c5ded0@news.povray.org...
> Thanks.
I suspect that the 'transform' directive will end up being the key to
achieving what you need.
You can assign an identifier to a transformation and re-use it as many times
as you like.
#declare MyTransform = transform {translate <-1,0,0> rotate <20,90,10>}
sphere {0,1 transform MyTransform pigment {color rgb 1}}
box {... transform MyTransform ...}
camera {... transform MyTransform ...}
You can build up complex transformations by applying additional
transformations on top of the first:
#declare MyTransform = transform {translate <-1,0,0>}
#declare MyTransform = transform {MyTransform rotate <20,90,10>}
and you can obtain the inverse of a given transformation using the 'inverse'
keyword:
#declare InverseTransform = transform {MyTransform inverse}
Chris B.
Date: 22 Jan 2007 02:30:01
Message: <web.45b46786d0b80ee6bd8c5ded0@news.povray.org>
> > Thanks.
> Hi,
> as you like.
> keyword:
> Regards,
> Chris B.
Hello Chris,
thank you. It works pretty good!
Best regards,
Peter
