POV-Ray : Newsgroups : povray.animations : Rotating earth SPECIAL VERSION Server Time
28 Jul 2024 16:31:40 EDT (-0400)
  Rotating earth SPECIAL VERSION (Message 1 to 6 of 6)
Subject: Rotating earth SPECIAL VERSION
Date: 2 Mar 2000 18:13:41
Message: <38BF75C8.78D36056@wxs.nl>
I want to make an animation of a rotating earth, with some extra's:
Somewhere on the net I found high-res pictures of the earth "by day" and
"by night". My idea is to combine these pictures on one rotating sphere.
In my opinion, this is not a trivial task. Has someone experience with
this? How can I set this up?
Please send your answer and/or comments to my e-mail adress
jan### [at] wxsnl
Subject: Re: Rotating earth SPECIAL VERSION
Date: 2 Mar 2000 19:37:00
Message: <38bf092c$1@news.povray.org>
If I were to do this I would paste the two pictures together using picture
editing software.
Mike
"A. Jans-Beken" <jan### [at] wxsnl> wrote in message
news:38BF75C8.78D36056@wxs.nl...
> jan### [at] wxsnl
Date: 3 Mar 2000 07:07:52
Message: <38bfab17@news.povray.org>
You could use a gradient texture map. On one side of the sphere is one of
the image maps and on the other is the other image map. A small area between
then could fade from one to other.
Date: 3 Mar 2000 11:58:17
Message: <38bfef29@news.povray.org>
"Nieminen Juha" <war### [at] sarakerttunencstutfi> wrote in message
news:38bfab17@news.povray.org...
I emailed this same thing as an easy way last night but having since tried it
out it doesn't appear to be a plausible way to go.  The other way I had said was
how I had actually done it before by using layered textures and two spheres.
The problem in the texture_map method is with the map_type needing to be
spherical and when placing the gradient texture_map of the two images onto the
sphere they no longer fit right.
Date: 6 Mar 2000 12:54:24
Message: <38C3F0CA.BA3D632D@spiritone.com>
This is from my cyclopedia:
 Ron Parker provided this solution, which he derived from Chris Colefax:
  #macro DoubleImage ( front,back )
    radial
    pigment_map {
      [ .5 front ]
      [ .5 back rotate 180*y ]
  #declare f=pigment { image_map{ sys "heads.bmp" once } translate -.5 }
  #declare b=pigment { image_map{ sys "tails.bmp" once } translate -.5 }
  #declare coin = cylinder {
    -.1*z,.1*z,1
    texture { pigment { color rgb 1 } }
    texture { pigment { DoubleImage(f,b) } }
You will need to adjust the pigments, and getting them to rotate could be
tricky. I would think that the globe would rotate, and as the images move
across the terminus, it is displayed with the other image. Since that was a
bit glib, what I mean is that we see, say. New York at night, then as the
world turns we see it in the daytime map
Josh
> jan### [at] wxsnl
Josh English
eng### [at] spiritonecom
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
Date: 10 Mar 2000 18:22:36
Message: <38C983E9.8E24DE0@ij.net>
	I'd start by trying two clipped hemispheres, one with each map
and rotating them both the same amount.
