POV-Ray : Newsgroups : povray.animations : Animation tutorial for linux users Server Time
28 Sep 2024 22:15:05 EDT (-0400)
  Animation tutorial for linux users (Message 1 to 8 of 8)
Subject: Animation tutorial for linux users
Date: 25 Jun 2003 09:07:17
Message: <3ef99e85$1@news.povray.org>
Hello eveybody,
This is to let you know about a tutorial I made regarding how to make
animations using POV under RedHat 7.3.  The page focuses on
visualization of chemical quantities (vibrational modes, to be exact),
but the info on how to take the frames and turn them to mpegs or
animated gifs is pretty general and may be useful to a wider audience.
The URL is:
http://www.geocities.com/quimico69/povray/Jmol_to_mpeg_tutorial.html
Comments welcome.
Victor
Subject: Re: Animation tutorial for linux users
Date: 16 Jul 2003 11:00:33
Message: <3f156891@news.povray.org>
Hi, thx for this howto.
Perhaps i can give you some adds:
Kpovmodeler is absolutely stable and comfortable for making .povs
Look at "povray.binaries.images" for an example i did with it..
With "mencoder" from "mplayer" you can easily make animations out of single
pictures or other formats to divX, mpg, avi, etc....
It supports over 160 (!!) codecs in my installation...
My greatest difficulty was, to find out the spline for the camera and the
"look_at" until i did it like that:
1. Take an visual modeler (kpovmodeler)
2. add the basic shapes of my scene
3. put 2 blobs in it
4. put in the first blob some balls that represent the camera-path
5. put some cylinders in the second blob for the "look_at"-point
6. as an option of blob, it is rendered smooth along the blobs, so it is easy to
see the resulting path.
7. Export it to ".pov"
8. extract the blobs and the points out of it
9. make the camera/look_at-spline with it
Date: 16 Jul 2003 12:07:56
Message: <3f15785b@news.povray.org>
> single pictures or other formats to divX, mpg, avi, etc....
But it can only _play_ 160 codecs, not encode them all, right?
Furthermore, it cannot encode multiple PNG files unless you
patch it in some crude way... (Took me several hours.)
Wolfgang
Date: 16 Jul 2003 13:10:41
Message: <3f158710@news.povray.org>
You're right, but encodes more than 20 codecs...
Just wrong. I did it like that ("mencode -mf someOptions:file=png").
Date: 17 Jul 2003 03:02:58
Message: <3f164a21@news.povray.org>
Yes but that does only work with divx for me. When using
lavc, the swscaler has to be used for colorspace conversion
and it introduces heavy disortion. You can get the same effect
by using (IIRC)
  mplayer -vo xv -mf on:w=640:h=480:fps=25:type=png "f000*.png" -vop rgb2bgr
In case you know how to encode multiple png files using
  -ovc lavc -lavcopts vcodec=mpeg4
I'd be very happy to know.
Wolfgang
Date: 17 Jul 2003 11:11:58
Message: <3f16bcbe@news.povray.org>
Just begin with a step-in-between, making a "rawrgb"-avi.
Then take the result as source and do whatever you want, no distortion then.
Be happy ;-)
Date: 17 Jul 2003 16:24:15
Message: <3f1705ef@news.povray.org>
> then.
Okay... but that's inacceptable for me because of the size of
the raw AVI.
I am using compressed PNGs and don't want to inflate the
complete film before finally compressing it.
The best solution then is probably to fix mencoder...
Wolfgang
Date: 14 Sep 2003 08:04:12
Message: <Xns93F651B07CE0APOVMIKA@204.213.191.226>
Florian Rustedt <flo### [at] rustedtde> wrote in
news:3f156891@news.povray.org:
> camera and the "look_at" until i did it like that:
> camera-path
> "look_at"-point
> blobs, so it is easy to see the resulting path.
This seems interesting, do you have a visual example of one
of your blob placements so that I may better understand you r
technique?
Kpovmodeler is for unix only from what I see, it looked
interesting :(
Thanks
Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
