POV-Ray : Newsgroups : povray.advanced-users : Object's rotation matrix Server Time
8 Jan 2025 15:25:58 EST (-0500)
  Object's rotation matrix (Message 1 to 8 of 8)
Subject: Object's rotation matrix
Date: 16 Mar 2015 15:45:01
Message: <web.5507318a24dc4c18b91df8500@news.povray.org>
Is there a way to find out/obtain/get object's "rotation matrix" so it can be
applied to another object?
Subject: Re: Object's rotation matrix
Date: 16 Mar 2015 16:26:26
Message: <55073c72@news.povray.org>
Am 16.03.2015 um 20:39 schrieb bublible:
Nope, sorry. You'd need to modify POV-Ray's source code for that stunt.
(And, knowing that you're wrestling with LDD-to-POVRay, that won't get
you anywhere either because the tool is designed in such a way that
scenes won't render with an unofficial version of POV-Ray. Did I mention
before that the tool sucks big time?)
Date: 16 Mar 2015 17:10:00
Message: <web.550745dab66bd306b91df8500@news.povray.org>
yea you did mention it but it didn't help me much in solving my problem so I did
not care to reply, sorry :D
anyway, there have to be some way as I have here one script dealing with
automatic rotation of background (ehm, actually a box functioning as background)
that expands and face directly to camera nevermind cameras position which is
basically what I want but I want just one axis to be corresponding to the camera
axis in oposite angle as my polygon is rotate<0,0,0> and I want it turns to
directly to camera but only on its y axis (I got gradient polygon functioning as
a base plane and I need its gradient would always go from camera to the distance
far away independently of LDD/camera rotation)
Date: 16 Mar 2015 21:23:03
Message: <550781f7$1@news.povray.org>
Am 16.03.2015 um 22:06 schrieb bublible:
Even if you had replied, I'd have happily taken the opportunity to again
point out what I think of the LDD-to-POVRay tool ;)
If you can get that far from whatever parameters there are floating
around in the scene, then here's what I'd do:
(1) Transform a unit vector (x or z, depending on the original
orientation of the model) according to the rotation matrix, using the
vtransform() function.
(2) Take the resulting vector, and multiply it by <1,0,1>.
(3) If needed, normalize the resulting vector using vnormalize().
=> Voila, you should now have rotated the original vector around the y axis.
If what you need is a rotation rather than a rotated vector, continue as
follows:
(4) Compute the cosine of the angle between the (normalized) rotated
vector and the original vector by computing the dot product, using the
dot() function.
(5) From the cosine of the angle, compute the angle in radians using the
acos() function.
(6) If needed, compute the angle in degrees by multiplying with 180/pi.
(7) If you find that the rotation doesn't fit, try inverting the sign.
I hope this helps.
Date: 17 Mar 2015 08:05:01
Message: <web.550816b9b66bd306b91df8500@news.povray.org>
> follows:
> dot() function.
> acos() function.
> I hope this helps.
:-D looks like you really know what you are talking about much more than I am
able to understand fully at this point, I'm afraid...
So could you elaborate more on this, or even better if it doesn't bother you
much: could you provide some fictional example here (you know, I would just
replace corresponding values in it in my script)?
BTW aren't you on Eurobricks.com (if so I would include you in credit for the
help woth the script as I will post it there including complete tutorial)? I am
asking cos this povray forum format is so
limiting and I would like to write to you about this in more usable way :(
Date: 17 Mar 2015 12:40:01
Message: <web.55085835b66bd306b91df8500@news.povray.org>
> > follows:
> > dot() function.
> > acos() function.
> > I hope this helps.
Well, I got it and maybe strangely enough the help came from guy called hrontos
- developer of your hated LDD-to-POVRay :):):):):)
Date: 18 Mar 2015 08:00:39
Message: <550968e7$1@news.povray.org>
Am 17.03.2015 um 12:59 schrieb bublible:
Nope; I'm more a 3D rendering enthusiast who also likes to dabble a bit
with LEGO, rather than a LEGO enthusiast who also likes to dabble a bit
with 3D renders.
Date: 18 Mar 2015 08:02:54
Message: <5509696e$1@news.povray.org>
Am 17.03.2015 um 17:37 schrieb bublible:
Hmm... maybe I should contact that guy and try to help make the tool
better, rather than just rant about it here.
