POV-Ray : Newsgroups : povray.animations : Move fast then slow down? Server Time
28 Jul 2024 14:32:19 EDT (-0400)
  Move fast then slow down? (Message 1 to 10 of 12)
Subject: Move fast then slow down?
Date: 2 Aug 2000 20:00:16
Message: <3988B602.BAF223EA@acns.fsu.edu>
I'm very new to povray(less than two weeks) but I'm making great
strides. I just need help with one part of an animation that I doing.
Here is the code and see if you can help me out with the last part
please. (the ? is at the bottom)
   #if ( clock <= 1 )
    camera { location <1.4, 11.5, .11>
             look_at <1.4, 0, .11>
      translate <0,-clock*9,0>
    #else
     #if (clock <= 2)
      #declare Clock1 = clock -1;
      camera { location <1.4, 1.70, .11>
              look_at <1.4, 0, 1>
     rotate <Clock1*-65,0 , 0>
     //translate <0, -clock*1,0>
     #else
      #if (clock >2)
       #declare ElseClock = clock - 2;
       camera { location <1.4,.9, -1.5>
               look_at <1.4, .9, 1>
        translate <0,0,-2*1>
        rotate <0,0,0> }
 I want the camera to move back fast at first but then slow down. Can
anyone help me out. Also(This isn't as bad a problem) can anyone suggest
on how to smooth out the whole operation. There is a text object  that
the camera dives down on the rotates back to show the message then I
want to to fly off backwards then slowdown. If I'm not getting my point
across email me at
sjs### [at] garnetacnsfsuedu
Thanks
    Shawn
Subject: Re: Move fast then slow down?
Date: 2 Aug 2000 20:32:49
Message: <3988BD8D.2974105C@yahoo.com>
chris colfax has an animation setup for pov that includes all kinds of
acceleration and deceleration.  find a link to it from the pov links at
pov.org.  don't reinvent the wheel.
>    #if ( clock <= 1 )
>     #else
>      #if (clock <= 2)
>               look_at <1.4, 0, 1>
>      #else
>       #if (clock >2)
>         rotate <0,0,0> }
>      #end
>      #end
>      #end
> across email me at
> Thanks
>     Shawn
Date: 2 Aug 2000 22:49:43
Message: <3988ddc7@news.povray.org>
"ryan constantine" <rco### [at] yahoocom> wrote in message
news:3988BD8D.2974105C@yahoo.com...
Exactly.  Were you to use the ClockMod.inc file you would put:
#declare clock_type="D"
#include "clockmod.inc"
#declare Decel=mclock;
Then use Decel in place of 'clock' where you want the deceleration.
To combine different types just add this:
#declare clock_combine="W"
before the include line and you will get a wave, or back and forth movement
that also slows down.
Also using separate declarations for individual parts of movement too:
#declare clock_type="W"
#declare Wave=mclock;
and put those in where most likely to go, like one for z translation and
other for y.  Hope that made sense.
Plenty is possble just using the include, but there is a macro now too.
Date: 3 Aug 2000 13:38:48
Message: <3989AE8C.7C382C68@t-online.de>
Yep! The macro is very powerful and handy. Try it out.
Karl
Date: 3 Aug 2000 14:06:39
Message: <3989B2F2.A21E9AA0@pacbell.net>
Colefax - http://www.geocities.com/SiliconValley/Lakes/1434/
Date: 3 Aug 2000 15:41:51
Message: <3989CB06.D6B6E14E@aol.com>
The macro absolutely rules.  Not only did he invent the wheel, he
perfected it as well. ;)
-Mike
Date: 3 Aug 2000 18:16:16
Message: <3989EE7F.1EE9EBF8@spiritone.com>
But some of us like reinventing the wheel. Honestly.
I have a poorly defined system for this, but it kind of explains how to
do it yourself at
http://www.spiritone.com/~english/animaker/animaker.html
Josh
> -Mike
eng### [at] spiritonecom
Date: 4 Aug 2000 07:50:13
Message: <398AACC4.2075B0D0@my-dejanews.com>
First of all, the clock moves from 0 to 1, so the code you posted will meet
problems.
If you want something to move quickly at first then slowly, say:
    translate <0,-sqrt(clock),0>        //think how y=sqrt(x) varies from 0
to 1
If you want something to move slowly at first then speed up, say:
    translate <0,-sqr(clock),0>        //think how y=sqr(x) varies from 0 to
1
Date: 4 Aug 2000 11:29:34
Message: <p5olos0mhvoh0qnmmg5ssj0dd2os0molaf@4ax.com>
On Fri, 04 Aug 2000 07:45:08 -0400, "Greg M. Johnson"
>problems.
Not necessarily true, it defaults to [0..1] but you can adjust it by
the +ki and +kf switches.
Peter Popov ICQ : 15002700
Date: 4 Aug 2000 11:31:01
Message: <398AE18F.C55947A5@yahoo.com>
or change the start and end in your ini file.
> >problems.
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
