POV-Ray : Newsgroups : povray.advanced-users : Rendering POVRay Images at different camera positions(translations and rota= Server Time
8 Feb 2026 09:16:24 EST (-0500)
  Rendering POVRay Images at different camera positions(translations and rota= (Message 1 to 4 of 4)
Subject: Rendering POVRay Images at different camera positions(translations and rota=
Date: 3 Nov 2014 16:40:01
Message: <web.5457f5ab25e0dc43cfa57e830@news.povray.org>
Hi everyone,
I have a txt file containing a list of camera positions at which I'd like to
render my scene at. The scene is an obj file converted to POVRay format (.pov,
..inc, .mat, .ini etc. using poseray) and there are around 60K tokens so it
spends a lot of time parsing this scene file when I send a render command for
instance
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
==== [Parsing...] ==========================================================
Parsing 18284K tokens
The image renders quickly after it is done parsing. I'm issuing a fresh
rendering request every time I render the scene at a different camera position.
Is there any possibility of rendering all the images within one rendering
instance without having to re-parse it every time? This would save me a huge
amount of time. I know animation can be helpful here but I don't know how to use
it together with the camera positions (numbered from 1 to N). If you have any
suggestions, it would be of immense help.
Thank you for your time.
Kind Regards,
Subject: Re: Rendering POVRay Images at different camera positions(translations and rota=
Date: 3 Nov 2014 19:12:44
Message: <545819fc@news.povray.org>
Even for animations, objects do not persist across frames. However,
UberPOV now features #persistent variables for this purpose, see
https://github.com/UberPOV/UberPOV
Date: 4 Nov 2014 20:58:28
Message: <54598444@news.povray.org>
> Hi everyone,
> instance
> Kind Regards,
For an animation using the defined camera positions, you have a few options:
1) In a loop using frame_number as a controll value, read your
positions, stopping at the desired one.
2) Read all the positions at once and place them in an array, say,
Cam_Pos[xx]. Next, use a specific element:
camera{location Cam_Pos[frame_number] look_at 0}
By the way, 60K tokens is not even large. I have scenes with a tokens
count 2 order of magnitude larger... And the source is less that 4Kb.
The joy of loops.
Subject: Re: Rendering POVRay Images at different camera positions(translationsand rota=
Date: 5 Nov 2014 03:45:21
Message: <5459e3a1$1@news.povray.org>
> The joy of loops.
60k token is not large, but if it is a single mesh, it can be slow near
the end. (whereas a mesh2 of the same object would not slow as parsing
progresses).
Just because nobody complains does not mean all parachutes are perfect.
