![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Folks:
(modification of post in general)
I'm trying to figure out the best way to do an aquarium. I want to show
the 'ripple pattern' of light moving across the top surface of the water. I
want this to be in effect
a clear block (with an IOR) with a 'wavy' top surface.
The closest I have so far is an Isosurface, which looks good but when I
animate it I get something odd: 'phase' identifier in the wrinkles (or waves
or ripples) causes the surface to move *down* not across, so it causes a
concavity. I tried different combinations of functions, rotations, etc. and
it doesn't seem to work. An example - I replaced 'clock' in the phase with
a .5 so you can see what it looks like.
It's a neat effect but it's not what I'm looking for ;-)
Any suggestions?
== John ==
#version unofficial MegaPov 0.7;
#declare R=1.0;
#declare R1=R+0.01;
#declare Box = 1;
camera { location <5*R, 5*R, -8*R> look_at <0, 0, 0> angle 20}
sky_sphere { pigment {
gradient y
color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source {<100,200,-100> colour rgb 1}
#declare WaveDepth = .5;
#declare WrinklesFunc =
function {
pigment {wrinkles phase .5 // clock
color_map {[0 color rgb 0][1 color rgb 1]
turbulence .1
isosurface {
function {
//sphere
sqrt(sqr(x) + sqr(y) + sqr(z)) - 1 -
// y - // the xy plane...
WrinklesFunc(x, y, z) * WaveDepth
//contained_by{box <-R,-R/2,-R> <R, R, R>}
contained_by{sphere <0,0,0> R*2 }
pigment {rgb <.2 .2 .9 >}
finish {phong 0.5 phong_size 10}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"John D. Gwinner" <jgw### [at] hotmail com> wrote in message
news:3b4778d1$1@news.povray.org...
Changed your script code around a little and got a nice little water surface showing
caustics on
the ground below the isosurface.
#declare R=1.0;
#declare R1=R+0.01;
#declare Box = 1;
light_source {<50,200,50> colour rgb 1}
camera { location <5*R, 5*R, -8*R> look_at <0, -1, 0> angle 20}
gradient y
plane {y,-1.5
pigment {rgb 1}
finish {diffuse .75}
function {
pigment {ripples phase clock
} sine_wave //frequency -1
scale .5
turbulence .1
isosurface {
function {
y-(sqrt(sqr(x) + sqr(y) + sqr(z))// - 1
- WrinklesFunc(x, y, z) * WaveDepth)/10
// threshold .1
// eval
// accuracy .001
max_gradient 3
contained_by{box <-R,-R,-R> <R, R, R>}
material {
pigment {rgbf <.8, .9, 1, .75 >}
finish {phong 0.5 phong_size 50
// reflection .2
interior {ior 1.3 caustics 1 fade_distance .1 fade_color <.6,.8,1>}
I'm not savy enough to know why there is a overall concave surface, as seen when
wrinkles is used
instead of ripples. Mystery to me, sorry I couldn't solve that. However the surface
does move in
a way which you wanted I believe.
I animated it with that ripples pattern and it looked right enough to me. Well, I
take that back,
looks like somethings wrong with the container bounds but I'm not sure.
Bob H.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it John D. Gwinner who wrote:
>Folks:
> Any suggestions?
First let me tell you what's happening. The main awkward effect seems to
be that the wrinkles pattern produces values that are centred around
(phase + 0.5). So, when phase is zero you get numbers close to 0.5 which
is in the middle of the colour_map, but when phase is 0.5 you get
numbers that are close to 1.0 which is at the edge of the colour_map
where there's a sharp colour transition.
To see this, forget about the isosurface for a moment, and just paint
the wrinkle pigment onto a sphere
sphere {0,1
pigment {wrinkles phase 0.5 // clock
turbulence .1
When the phase is 0.0 you get gentle modulations of grey tones, but when
the phase is 0.5 you get black and white patches, as the numbers fall
off the end of the colour_map.
My rather inelegant fix for this would be to modify the colour_map with
the clock so that the output is centred in mid grey, like this
#declare my_clock = 0;
sphere {0,1
pigment {ripples phase my_clock// clock
color_map {[my_clock-1 color rgb 1]
[my_clock color rgb 0]
[my_clock+1 color rgb 1]
turbulence .1
Once the pigment is behaving itself sensibly, we can bung that
colour_map back into the isosurface function
function {
pigment {wrinkles phase my_clock // clock
turbulence .1
A second effect that was happening was that the black/white transitions
caused very sharp gradients in the function, and this exceeded the
default max_gradient. This shouldn't happen any more, but if it does you
can add "method 2 eval" to the isosurface to fix it.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Bob H. who wrote:
>"John D. Gwinner" <jgw### [at] hotmail com> wrote in message news:3b4778d1$1@news.p
>ovray.org...
>showing caustics on
> seen when wrinkles is used instead of ripples. Mystery to me, sorry I
> couldn't solve that. However the surface does move in a way which you
> wanted I believe. I animated it with that ripples pattern and it
> looked right enough to me. Well, I take that back, looks like
> something's wrong with the container bounds but I'm not sure.
The concavity is due to subtracting a sphere from the function. You've
got
function {
which is plane - (sphere - Wrinkles)/10
The concavity effect looks more pronounced when you use wrinkles because
the ripples are higher than the wrinkles. You can see the underlying
concavity more clearly of you temporarily set the WaveDepth to zero.
If we get rid of the spherical component
function {
y + WrinklesFunc(x, y, z) * WaveDepth/10
then we get ripples on a flat surface instead of a concave one.
