POV-Ray : Newsgroups : povray.animations : Server Time
28 Jul 2024 20:34:16 EDT (-0400)
   (Message 1 to 2 of 2)
Subject:
Date: 23 May 1999 11:10:52
Message: <37480c6c.0@news.povray.org>
I'm quite new to animation in POV (for Windows) and got stuck on this
problem a few times.
Suppose I made a cylinder, originating in <0,0,0> and ending in <0,1,0>.
Including the cylinder and a sphere at the end of it in a object, gives me a
stick-like object. When I would rotate the stick around, say, the Z-axis, is
same scene.
Thanks in advance,
Remon Koopmans,
the Netherlands.
Subject:
Date: 23 May 1999 14:20:52
Message: <37483807.3392147@news.povray.org>
On Sun, 23 May 1999 15:17:20 +0200, "Remon Koopmans"
>same scene.
The tools you want are vrotate and vaxis_rotate.  Look under vector
functions in the docs.  Vrotate will give you the new coordinates
resulting when you apply a rotation (about <0, 0, 0> = "rotate <a, b,
c>") to a point, and vaxis_rotate will do the same if you give it an
arbitrary axis of rotation and number of degrees.
Jerry Anning
clem "at" dhol "dot" com
