POV-Ray : Newsgroups : povray.animations : animation tracks for armour vehicul Server Time
28 Jul 2024 18:12:47 EDT (-0400)
  animation tracks for armour vehicul (Message 1 to 10 of 11)
Subject: animation tracks for armour vehicul
Date: 6 Sep 1999 10:56:20
Message: <37d3d614@news.povray.org>
Can somebody help me to design pov files.
It is about an animation of tracks from track vehicule.
I would like to know how to positioned each element.
And to animat all of them for when vehicule started and
go on a plane road.
It seems hard to me ( i have not found solution since few month . . . ) to
make this.If you want more information on my tracks and the nature of the
vehicule my e-mail is j_b### [at] yahoocom
I am not good in english speaking so excuse me.
Some explications or ideas are wellcome.
BOGUET Jerome
Subject: Re: animation tracks for armour vehicul
Date: 8 Sep 1999 18:47:12
Message: <cebWN=h=SpHzhWbSJKMPgIwKwl7K@4ax.com>
>go on a plane road.
>BOGUET Jerome
How about this as a start?
// POV program for animated tracks
//  David Wilkinson  8 Sept 1999
global_settings
  assumed_gamma 1.0
camera
  location  <2, 3, -8.0>
  direction 1.5*z
  right     4/3*x
  look_at   <2, 1,  0.0>
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
  <-60, 60, -30>
  color rgb 1
light_source
  <60, 60, -30>
  color rgb 1
#declare Pitch=0.4 // pitch of track treads
#declare R1=20*Pitch/(2*pi); // radius of end wheels
#declare Dist1=4; // distance between end wheels
plane { y, -(R1+Pitch/2) pigment {color rgb <0.7,0.5,0.3>}} // ground plane
union {
// bottom of track
      #local Count=0;
      #while (Count<10)
         box { 0, <Pitch/2,Pitch/2,1> translate <Pitch*(Count-clock),-(R1+Pitch/2),0>}
         #local Count=Count+1;
// LH end of track
      #local Count=1;
      #while (Count<11)
           translate -(R1+Pitch/2)*y
           rotate -z*degrees((Pitch/R1)*(Count+clock))
// RH end of track
      #local Count=0;
      #while (Count<11)
           rotate z*degrees((Pitch/R1)*(Count-clock))
           translate Dist1*x
// top of track
      #local Count=0;
      #while (Count<9)
         box { 0, <Pitch/2,Pitch/2,1> translate <Pitch*(0.5+Count+clock),R1,0>}
  pigment { Red }
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 9 Sep 1999 04:24:23
Message: <37d76eb7@news.povray.org>
.......Ok.
Tanks for answer.
I will test this and send  youeventuals questions.
You have find this solutions in how many time ! ?
I think is very hard to me to find solution but you have
find it in short time !
See you soon ,
Jerome BOGUEt
Date: 10 Sep 1999 11:52:43
Message: <37d9294b@news.povray.org>
Hi ,
It seems to be one solution , the solution for this probleme , the first.
If my tracks is more complexable the actual tracks , can you help me one
more time ?
It is to have , not a plane tracks on the up tracks and with a different
path for end wheels right and left.
Would you like to see the whole tracks' path ?
BOGUET Jerome
Date: 10 Sep 1999 12:08:56
Message: <37D92CB9.AF214631@pacbell.net>
BOGUET wrote:
> Hi ,
> more time ?
> BOGUET Jerome
You are searching for a trapezoid shaped track path. Yes/no (?)
 _________________
 \_______________/
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 10 Sep 1999 16:58:54
Message: <zHDZN34UTmxX96Pq6vLYCrFwCaXG@4ax.com>
>more time ?
Yes, please let us see all the geometry of the tracks.
David
Subject: the path . . .
Date: 13 Sep 1999 10:03:55
Message: <37dd044b@news.povray.org>
Download 'tracks.jpg' (16 KB)
Preview of image 'tracks.jpg'
Date: 13 Sep 1999 10:29:28
Message: <37dd0a48@news.povray.org>
You should have said to see it over at p.b.i., David   ; )
What's needed is a spline curve to place the individual tractor treads
on.  Colefax's Spline Generator should do well for such a thing.  Just
position some key points at the wheels (may need a few points each to
get the proper bend and straightening) and a couple perhaps for the
sag at upper part.
I've always wanted to do one of these myself so maybe I'll give it a
go and if you can't get it right yourself I could post the script
later, but may be a long wait.
David Wilkinson <dav### [at] cwcomnet> wrote in message
news:zHDZN34UTmxX96Pq6vLYCrFwCaXG@4ax.com...
> David
Date: 23 Sep 1999 05:46:52
Message: <37e9f70c@news.povray.org>
Thought I'd try and locate this message post again so I could reply.
I was looking into doing something like this myself long ago and again
because you brought it up here.  I figured the Spline Generator from
Chris Colefax would suffice easily enough.  Wrong.  It fails to
animate a continuous track for some reason unknown to me.  It drops a
position (tractor tread) out every frame of the animation.  Well maybe
there's still hope in the future, Chris has stated he may have a
Spline Generator for POV-Ray 3.1 someday soon, perhaps the fix will
appear then.
boguet <j_b### [at] yahoocom> wrote in message
news:37d3d614@news.povray.org...
> go on a plane road.
. ) to
of the
> BOGUET Jerome
Date: 24 Sep 1999 05:38:32
Message: <37eb4698@news.povray.org>
> appear then.
Without seeing your code I couldn't say for sure why the include file might
be missing a tread - are you using a direct spline clock counter (between 0
and 1) to return the tread positions?  In this case you might find that
rounding errors are causing the last tread to be skipped.  I would usually
recommend using an integer counter, from which you can calculate your spline
clock value, eg:
   #declare Steps = 100;
   #declare Counter = 0; #while (Counter <= Steps)
      #declare spline_clock = Counter/Steps;
   #declare Counter = Counter + 1; #end
More importantly, I do indeed have a complete Spline macro system pretty
much waiting to go, but after posting a description on my site I had the
crazy idea of completely rewriting the memory usage to take advantage of an
apparently undocumented feature of POV-Ray arrays.  Fortunately all went as
planned, and I even managed to add a couple of extra features (such as
latest message I've posted a track preview animation in
details...
