POV-Ray : Newsgroups : povray.animations : Clipped_by slows rendering time Server Time
28 Jul 2024 12:27:22 EDT (-0400)
  Clipped_by slows rendering time (Message 1 to 4 of 4)
Subject: Clipped_by slows rendering time
Date: 15 Jan 2001 09:47:50
Message: <3A630D89.98BE93E9@yogi.unibas.ch>
does anyone have an answer to help me out here ?
I am trying to render an animation of the surface of a biological
molecule, which is composed of thousands of triangles.
The rendering of such an animation takes a few minutes per frame.
I would now like to cut the molecule half-open to see the interior,
while it rotates. If I introduce a
command, the rendering time decays to about 12 hours per frame.
The same slowdown happens, when I use the difference command.
Does anybody know how to speed this up ?
Thanks,
Hen### [at] unibasch
Subject: Re: Clipped_by slows rendering time
Date: 15 Jan 2001 11:03:49
Message: <3A631FB2.C9FCBDD5@pacbell.net>
mihm17 wrote:
> Hi,
> clipped_by { box { <-1000,-1000,-1000>, <1000,0,1000> }
The reason this is taking so long is because you are doing a csg
operation on 1000's of objects. Each object that is intersected
by the box must be evaluated seperately which greatly increases
the rendering time. You may be able to speed things us a bit by
manually bounding the object(s) in question but I doubt the increase
will be signifigant. If you can figure out a way to create your
molecule object out of a few primitive objects instead of serveral
thousand traingles you can probably speed things up quite a bit.
Subject: Re: Re: Clipped_by slows rendering time
Date: 23 Jan 2001 05:07:32
Message: <3A6D57E3.F19A6457@unibas.ch>
Thanks Ken.
I cannot reduce the number of triangles my scenery is composed of.
The biological molecule is that complicated, and the electron-microscopical
3D structure of that membrane-protein should be scientifically visualized
without simplifications or alterations.
I used now a
Pre_Frame_Commmand = my_clip %k
and clip the set of triangles outside of POVray. This works, and I can
calculate again
a frame in a few minutes.
BUT: Why is this faster than POVray can do ?
Is it that POVray is clipping the whole 3D scenery for every pixel/ray all
over again ?
Wouldn't it be much faster to once clip the 3D scenery while reading the
scene,
and then do the raytracing without further clipping calculations ?
Or is there a kind of Preprocessor incorporated into POVray ?
Yours, Henning.
Ken wrote:
> mihm17 wrote:
> > Hi,
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 23 Jan 2001 19:48:44
Message: <chrishuff-22ED47.19494023012001@news.povray.org>
In article <3A6D57E3.F19A6457@unibas.ch>, hen### [at] unibasch
> over again ?
> the scene, and then do the raytracing without further clipping
> calculations ?
POV can't do that, because it can't know that an intersection won't be
used until it computes that intersection. The necessary information just
doesn't exist until POV is tracing a pixel...
Hmm, I just thought of something...you may be expecting the scene to be
converted into triangles, which would be discarded at parse time.
POV-Ray traces most objects directly, solving the mathematical
representations of the objects, not converting them to a mesh of
triangles.
Christopher James Huff
