POV-Ray : Newsgroups : povray.animations : Building MPEG Server Time
28 Jul 2024 14:35:10 EDT (-0400)
  Building MPEG (Message 1 to 9 of 9)
Subject: Building MPEG
Date: 12 Oct 2000 16:08:36
Message: <39E61AAA.7C686F8@yahoo.com>
	I have been using mpeg2encode for a few months now and this is the only tool
I've used at all for encoding MPEG from pictures.
I was wondering two things,
 1) what are the software for linux that are capable of encrypting a good
animation for the IRTC. (ie: valid encryption)
 2) what are the software for linux that are capable of encrypting an animation
with the Best quality of frames and still a bit of compression (I'm talking
about mpeg, not avi...)
And then, are there software for linux that can do both?
I've looked at the utility page on www.povray.org, but geez, I'd have to try
them all??  But maybe you already examined some of them?
Thanks,
	Simon
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Subject: Re: Building MPEG
Date: 16 Oct 2000 09:53:51
Message: <39eb086e@news.povray.org>
Encrypting and encoding are two different things.
Date: 17 Oct 2000 00:35:56
Message: <39EBD761.B58A1F6E@yahoo.com>
Hmmm, yes indeed.  I must have made a mistake, but I'm sure you understood I
meant "encoding"! (Converting a serie of pictures to a single movie file)
Thanks,
	Simon
Date: 30 Oct 2000 12:31:43
Message: <39FDB1CF.6DB2BD63@free.fr>
<french>
Salut Simon ;-)
</french>
	What's wrong with the MSSG encoder ? What do you mean by valid encoding ?
The mpeg2encode tool is supposed to give you "valid" files since it has been
used for the test models of the MPEG Commitee.
	There are several ways to improve quality of an encoding, in general
sense, not only with this tools. Parameters depend on which models you want
to use (MPEG-1 or 2), the bitrate you need, the type of source (TV caps, CG
animation, ...) and much more. I could manage having correct results in MPEG-2
with this tool while tweaking default parameters carefully.
	Under Linux, I don't know much good softs for encoding, but there's
one that rules in Windows platform: TMPGEnc. It's free until now, best quality
ever - even commercial softs can't cope with it. Produces VCD/SVCD/DVD(NTSC)-
compliant video streams. It's a japanese soft, but there are english ressources
for it (patch) until the author switch to an english version (should be the
next release).
Current TMPGEnc website:          www.yks.ne.jp/~hori/TMPGEnc.html
Future location (not ready yet):  www.tmpgenc.com
English ressources:               www.jamsoft.com/tmpgenc/ [check this one first]
	Note: I posted similar infos in p.unix a few months ago in the
"mpeg_encode Berkeley" thread (2000-08-20)
	Believe me, you should try it, it's also very fast. Input in from AVI
stream, but you can easily make it from TGA files.
	This soft, a few other tools, and DVD players are the only reason for
me to keep windoze on my PC ;-)
*** Nicolas Calimet
*** http://pov4grasp.free.fr
Date: 30 Oct 2000 21:53:03
Message: <39FE4237.95292610@yahoo.com>
> next release).
My problem is that I don't have windows, and currently only have mpeg2encode, I
was wondering if there were any other software for linux that could give best
results... I'll try working with mpeg2encode, but if you know any other, please
post it!
Thanks,
	Simon
Date: 4 Nov 2000 22:09:35
Message: <3A04CF68.50061D2A@ij.net>
Simon Lemieux wrote:
> Hi,
	I have since found mpeg_encode compiled for linus if you want to give
it a try.
I will sing you the ballad of the lost C'mell.
	-- The Iron Webmaster, 226
Date: 6 May 2001 20:51:47
Message: <3af5f1a3$1@news.povray.org>
good
been
Since Simon used the terms "IRTC" and "Valid" in the same sentence, I'll
assume he meant the following (from
http://www.irtc.org/anims/rules.html#anims ):
Only MPEG-1 format animation files are acceptable. "I", "P", and "B" frames
are permitted.
The MPEG file must be less than 5mb (5,242,880 bytes) in size.
The MPEG file may have any frame size or frame count. We recommend frames of
320x240 pixels, however, based on current widespread hardware and software
limitations.
well, I guess that's not too restrictive, save that MPEG-2 is a no-no.
Date: 22 Oct 2001 22:29:35
Message: <3bd4d60f$1@news.povray.org>
I tried to install TMPGEnc and it crashed some software on my computer.
TMPGEnc never did work and I had to do a full restore to get my system
straight.  I'm using Win2000 on a  1.4GHz P4.  Could be fluke, of course,
but there seem to be enough encoder candidates out there such that it will
be awhile before I try that one again.
r
"Nicolas Calimet" <pov### [at] freefr> wrote in message
news:39FDB1CF.6DB2BD63@free.fr...
> <french>
> Salut Simon ;-)
> </french>
the only tool
good
animation
talking
been
want
CG
MPEG-2
quality
VCD/SVCD/DVD(NTSC)-
ressources
the
> next release).
first]
> *** Nicolas Calimet
Date: 13 Jul 2002 05:09:11
Message: <3d2fee37$1@news.povray.org>
I use bmp2avi and that works swell.  Even allows you to use your own codec.
Is a win32 command line tool, maybe lindows will run it????
-Zach
"Michael Yecchh" <som### [at] anywherecom> wrote in message
news:3bd4d60f$1@news.povray.org...
> r
> > <french>
> > Salut Simon ;-)
> > </french>
> the only tool
> good
> animation
> talking
> been
> want
> CG
> MPEG-2
> quality
> VCD/SVCD/DVD(NTSC)-
> ressources
> the
> > next release).
one
> first]
> > *** Nicolas Calimet
