POV-Ray : Newsgroups : povray.animations : instant appearance Server Time
28 Jul 2024 14:20:28 EDT (-0400)
  instant appearance (Message 1 to 9 of 9)
Subject: instant appearance
Date: 18 Apr 2000 12:54:26
Message: <benboomREMOVE_THIS_PART-C83EF9.09511318042000@news.povray.org>
I am wondering how to go about having an object appear instantly in a
POV animation. Specifically, I am working with moving light sources
(death rays, as it happens :-) that appear at the snout of a ray gun and
then fly off. Currently I am using some really inelegant ways of doing
this, such as putting them really far away then translating them into
ground, but there must be a better way.
Thanks,
RA
Subject: Re: instant appearance
Date: 18 Apr 2000 13:42:29
Message: <38fc9e85$1@news.povray.org>
I would use the clock like this:
#if (clock > .5)
 object(laser)
#endif
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
"Rick Adams" <ben### [at] xprtnet> wrote in message
news:benboomREMOVE_THIS_PART-C83EF9.09511318042000@news.povray.org...
> Thanks,
> RA
Date: 18 Apr 2000 19:00:32
Message: <benboomREMOVE_THIS_PART-C33E4F.15571918042000@news.povray.org>
In article <38fc9e85$1@news.povray.org>, "Mike Weber"
> #if (clock > .5)
>  object(laser)
> #endif
Thanks!. Very simple; I like that.
Date: 18 Apr 2000 22:03:21
Message: <38fd13e9@news.povray.org>
If you want multiple instances the thing to do is use #switch with #range.  These
directives are practically made for
animation.  Example:
#switch (clock)
#range (0.3,0.5) // for a 0 to 1 clock
// do the ray here
#break
news:benboomREMOVE_THIS_PART-C33E4F.15571918042000@news.povray.org...
| > #if (clock > .5)
| >  object(laser)
| > #endif
Date: 18 Apr 2000 23:04:58
Message: <benboomREMOVE_THIS_PART-4A86B9.20014518042000@news.povray.org>
In article <38fd13e9@news.povray.org>, "Bob Hughes"
> #range.  These directives are practically made for
> animation.  Example:
> #switch (clock)
> // do the ray here
> #break
> #end
Does that mean that the other example won't let you do multiples? I used
it in my currently rendering animation, but just once, and it seemed to
work fine and I can't see why you couldn't use it for multiple death
rays, or whatever. What is the advantage this way? (I know there must be
one, I just don't see it.)
RA
Date: 18 Apr 2000 23:12:10
Message: <38FD23C3.DF54931C@pacbell.net>
> > animation.  Example:
> > #switch (clock)
> > // do the ray here
> > #break
> > #end
> RA
I don't do much animation work but I believe the difference is that the
first example will cause the death ray to appear at clock cycle 0.5 and
persist until it reaches a value of one - until the last frame of the
animation. With the second example you can have the death ray appear at
a clock value of 0.3 and then dissapear at the clock value of 0.5. The
second method offers a little more flexibility than does the first.
Date: 19 Apr 2000 00:08:27
Message: <38fd313b@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message news:38FD23C3.DF54931C@pacbell.net...
That's pretty much it, and for simplicity really.  You have to start nesting those
"#if" directives to get the same
result.  Can get difficult to follow.
Date: 19 Apr 2000 10:53:42
Message: <benboomREMOVE_THIS_PART-1A7DD9.07502819042000@news.povray.org>
In article <38fd313b@news.povray.org>, "Bob Hughes"
> nesting those "#if" directives to get the same
Okay, I understand. It wasn't an issue in the animation I'm doing now
since I send the death ray off out of the picture, never to be seen
again (it's more like the rays they used in Forbidden Planet, it you
remember that one), but your way makes them able to disappear on cue,
too. That's probably lots more useful for most apllications.
Thanks, everybody.
Date: 19 Apr 2000 14:25:40
Message: <38fdfa24$1@news.povray.org>
A good example would be a flashing light.
Mike
news:benboomREMOVE_THIS_PART-1A7DD9.07502819042000@news.povray.org...
the
and
at
> Thanks, everybody.
