POV-Ray : Newsgroups : povray.advanced-users : focal_point with camera transform? Server Time
14 Mar 2026 14:32:30 EDT (-0400)
  focal_point with camera transform? (Message 1 to 10 of 13)
Subject: focal_point with camera transform?
Date: 7 Nov 2013 15:05:01
Message: <web.527bf23a113a666c4dc349de0@news.povray.org>
Is it possible to create a perspective camera that doesn't use "location" and
"look_at", but instead uses "transform {matrix <...>}" and have focal_point work
properly?
When I try to use a transform with a camera, focal_point no longer works as
described.
Any help would be greatly appreciated!
-andy.
Subject: Re: focal_point with camera transform?
Date: 7 Nov 2013 22:59:18
Message: <527c6196$1@news.povray.org>
> properly?
> described.
> -andy.
It's realy easy to set a camera that don't use location and point_at:
Just don't set them and you get a camera siting at the origin and look
toward <0,0,1>.
If you transform your camera after seting focal_point, then the
transform will apply to focal_point the same way it apply to the rest.
You may want to transform your camera BEFORE you set the facal point.
If you declared your camera with a focal_point and then use
camera{Camera_Id transform{My_Tranfsorm}}, you may want to change it to:
camera{Camera_Id transform{My_Tranfsorm} focal_point FocalPoint}
This will reset focal_point to the corect location.
Date: 8 Nov 2013 07:42:54
Message: <527cdc4e$1@news.povray.org>
> properly?
> described.
> -andy.
I did some work on this sort of problem a couple of years ago. If I
understand you correctly, you want to be able to position the look_at at
some arbitrary position within the actual image.
Unfortunately, I'm at work atm but will look up the work I did and post
back this evening (I'm on GMT)
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 8 Nov 2013 18:13:54
Message: <527d7032$1@news.povray.org>
>> properly?
>> described.
>> -andy.
> John
Dammit, I can't find the files immediately - maybe a conjunction of
fatigue and somewhat-upset son (he can't understand why Peppa Pig is not
on Feegle-on-Demand). I'll keep looking.
John
Protect the Earth
Date: 9 Nov 2013 00:35:00
Message: <web.527dc85e9915e2734dc349de0@news.povray.org>
> > properly?
> > described.
> > -andy.
> toward <0,0,1>.
> Alain
I tried that -- no dice...
Here is a normal camera using look_at and location:
 perspective
 angle 60
 location<0,7,7>
 look_at<0,0,-1>
 focal_point <0.0,3.5,1>
        aperture 0.5
        blur_samples 100
        confidence .9
        variance 1/10000
Then I do this, and it doesn't work:
 perspective
 direction <0,0,-1>
 angle 60
 transform { matrix<1,0,0,0,1,0.1,0,-0.1,1,0,-1.75,-12> inverse }
        aperture 0.5
        blur_samples 100
        confidence .9
        variance 1/10000
The reason why I am using direction with z negative is because I am using OpenGL
to generate the matrix, where Z goes towards the camera, not away.
Date: 9 Nov 2013 00:45:01
Message: <web.527dcacc9915e2734dc349de0@news.povray.org>
> camera {
>  perspective
>  angle 60
>  location<0,7,7>
>  look_at<0,0,-1>
>         aperture 0.5
>         blur_samples 100
>         confidence .9
>         variance 1/10000
> camera {
>  perspective
>  direction <0,0,-1>
>  angle 60
>         aperture 0.5
>         blur_samples 100
>         confidence .9
>         variance 1/10000
As soon as i wrote "Where Z goes towards the camera, not away." and hit "enter",
it hit me.
In the matrix above, i am translating -12 on the Z. Since direction is set to be
negative, I need to compensate for that by changing this:
to this:
focal_point <0.0,3.5,-11>
-12-11=1, and 1 is where i want the focal point to be set up on Z.
It seems to work? Am I heading down the right path?
Date: 9 Nov 2013 13:25:20
Message: <527e7e10$1@news.povray.org>
>> camera {
>>   perspective
>>   angle 60
>>   location<0,7,7>
>>   look_at<0,0,-1>
>>          aperture 0.5
>>          blur_samples 100
>>          confidence .9
>>          variance 1/10000
>> camera {
>>   perspective
>>   direction <0,0,-1>
>>   angle 60
>>          aperture 0.5
>>          blur_samples 100
>>          confidence .9
>>          variance 1/10000
> it hit me.
> to this:
Try defining your camera without focal blur and only add it after the
transform.
Normaly, focal_point define an absolute location relative to the origin
of the coordinate system.
Date: 9 Nov 2013 18:05:00
Message: <web.527ebf289915e2734dc349de0@news.povray.org>
> >> camera {
> >>   perspective
> >>   angle 60
> >>   location<0,7,7>
> >>   look_at<0,0,-1>
> >>          aperture 0.5
> >>          blur_samples 100
> >>          confidence .9
> >>          variance 1/10000
> >> camera {
> >>   perspective
> >>   direction <0,0,-1>
> >>   angle 60
> >>          aperture 0.5
> >>          blur_samples 100
> >>          confidence .9
> >>          variance 1/10000
> > it hit me.
> > to this:
> transform.
Would it help if I uploaded the POV file?  Here is what I am working with:
http://www.heinleins.com/library.pov.zip
Date: 10 Nov 2013 14:09:37
Message: <527fd9f1$1@news.povray.org>
Testing your scene.
Added some axis centered at the focal_point, and a second axis group
that is transformed by the matrix, to beter see whats going on.
Doing a 2 frames animation with the matrix transform *before* and
*after* setting the focal point.
Also checking using rotate and translate.
In both cases, BOTH results are identical. It looks like it may be a
bug, but it may be as intended but not intuitive.
Apparently, it don't mather wether the transform is applyed before or
after you set the focal point, the transform always apply to the whole
camera. It looks similar to the way turbulence work if it's not
contained in a warp block.
Workaroud:
Using the vtransform() macro, apply your transform/matrix to the parts
of the camera that you want to affect, like location and look_at.
Date: 10 Nov 2013 18:00:01
Message: <web.52800f589915e2734dc349de0@news.povray.org>
> Workaroud:
Could you please show me an example on how to do this?  I am not following what
you are saying...
