POV-Ray : Newsgroups : povray.animations : Convert animation to MPEG or AVI - a detail Server Time
27 Sep 2024 20:22:36 EDT (-0400)
  Convert animation to MPEG or AVI - a detail (Message 1 to 9 of 9)
Subject: Convert animation to MPEG or AVI - a detail
Date: 13 Apr 2004 13:55:00
Message: <web.407c28a34e51b707251dc0800@news.povray.org>
Thanks for advices, but I forgot to say a thing: I use Linux, not Windows.
I'm trying to convert that PNG to MPEG/AVI with Kurumin (a brazilian port
from Debian)
Thanks
Subject: Re: Convert animation to MPEG or AVI - a detail
Date: 13 Apr 2004 15:00:28
Message: <407c38cc@news.povray.org>
> from Debian)
  The only true media player for linux, ie. mplayer, should be able to
do what you want (afaik it can create an avi from image files).
Date: 13 Apr 2004 18:01:58
Message: <cjameshuff-134931.18025213042004@news.povray.org>
In article <407c38cc@news.povray.org>, Warp <war### [at] tagpovrayorg>
mencoder, included with mplayer, can do this. However, I couldn't get it
to use PNGs correctly, I had to use TGA. And it's annoyingly complicated
and poorly documented.
Probably the easiest way is to use ImageMagick convert, but it doesn't
give you any control over the encoding (at least not that I've found).
http://tag.povray.org/
Date: 13 Apr 2004 19:39:48
Message: <pan.2004.04.13.18.40.30.94708@ednet.rvc.cc.il.us>
Have you tried using mpeg2encode?   that's what I've used in the past
to create animations.
David
dsf### [at] ednetrvcccilus
Date: 14 Apr 2004 00:20:00
Message: <web.407cbabe214f6e47251dc0800@news.povray.org>
> from Debian)
> Thanks
Thanks for all. mencode resolved my problem!
Date: 14 Apr 2004 15:50:34
Message: <407d960a$1@news.povray.org>
It does, and works well, although there are lots more knobs and switches
than I've bothered to really figure out.
>> Windows.
> Would not the PPMtoMPEG in pbmplus be able to do this? I can't imagine
> it runs on Windows and not Linux, given the whole package started on UNIX.
Date: 14 Apr 2004 15:52:52
Message: <407d9694$1@news.povray.org>
Cid,
Presuming you've tested under multiple players, could you post the
command line (and version of mplayer) that you used?
My attempts w/mencoder played fine in mplayer but the colors were
completely mucked up when viewing in some other players.
Thanks!
>>from Debian)
>>Thanks
Date: 16 Apr 2004 11:37:18
Message: <cjameshuff-A78AB5.11381716042004@news.povray.org>
In article <pan### [at] ednetrvcccilus>,
Not that I can recall...I'll look it up.
Date: 20 Apr 2004 12:37:42
Message: <pan.2004.04.20.11.38.39.634419@ednet.rvc.cc.il.us>
You can find it at ftp://ftp.mpeg.org/pub/mpeg/mssg
I used gimp to generate the config file for it.  check out povray.unix.
There was a discussion I was involved in dated 01/12/02 concerning some
problems I had with it
Good luck!
David