Your fix for the main problem - adding sine_wave to the WrinklesFunc -
declaration also works for the wrinkles pattern, and is rather more
elegant than my shifting of the colour_map in phase with the clock.
Your container looks fine to me.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike:
Maybe I'm doing something wrong, but actually, y+WrinklesFunc doesn't work -
it's basically what I tried before (I used y-). It looks fine as a single
frame, but when you animate it the surface goes down. I'm posting the
animation in news:news.povray.org/povray.animations (not sure if that will
work)(Finally in MPEG format, using TMPGE).
I'm including the scene file below your post. I blended the sine wave and
the color map issues however, might take that out. I made the wave depth
slightly larger too.
#declare R=1.0;
#declare R1=R+0.01;
#declare Box = 1;
gradient y
light_source {<-100,200,100> colour rgb 1}
#declare WaveDepth = 1;
function {
pigment {wrinkles phase clock
color_map {
[ clock-1 color rgb 1]
[clock color rgb 0]
[clock+1 color rgb 1]
scale .2
translate <1, 0, 0>
turbulence .1
isosurface {
function {
y + WrinklesFunc(x,z,y) * WaveDepth/10
"Mike Williams" <mik### [at] nospam please> wrote in message
news:3SJ### [at] econym demon co uk...
> >ovray.org...
I
waves
a
etc. and
with
surface
> >showing caustics on
> got
> function {
> function {
> Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3b488a38$1@news.povray.org...
work -
Yep, that's curious. It isn't due to turbulence being used anyway, checked
on that.
Using just the regular color_map as before it undulates up and down. It is
as if phase effects the color_map or isosurface (or function) in a
unexpected way, as you described.
Although shifting the color_map as it goes might seem a solution I think it
more a bug rather than something to work around. Maybe someone has more
ideas on this, like whether the behavior is correct or not? Could it even
be related to the noise clipping?
Btw, the last sample of script had the function x,y,z written as x,z,y this
time so I put it back to x,y,z.
Bob H.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, thanks - I'd been playing with the functions to see what the effect was
so that's probably where the x,z,y came from.
I didn't think it was a bug exactly, I thought I was doing something wrong
How would we isolate the bug?
I was wrong about the news link, it's
news:news.povray.org/povray.binaries.animations, "Rot and Renewal". And now
that I check it, I had the x,z,y *lol*. Back to the IDE ..
== John ==
"Bob H." <omn### [at] msn com> wrote in message
news:3b489d64@news.povray.org...
> work -
single
checked
> on that.
is
it
this
> Bob H.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3b49b802$1@news.povray.org...
was
Well, being the mere end-user that I am there's not much to try except make
sure the surface level changes along the y axis as a whole instead of just
the pattern changes one would expect.
I put a semitransparent y plane across the isosurface and placed the camera
nearly parallel with it to see if the surface really does rise and fall as a
whole. It did. The amount of shift is small but I believe what is
happening is that the function is somehow changing the color_map or isn't
remaining stable.
That is to say, perhaps it brightens and darkens overall instead of only
shifting the color values around in a prespecified range. If you look at
the patterns themselves you will see the patterns like ripples or bozo (bozo
is especially obvious once animated) transform rgb 0 to rgb 1 while rgb 1
goes to rgb 0 along the pattern wave type.
We can only see the isosurface undulating though to prove or disprove
anything, since the patterns themselves as pigments look correct.
Try the script below if you like, I'm not absolutely certain wrinkles is the
only problemed pattern, granite looks awful when phased. As Mike Williams
has said it could be all in how the pattern equations are done, something I
know nothing about. But it looks as though all are subjected to the same
undulation of the isosurface and there isn't anything there I can figure to
cause it aside from phase.
Bob H.
now
#declare R=1.0;
#declare R1=R+0.01;
#declare Box = 1;
camera { location <5*R, 0.1*R, -8*R> look_at <0, 0, 0> angle 20}
gradient y
plane {y,.05 pigment {rgbf .7}}
plane {y,0
pigment {wrinkles // bozo // ripples // granite
color_map {
[0 color rgb 0]
[1 color rgb 1]
} sine_wave phase clock
scale .3
translate <1, 0, 0>
turbulence .1
finish {ambient 1 diffuse 0}
rotate -90*x
function {
color_map {
[0 color rgb 0]
[1 color rgb 1]
scale .3
translate <1, 0, 0>
turbulence .1
isosurface {
function {
y - WrinklesFunc(x,y,z) * WaveDepth/10
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, it turns out the iso surface 'water' works pretty well, but when it's
scaled up to be the surface of my aquarium, the spherical portion makes the
middle look 'lower'. I could probably fix this, but it's SLOW.
I've basically abandon'd my Isosurface at this point - a procedural
heighfield and Instersection seems to be working much better. Will post
results later.
== John ==
news:3b4a0bb8@news.povray.org...
> was
wrong
make
camera
a
> remaining stable.
(bozo
the
I
to
> Bob H.
> now
> #declare R=1.0;
> #declare R1=R+0.01;
> #declare Box = 1;
> gradient y
> plane {y,0
> color_map {
> [0 color rgb 0]
> [1 color rgb 1]
> scale .3
> translate <1, 0, 0>
> turbulence .1
> rotate -90*x
> function {
> color_map {
> [0 color rgb 0]
> [1 color rgb 1]
> scale .3
> translate <1, 0, 0>
> turbulence .1
> isosurface {
> function {
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
