POV-Ray : Newsgroups : povray.advanced-users : Macro in POV-ray Server Time
11 Oct 2025 00:57:17 EDT (-0400)
  Macro in POV-ray (Message 1 to 6 of 6)
Subject: Macro in POV-ray
Date: 17 Oct 2014 22:35:00
Message: <web.5441d0a9bcbb5a72e0d811940@news.povray.org>
I want to do azimuth and elevation so Rotate_Around_Trans() I think helps me.
But how to use it? Its not working when I write it as
Rotate_Around_Trans(1.x, 2.x, 3.x, 1, 0, 0).
How to make a macro in POV-ray? In documents I am unable to find it. Can I make
my own macro for azimuth and elevation?
Subject: Re: Macro in POV-ray
Date: 18 Oct 2014 00:40:00
Message: <web.5441eeeb5ae0f3ce5e7df57c0@news.povray.org>
 Rotate_Around_Trans(Rotation, Point). Ordinary rotation operates around the
origin, this macro rotates around a specific point.
Parameters:
    Rotation = The rotation vector, the same as the parameter to the rotate
keyword.
    Point = The point to rotate around.
So,
#include "transforms.inc"
 object {My_Object Rotate_Around_Trans(z*90, <0, 0, 0>) }
would rotate around the z-axis like usual.
 object {My_Object Rotate_Around_Trans(z*90, <5, 0, 0>) }
rotates around the z-axis where x=5.
Macros are kinda like a subroutine.
You define a macro by using the MACRO keyword
#macro My_Macro (d, e, f)
     #local g = d * 3;
     sphere {<d, e, f>, g}
#declare a = 1;
#declare b = 2;
#declare c = 3;
My_Macro (a, b, c)
The values plugged into the macro (a, b, and c) are copied over to the macro
variables (e, f, and g) for use within the macro.
The macro variable g is only defined within the macro - outside of the macro g
is undefined.
Hit F1 or select HELP from the menu while running POV-Ray.
Search for macros - there's a whole section.
3.3.2.8 User Defined Macros
Date: 18 Oct 2014 22:10:01
Message: <web.54431b9f5ae0f3ce9532ba3c0@news.povray.org>
> Parameters:
> keyword.
> So,
>      #local g = d * 3;
> #end
> #declare a = 1;
> #declare b = 2;
> #declare c = 3;
> My_Macro (a, b, c)
> is undefined.
Thanks a lot. :)
I make a macro named as Camera_rotation(a, b, c) and I am now able to rotate
camera. :)
Can we make a macro for a box? In which box is formed using 8 vertex?
Thanks
Gurwinder Singh Bains
Date: 19 Oct 2014 01:10:01
Message: <web.544346f35ae0f3ce5e7df57c0@news.povray.org>
Boxes are traditionally just made with the BOX directive, specifying the two
opposing corners.
box {<0, 0, 0>, <1, 1, 1> pigment {Red}}
You can also get a box shape with a superquadratic ellipsoid:
superellipsoid {<0, 0> texture {pigment {Green} finish {phong 0.2}} }
Changing either zero to another value changes the shape, and you can get rounded
boxes, cylinders, spheres, etc.  It's a fun shape to use, but can be slow to
render.
There are also the Round Box and Wire Box shapes:
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes330e.htm
Good Luck,
//==============================Bald Eagle====================================
cylinder{z,z*1.1,.65 pigment{cylindrical rotate x*90 color_map{[0 rgb<1,.2,0>]
[1 rgb xy]}}}#macro C(D,S,F,M)sin(radians(D+(F*90)+(i*S)))*A+M#end#local L=.9;
#local A=0.3125;#local i=0;#local T=.014;#macro
R(X,Y,D,S,M,N)cylinder{<X,Y,L>,<C(D,S,1,M),C(D,S,0,N),L>T}#end#macro
V(X,Y,Z,P,J,K,Q,U)cone{<X,Y,Z>P<J,K,Z>Q pigment{rgb U}}#end#while(i<8)#local
F=R(-0.243,.113,170,20,-.415,.069) #local
W=difference{R(-.172+(i/80),.328,250,5,-0.18,0.18)sphere {<-.14,.22,L>A/2.4}}
union{object{F}object{F scale-x*1}object{W}object{W scale-x*1}
cylinder{<.004,.095,L>,<-.007,-.18,L>,.1}pigment{Brown}}
cylinder{<-.008,-0.03,L>,<C(240,10,1,-.028),C(240,10,0,-.09),L>.014 pigment{rgb
1}}V(-.01,.095,L,.08,.003,.28,.021,1)V(-.001,.2,.85,0,.01,.26,.028,0)
V(.019,.23,.83,0,.026,.25,.01,xy)sphere{<.005,.25,.82>.002 pigment{rgb
1}}#declare i=i+1;#end
Date: 19 Oct 2014 18:51:25
Message: <5444406d@news.povray.org>
> Thanks
While it can be made, it's much simpler, faster and less prone to errors
to use the box primitive. The face of that box are parallel to the
reference planes. If you want your box in another orientation, you just
need to create is around the origin, rotate it as needed, and translate
it to the desired location, or use the Rotate_Around_Trans macro.
It can also be done using the prism primitive using a 4 sided base. Good
if the "box" you want faces are not parallel to each others.
You can also use a transform matrix if you want to shear your box.
Finaly, if you want to have non-flat faces, you can use an union of 8
bicubic patches or a mesh.
A macro can automate the creation process for those.
Date: 19 Oct 2014 20:55:01
Message: <web.54445c965ae0f3ce5e7df57c0@news.povray.org>
Good call.  I wasn't thinking about asymmetric instances.
So many options. :D
True.  Almost limitless options with custom CSG objects.
There's also this -
http://www.f-lohmueller.de/pov_tut/a_geo/a_geo62e.htm
I may have to play around with the SuperCone object - that looks like it has
great potential for some things I've been thinking of trying.
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes360e.htm
