POV-Ray : Newsgroups : povray.animations : Codecs Server Time
28 Sep 2024 22:18:38 EDT (-0400)
  Codecs (Message 1 to 10 of 11)
Subject: Codecs
Date: 7 Oct 2003 16:42:58
Message: <3f832552$1@news.povray.org>
OK, so a number of people have advised me to use DivX instead of any of the
other various AVI codecs I have... I would just like to say that I have now
tried this, and it appears that for the most part, DivX gives lower quality
with larger filesizes when compared to MPEG-1. (I'm sure someone's going to
come and tell me I've got it all wrong, but that's what I found.)
Of course, DivX has that many parameters you can adjust, it's hard to tell
what's going on... (Not like it tells you what any of it means or anything!)
But anyway, initially the results were aweful. Then I tried turning up the
maximum bitrate, and the quality improved. After a while though, turning it
up made no further difference - either to the quality or the filesize. I
suppose you have to do something to the other parameters or some such...
Then again, TMPGEnc has more parameters that you can shake a wet fish at!
But anyway...
Also, a lot of folks have said something about "MPEG-4 codecs"... Where the
heck do you find one of those? (Bearing in mind that I have no idea how the
codecs I *do* have got onto my system...)
Thanks.
Andrew.
Subject: Re: Codecs
Date: 7 Oct 2003 17:43:38
Message: <3f83338a@news.povray.org>
  Then all those people sharing videos in the net should promptly switch
to MPEG-1 instead of DivX... ;)
  Do you really think they are not using MPEG-1 for a good reason?-)
  DivX is one. You can also try Xvid (http://www.xvid.org/)
Subject: Re: Codecs
Date: 8 Oct 2003 04:43:27
Message: <3f83ce2f$1@news.povray.org>
In article <3f832552$1@news.povray.org> , "Andrew Coppin"
If you post a screenshot of the settings you used to povray.binaries.images
and ask for help finding good settings, I am sure somepeople will be able to
help you.  Or post a short animation povray.binaries.animations showing the
problems.
    Thorsten
e-mail: tho### [at] trfde
Subject: Re: Codecs
Date: 8 Oct 2003 05:01:50
Message: <k2k7ov4v3n96t1dalogk8bf3r8a36lecoq@4ax.com>
On Tue, 7 Oct 2003 21:40:04 +0100, "Andrew Coppin" <orp### [at] btinternetcom>
DivX has highier system requirements than MPEG-1 which I myself don't like.
At home I still poving actively with W95 on PII233 because that's what I own
at home while http://www.divx.com/divx/system_requirements.php .
ABX
Subject: Re: Codecs
Date: 8 Oct 2003 11:09:47
Message: <3f8428bb@news.povray.org>
They of course came with your operating system.  How else could they have
appeared there?  There are not little wizards that let appear codecs on all
computers at the same time by magic.  It would be kind of difficult ;-)
    Thorsten
Subject: Re: Codecs
Date: 8 Oct 2003 11:14:19
Message: <3f8429cb@news.povray.org>
Most likely there is a problem with the source material you have then.  It
could simply be unsuitable for modern compression algorithms.  I have
created a page that demonstrates this very well:
<http://mac.povray.org/support/video/>
NOTE: It will take at least another hour *after* I made this post to upload
all files to povray.org as I only have a ADSL connection with a 16 KByte/s
(128 KBit/s) upstream and some of the files are rather huge.  So please
don't tell me that some files are corrupted within the next two or so hours
- they simply didn't arrive on the server yet! :-)
    Thorsten
Subject: Re: Codecs
Date: 8 Oct 2003 11:40:54
Message: <trb8ov4jmskjs7gofdq5e8m49q086g3km1@4ax.com>
On Wed, 08 Oct 2003 17:09:32 +0200, "Thorsten Froehlich" <tho### [at] trfde>
Are you sure about this? Mr Gates says he employs lots of wizards :-}
Regards
Subject: Re: Codecs
Date: 8 Oct 2003 12:37:31
Message: <3f843d4b@news.povray.org>
In article <trb8ov4jmskjs7gofdq5e8m49q086g3km1@4ax.com> , Stephen McAvoy
Well, all the little wizards he has hired are busy magically getting your
money out of your pocket; they have no time to give you anything you want in
return.  There are however a few little evil wizards busy getting software
on your computer you do not want, but they only pretend to be from
Microsoft...  ;-)
    Thorsten
Subject: Re: Codecs
Date: 8 Oct 2003 15:35:06
Message: <3f8466ea$1@news.povray.org>
the
the
all
Well... sometimes it automatically downloads codecs for things... (It did it
just the other day in fact...) But that was for MediaPlayer... Hey, what do
I know? :-)
Subject: Re: Codecs
Date: 8 Oct 2003 15:37:04
Message: <3f846760$1@news.povray.org>
tell
anything!)
to
the
> problems.
OK, I might give that a go a bit later...
Thanks.
Andrew.
